[Liblas-commits] hg: Add liblas::Index back -- octree indexing by Gary Huber
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Aug 4 14:43:30 EDT 2010
changeset 78e653b322d9 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=78e653b322d9
summary: Add liblas::Index back -- octree indexing by Gary Huber
diffstat:
 include/liblas/detail/index/indexcell.hpp   |   105 ++
 include/liblas/detail/index/indexoutput.hpp |    76 +
 include/liblas/lasindex.hpp                 |   263 +++++
 src/CMakeLists.txt                          |    13 +
 src/detail/index/indexcell.cpp              |   277 +++++
 src/detail/index/indexoutput.cpp            |   392 +++++++
 src/lasindex.cpp                            |  1408 +++++++++++++++++++++++++++
 7 files changed, 2534 insertions(+), 0 deletions(-)
diffs (truncated from 2599 to 300 lines):
diff -r bbbac5b90be9 -r 78e653b322d9 include/liblas/detail/index/indexcell.hpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/include/liblas/detail/index/indexcell.hpp	Wed Aug 04 13:43:22 2010 -0500
@@ -0,0 +1,105 @@
+ * $Id$
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  index cell implementation for C++ libLAS
+ * Author:   Gary Huber, gary at garyhuberart.com
+ * (C) Copyright Gary Huber 2010, gary at garyhuberart.com
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifndef LIBLAS_DETAIL_INDEXCELL_HPP_INCLUDED
+#define LIBLAS_DETAIL_INDEXCELL_HPP_INCLUDED
+#include <boost/cstdint.hpp>
+#include <map>
+namespace liblas { namespace detail {
+typedef int16_t ElevExtrema;
+typedef uint32_t ElevRange;
+typedef uint8_t	ConsecPtAccumulator;
+typedef std::map<uint32_t, ConsecPtAccumulator> IndexCellData;
+typedef std::map<uint32_t, IndexCellData> IndexSubCellData;
+class IndexCell
+public:
+	IndexCell();
+private:
+	uint32_t m_FileOffset;
+	uint32_t m_NumPoints;
+	ElevExtrema m_MinZ, m_MaxZ;
+	IndexCellData m_PtRecords;
+	IndexSubCellData m_ZCellRecords;
+	IndexSubCellData m_SubCellRecords;
+public:
+	void SetFileOffset(uint32_t fos);
+	void SetNumPoints(uint32_t nmp);
+	uint32_t GetFileOffset(void) const;
+	uint32_t GetNumRecords(void) const;
+	uint32_t GetNumPoints(void) const;
+	uint32_t GetNumSubCellRecords(void) const;
+	uint32_t GetNumZCellRecords(void) const;
+	ElevExtrema GetMinZ(void) const {return m_MinZ;};
+	ElevExtrema GetMaxZ(void) const {return m_MaxZ;};
+	bool RoomToAdd(uint32_t a);
+	void AddPointRecord(uint32_t a);
+	void AddPointRecord(uint32_t a, uint8_t b);
+	bool IncrementPointRecord(uint32_t a);
+	void RemoveMainRecords(void);
+	void RemoveAllRecords(void);
+	void UpdateZBounds(double TestZ);
+	ElevRange GetZRange(void) const;
+	void AddZCell(uint32_t a, uint32_t b);
+	bool IncrementZCell(uint32_t a, uint32_t b);
+	void AddSubCell(uint32_t a, uint32_t b);
+	bool IncrementSubCell(uint32_t a, uint32_t b);
+	uint8_t GetPointRecordCount(uint32_t a);
+	const IndexCellData::iterator GetFirstRecord(void);
+	const IndexCellData::iterator GetEnd(void);
+	const IndexSubCellData::iterator GetFirstSubCellRecord(void);
+	const IndexSubCellData::iterator GetEndSubCell(void);
+	const IndexSubCellData::iterator GetFirstZCellRecord(void);
+	const IndexSubCellData::iterator GetEndZCell(void);
+}} // namespace liblas::detail
+#endif // LIBLAS_DETAIL_INDEXCELL_HPP_INCLUDED
diff -r bbbac5b90be9 -r 78e653b322d9 include/liblas/detail/index/indexoutput.hpp
+++ b/include/liblas/detail/index/indexoutput.hpp	Wed Aug 04 13:43:22 2010 -0500
@@ -0,0 +1,76 @@
+ * $Id$
+ * Purpose:  index output implementation for C++ libLAS
+ * OF SUCH DAMAGE.
+#ifndef LIBLAS_DETAIL_INDEXOUTPUT_HPP_INCLUDED
+#define LIBLAS_DETAIL_INDEXOUTPUT_HPP_INCLUDED
+#include <liblas/lasindex.hpp>
+#include <liblas/detail/index/indexcell.hpp>
+class IndexOutput
+friend class liblas::Index;
+public:
+	IndexOutput(liblas::Index *indexsource);
+private:
+	liblas::Index *m_index;
+	liblas::VariableRecord m_indexVLRHeaderRecord, m_indexVLRCellRecord;
+	IndexVLRData m_indexVLRHeaderData, m_indexVLRCellPointData, m_indexVLRTempData;
+	uint32_t m_VLRCommonDataSize, m_VLRDataSizeLocation, m_FirstCellLocation, m_LastCellLocation, m_DataRecordSize,
+		m_TempWritePos;
+	bool m_FirstCellInVLR, m_SomeDataReadyToWrite;
+protected:
+	bool InitiateOutput(void);
+	bool OutputCell(liblas::detail::IndexCell *CellBlock, uint32_t CurCellX, uint32_t CurCellY);
+	bool InitializeVLRData(uint32_t CurCellX, uint32_t CurCellY);
+	bool FinalizeOutput(void);
+#endif // LIBLAS_DETAIL_INDEXOUTPUT_HPP_INCLUDED
diff -r bbbac5b90be9 -r 78e653b322d9 include/liblas/lasindex.hpp
+++ b/include/liblas/lasindex.hpp	Wed Aug 04 13:43:22 2010 -0500
@@ -0,0 +1,263 @@
+ * $Id$
+ * Purpose:  LAS index class
+ * Copyright (c) 2010, Gary Huber, gary at garyhuberart.com
+ * OF SUCH DAMAGE.
+#ifndef LIBLAS_LASINDEX_HPP_INCLUDED
+#define LIBLAS_LASINDEX_HPP_INCLUDED
+#include <liblas/lasreader.hpp>
+#include <liblas/lasheader.hpp>
+#include <liblas/lasvariablerecord.hpp>
+// std
+#include <stdexcept> // std::out_of_range
+#include <cstdio>	// file io
+#include <iostream>	// file io
+#include <cstdlib> // std::size_t
+#include <vector> // std::vector
+namespace liblas {
+#define LIBLAS_INDEX_MAXMEMDEFAULT	10000000	// 10 megs default
+#define LIBLAS_INDEX_VERSIONMAJOR	1
+#define LIBLAS_INDEX_VERSIONMINOR	0
+typedef std::vector<uint8_t> IndexVLRData;
+typedef std::vector<liblas::detail::IndexCell> IndexCellRow;
+typedef std::vector<IndexCellRow>	IndexCellDataBlock;
+class liblas::detail::IndexCell;
+class IndexData;
+/// Point data record composed with X, Y, Z coordinates and attributes.
+class Index
+public:
+	Index();
+	Index(liblas::Reader *reader, std::ostream *ofs = 0, const char *tmpfilenme = 0, const char *outfilenme = 0, const char *indexauthor = 0,
+		const char *indexcomment = 0, const char *indexdate = 0,
+		double zbinht = 0.0, uint32_t maxmem = LIBLAS_INDEX_MAXMEMDEFAULT, int debugoutputlevel = 0, FILE *debugger = 0);
+    Index(std::istream *ifs, std::ostream *ofs = 0, const char *tmpfilenme = 0, const char *outfilenme = 0, const char *indexauthor = 0,
+    Index(IndexData const& ParamSrc);
+	~Index();
+    // Blocked copying operations, declared but not defined.
+    /// Copy constructor.
+    Index(Index const& other);
+    /// Assignment operator.
+    Index& operator=(Index const& rhs);
+private:
+	Reader *m_reader;
+	Header m_header;
+	bool m_indexBuilt, m_tempFileStarted, m_readerCreated, m_readOnly, m_forceNewIndex;
+	int m_debugOutputLevel;
+    uint32_t m_pointRecordsCount, m_maxMemoryUsage, m_cellsX, m_cellsY, m_cellsZ, m_totalCells,
+		m_tempFileWrittenBytes, m_DataVLR_ID;
+    int32_t m_LowXCellCompletelyIn, m_HighXCellCompletelyIn, m_LowYCellCompletelyIn, m_HighYCellCompletelyIn,
+		m_LowZCellCompletelyIn, m_HighZCellCompletelyIn;
+    int32_t m_LowXBorderCell, m_HighXBorderCell, m_LowYBorderCell, m_HighYBorderCell,
+		m_LowZBorderCell, m_HighZBorderCell;
+    double m_minX, m_maxX, m_minY, m_maxY, m_minZ, m_maxZ, m_scaleX, m_scaleY, m_scaleZ,
+		m_offsetX, m_offsetY, m_offsetZ, m_rangeX, m_rangeY, m_rangeZ, m_cellSizeZ, m_cellSizeX, m_cellSizeY;
+	double m_filterMinXCell, m_filterMaxXCell, m_filterMinYCell, m_filterMaxYCell, m_filterMinZCell, m_filterMaxZCell;
+	std::string m_tempFileName;
+	std::string m_outFileName;
More information about the Liblas-commits mailing list
