[Liblas-commits] hg: add verbose option to turn off std::cout
updates
liblas-commits at liblas.org
Tue Aug 10 09:39:20 EDT 2010
changeset d9bee62875b5 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d9bee62875b5
summary: add verbose option to turn off std::cout updates
diffstat:
apps/las2las2.cpp | 43 +++++++++++++++++++++++--------------------
1 files changed, 23 insertions(+), 20 deletions(-)
diffs (99 lines):
diff -r c3e01b4cb920 -r d9bee62875b5 apps/las2las2.cpp
--- a/apps/las2las2.cpp Mon Aug 09 22:18:21 2010 -0500
+++ b/apps/las2las2.cpp Tue Aug 10 08:37:20 2010 -0500
@@ -1,16 +1,14 @@
-// $Id$
-// ts2las translates TerraSolid .bin file to ASPRS LAS file.
-// TerraSolid format: http://cdn.terrasolid.fi/tscan.pdf
-// (C) Copyright Howard Butler 2009, hobu.inc at gmail.com
-// Distributed under the BSD License
-// (See accompanying file LICENSE.txt or copy at
-// http://www.opensource.org/licenses/bsd-license.php)
-// liblas
+ * Project: libLAS -- C/C++ read/write library for LAS LIDAR data
+ * Purpose: LAS translation with optional configuration
+ * Author: Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2010, Howard Butler, hobu.inc at gmail.com
+ * See LICENSE.txt in this source distribution for more information.
#include <liblas/liblas.hpp>
#include <fstream>
@@ -191,7 +189,8 @@
bool process( std::string const& input,
std::string const& output,
std::vector<liblas::FilterI*>& filters,
- uint32_t split_size)
+ uint32_t split_size,
+ bool verbose)
@@ -218,7 +217,7 @@
writer = start_writer(ofs, out+"-1"+".las", reader.GetHeader());
+ if (verbose)
std::cout << "Target:"
<< "\n - : " << output
<< std::endl;
@@ -235,8 +234,9 @@
while (reader.ReadNextPoint())
liblas::Point const& p = reader.GetPoint();
- writer->WritePoint(p);
- term_progress(std::cout, (i + 1) / static_cast<double>(size));
+ writer->WritePoint(p);
+ if (verbose)
+ term_progress(std::cout, (i + 1) / static_cast<double>(size));
i++;
split_bytes_count = split_bytes_count - reader.GetHeader().GetSchema().GetByteSize();
@@ -258,8 +258,8 @@
split_bytes_count = 1024*1024*split_size;
- std::cout << std::endl;
+ if (verbose)
+ std::cout << std::endl;
delete writer;
delete ofs;
@@ -288,6 +288,7 @@
bool last_return_only;
bool first_return_only;
bool valid_only;
+ bool verbose = false;
std::vector<liblas::FilterI*> filters;
try {
@@ -315,6 +316,7 @@
("drop-intensity", po::value< string >(), "Range in which to drop intensity.\nThe following expression types are supported. --drop-intensity <200\n --drop-intensity >400\n--drop-intensity >=200")
("keep-time", po::value< string >(), "Range in which to keep time.\nThe following expression types are supported. --keep-time 413665.2336-414092.8462\n --keep-time <414094.8462\n --keep-time >413665.2336\n--keep-time >=413665.2336")
("drop-time", po::value< string >(), "Range in which to drop time.\nThe following expression types are supported. --drop-time <413666.2336\n --drop-time >413665.2336\n--drop-time >=413665.2336")
+ ("verbose", po::value<bool>(&verbose)->zero_tokens(), "Keep only valid points")
@@ -477,7 +479,8 @@
bool op = process( input,
output,
filters,
- split_size
+ split_size,
+ verbose
if (!op) {
return (1);
More information about the Liblas-commits
