[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Wed Aug 4 13:32:34 EDT 2010
changeset de11e3db4e30 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=de11e3db4e30
summary: more filters -- Thin and Returns
changeset bbbac5b90be9 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=bbbac5b90be9
summary: use new filters, reorg a bit
diffstat:
apps/las2las2.cpp | 147 ++++++++++++++++++++++++++++++------------
include/liblas/lasfilter.hpp | 39 +++++++++++
src/lasfilter.cpp | 72 +++++++++++++++++++++
3 files changed, 215 insertions(+), 43 deletions(-)
diffs (truncated from 381 to 300 lines):
diff -r 42a00f65d667 -r bbbac5b90be9 apps/las2las2.cpp
--- a/apps/las2las2.cpp Tue Aug 03 22:49:18 2010 -0500
+++ b/apps/las2las2.cpp Wed Aug 04 12:32:20 2010 -0500
@@ -71,6 +71,12 @@
liblas::Writer* start_writer( std::ofstream* strm,
std::string const& output,
liblas::Header const& header)
@@ -87,42 +93,14 @@
bool process( std::string const& input,
- liblas::Bounds const& bounds,
- uint32_t split_size,
- std::vector<uint8_t> keep_classes,
- std::vector<uint8_t> drop_classes)
+ std::vector<liblas::FilterI*>& filters,
+ uint32_t split_size)
- std::vector<liblas::FilterI*> filters;
- // Source
- std::cout << "Processing:" << "\n - dataset: " << input << std::endl;
- // Make the filters
- if (keep_classes.size() > 0) {
- liblas::ClassificationFilter* class_filter = new ClassificationFilter(keep_classes);
- class_filter->SetType(liblas::FilterI::eInclusion);
- filters.push_back(class_filter);
- if (drop_classes.size() > 0)
- liblas::ClassificationFilter* class_filter = new ClassificationFilter(drop_classes);
- class_filter->SetType(liblas::FilterI::eExclusion);
- if (bounds.dimension() > 0) {
- liblas::BoundsFilter* bounds_filter = new BoundsFilter(bounds);
- filters.push_back(bounds_filter);
std::ifstream ifs;
if (!liblas::Open(ifs, input.c_str()))
@@ -158,45 +136,59 @@
boost::uint32_t const size = reader.GetHeader().GetPointRecordsCount();
boost::int32_t split_bytes_count = 1024*1024*split_size;
- std::cout << "count: " << split_bytes_count;
- int k = 2;
+ int fileno = 2;
while (reader.ReadNextPoint())
liblas::Point const& p = reader.GetPoint();
writer->WritePoint(p);
- split_bytes_count = split_bytes_count - reader.GetHeader().GetSchema().GetByteSize();
term_progress(std::cout, (i + 1) / static_cast<double>(size));
i++;
- if (split_bytes_count < 0) {
+ split_bytes_count = split_bytes_count - reader.GetHeader().GetSchema().GetByteSize();
+ if (split_bytes_count < 0 && split_size > 0) {
+ // The user specifies a split size in mb, and we keep counting
+ // down until we've written that many points into the file.
+ // After that point, we make a new file and start writing into
+ // that.
+ // FIXME. No header accounting is done at this time.
delete writer;
delete ofs;
ofs = new std::ofstream;
ostringstream oss;
- oss << out << "-"<< k <<".las";
+ oss << out << "-"<< fileno <<".las";
- // out = std::string(oss.str());
writer = start_writer(ofs, oss.str(), reader.GetHeader());
- k++;
+ fileno++;
delete writer;
delete ofs;
+ //FIXME: clean up filters
return true;
int main(int argc, char* argv[])
uint32_t split_size;
+ uint32_t thin;
std::string input;
std::string output;
- std::vector<boost::uint8_t> keep_classes;
- std::vector<boost::uint8_t> drop_classes;
+ std::vector<boost::uint8_t> drop_returns;
liblas::Bounds bounds;
+ bool last_return_only;
+ bool first_return_only;
+ std::vector<liblas::FilterI*> filters;
try {
po::options_description desc("Allowed options");
@@ -212,6 +204,12 @@
("keep-classes,k", po::value< string >(), "Classifications to keep.\nUse a comma-separated list, for example, -k 2,4,12")
("drop-classes,d", po::value< string >(), "Classifications to drop.\nUse a comma-separated list, for example, -d 1,7,8")
("extent,e", po::value< string >(), "Extent window that points must fall within to keep.\nUse a comma-separated list, for example, \n -e minx, miny, maxx, maxy\n or \n -e minx, miny, maxx, maxy, minz, maxz")
+ ("thin,t", po::value<uint32_t>(&thin)->default_value(0), "Simple decimation-style thinning.\nThin the file by removing every t'th point from the file.")
+ ("last_return_only", po::value<bool>(&last_return_only)->zero_tokens(), "Keep last returns (cannot be used with --first_return_only)")
+ ("first_return_only", po::value<bool>(&first_return_only)->zero_tokens(), "Keep first returns (cannot be used with --last_return_only")
+ ("keep-returns", po::value< string >(), "Return numbers to keep.\nUse a comma-separated list, for example, --keep-returns 1\nUse --last_return_only or --first_return_only if you want to ensure getting either one of these.")
+ ("drop-returns", po::value< string >(), "Return numbers to drop.\nUse a comma-separated list, for example, --drop-returns 2,3,4,5\nUse --last_return_only or --first_return_only if you want to ensure getting either one of these.")
@@ -227,24 +225,56 @@
return 1;
- boost::char_separator<char> sep(",");
+ boost::char_separator<char> sep(",|");
if (vm.count("keep-classes"))
+ std::vector<boost::uint8_t> keep_classes;
tokenizer tokens(vm["keep-classes"].as< string >(), sep);
for (tokenizer::iterator t = tokens.begin(); t != tokens.end(); ++t) {
keep_classes.push_back(atoi((*t).c_str()));
+ liblas::ClassificationFilter* class_filter = new ClassificationFilter(keep_classes);
+ class_filter->SetType(liblas::FilterI::eInclusion);
+ filters.push_back(class_filter);
if (vm.count("drop-classes"))
+ std::vector<boost::uint8_t> drop_classes;
tokenizer tokens(vm["drop-classes"].as< string >(), sep);
drop_classes.push_back(atoi((*t).c_str()));
+ liblas::ClassificationFilter* class_filter = new ClassificationFilter(drop_classes);
+ class_filter->SetType(liblas::FilterI::eExclusion);
+ if (vm.count("keep-returns"))
+ std::vector<boost::uint16_t> keep_returns;
+ tokenizer tokens(vm["keep-returns"].as< string >(), sep);
+ for (tokenizer::iterator t = tokens.begin(); t != tokens.end(); ++t) {
+ keep_returns.push_back(atoi((*t).c_str()));
+ liblas::ReturnFilter* return_filter = new ReturnFilter(keep_returns, false);
+ return_filter->SetType(liblas::FilterI::eInclusion);
+ filters.push_back(return_filter);
+ if (vm.count("drop-returns"))
+ std::vector<boost::uint16_t> drop_returns;
+ tokenizer tokens(vm["drop-returns"].as< string >(), sep);
+ drop_returns.push_back(atoi((*t).c_str()));
+ liblas::ReturnFilter* return_filter = new ReturnFilter(drop_returns, false);
if (vm.count("extent"))
std::vector<double> vbounds;
@@ -262,8 +292,35 @@
std::cerr << "Bounds must be specified as a 4-tuple or 6-tuple, not a "<< vbounds.size()<<"-tuple" << "\n";
return 1;
+ liblas::BoundsFilter* bounds_filter = new BoundsFilter(bounds);
+ filters.push_back(bounds_filter);
+ if (thin > 0)
+ liblas::ThinFilter* thin_filter = new ThinFilter(thin);
+ filters.push_back(thin_filter);
+ if (first_return_only && last_return_only) {
+ std::cerr << "--first_return_only and --last_return_only cannot be used simultaneously. Use --keep-returns";
+ return 1;
+ if (last_return_only){
+ std::vector<boost::uint16_t> returns;
+ liblas::ReturnFilter* last_filter = new ReturnFilter(returns, true);
+ filters.push_back(last_filter);
+ if (first_return_only){
+ returns.push_back(1);
+ liblas::ReturnFilter* return_filter = new ReturnFilter(returns, false);
if (vm.count("input"))
input = vm["input"].as< string >();
@@ -272,7 +329,11 @@
return 1;
- bool op = process(input, output, bounds, split_size, keep_classes, drop_classes);
+ bool op = process( input,
+ output,
+ filters,
+ split_size
if (!op) {
return (1);
diff -r 42a00f65d667 -r bbbac5b90be9 include/liblas/lasfilter.hpp
--- a/include/liblas/lasfilter.hpp Tue Aug 03 22:49:18 2010 -0500
+++ b/include/liblas/lasfilter.hpp Wed Aug 04 12:32:20 2010 -0500
@@ -121,6 +121,45 @@
+class ThinFilter: public liblas::FilterI
+public:
+ ThinFilter(uint32_t thin);
+ bool filter(const liblas::Point& point);
+private:
+ ThinFilter(ThinFilter const& other);
+ ThinFilter& operator=(ThinFilter const& rhs);
+ uint32_t thin_amount;
+ uint32_t thin_count;
+class ReturnFilter: public FilterI
+public:
+ typedef std::vector<boost::uint16_t> return_list_type;
+ ReturnFilter(return_list_type returns, bool last_only);
+ bool filter(const Point& point);
+private:
+ return_list_type m_returns;
+ bool last_only;
+ ReturnFilter(ReturnFilter const& other);
+ ReturnFilter& operator=(ReturnFilter const& rhs);
} // namespace liblas
More information about the Liblas-commits
