[Liblas-commits] hg: add reprojection support
liblas-commits at liblas.org
Tue Aug 10 10:07:12 EDT 2010
changeset 6a6ee5406bd3 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=6a6ee5406bd3
summary: add reprojection support
diffstat:
apps/las2las2.cpp | 85 +++++++++++++++++++++++++++++++++++++++---------------
1 files changed, 61 insertions(+), 24 deletions(-)
diffs (155 lines):
diff -r d9bee62875b5 -r 6a6ee5406bd3 apps/las2las2.cpp
--- a/apps/las2las2.cpp Tue Aug 10 08:37:20 2010 -0500
+++ b/apps/las2las2.cpp Tue Aug 10 09:07:08 2010 -0500
@@ -189,6 +189,7 @@
bool process( std::string const& input,
std::string const& output,
std::vector<liblas::FilterI*>& filters,
+ std::vector<liblas::TransformI*>& transforms,
uint32_t split_size,
bool verbose)
@@ -204,6 +205,7 @@
liblas::Reader reader(ifs);
reader.SetFilters(&filters);
+ reader.SetTransforms(&transforms);
std::ofstream* ofs = new std::ofstream;
std::string out = output;
@@ -278,18 +280,14 @@
uint32_t thin;
std::string input;
std::string output;
- // std::vector<boost::uint16_t> returns;
- // liblas::Bounds<double bounds;
bool last_return_only;
bool first_return_only;
bool valid_only;
bool verbose = false;
- std::vector<liblas::FilterI*> filters;
+ std::vector<liblas::FilterI*> filters;
+ std::vector<liblas::TransformI*> transforms;
try {
@@ -299,25 +297,26 @@
p.add("output", 1);
desc.add_options()
- ("help", "produce help message")
+ ("help,h", "produce help message")
("split,s", po::value<uint32_t>(&split_size)->default_value(0), "Split file into multiple files with each being this size in MB or less. If this value is 0, no splitting is done")
("input,i", po::value< string >(), "input LAS file")
("output,o", po::value< string >(&output)->default_value("output.las"), "output LAS file")
- ("keep-classes,k", po::value< string >(), "Classifications to keep.\nUse a comma-separated list, for example, -k 2,4,12")
- ("drop-classes,d", po::value< string >(), "Classifications to drop.\nUse a comma-separated list, for example, -d 1,7,8")
+ ("keep-classes,k", po::value< string >(), "A comma-separated list of classifications to keep:\n-k 2,4,12\n--keep-classes 2")
+ ("drop-classes,d", po::value< string >(), "A comma-separated list of classifications to drop:\n-d 1,7,8\n--drop-classes 2")
("extent,e", po::value< string >(), "Extent window that points must fall within to keep.\nUse a comma-separated list, for example, \n -e minx, miny, maxx, maxy\n or \n -e minx, miny, maxx, maxy, minz, maxz")
("thin,t", po::value<uint32_t>(&thin)->default_value(0), "Simple decimation-style thinning.\nThin the file by removing every t'th point from the file.")
("last_return_only", po::value<bool>(&last_return_only)->zero_tokens(), "Keep last returns (cannot be used with --first_return_only)")
("first_return_only", po::value<bool>(&first_return_only)->zero_tokens(), "Keep first returns (cannot be used with --last_return_only")
- ("keep-returns", po::value< string >(), "Return numbers to keep.\nUse a comma-separated list, for example, --keep-returns 1\nUse --last_return_only or --first_return_only if you want to ensure getting either one of these.")
+ ("keep-returns", po::value< string >(), "A comma-separated list of return numbers to keep in the output file: \n--keep-returns 1\nUse --last_return_only ")
("drop-returns", po::value< string >(), "Return numbers to drop.\nUse a comma-separated list, for example, --drop-returns 2,3,4,5\nUse --last_return_only or --first_return_only if you want to ensure getting either one of these.")
("valid_only", po::value<bool>(&valid_only)->zero_tokens(), "Keep only valid points")
- ("keep-intensity", po::value< string >(), "Range in which to keep intensity.\nThe following expression types are supported. --keep-intensity 0-100\n --keep-intensity <200\n --keep-intensity >400\n--keep-intensity >=200")
- ("drop-intensity", po::value< string >(), "Range in which to drop intensity.\nThe following expression types are supported. --drop-intensity <200\n --drop-intensity >400\n--drop-intensity >=200")
- ("keep-time", po::value< string >(), "Range in which to keep time.\nThe following expression types are supported. --keep-time 413665.2336-414092.8462\n --keep-time <414094.8462\n --keep-time >413665.2336\n--keep-time >=413665.2336")
- ("drop-time", po::value< string >(), "Range in which to drop time.\nThe following expression types are supported. --drop-time <413666.2336\n --drop-time >413665.2336\n--drop-time >=413665.2336")
- ("verbose", po::value<bool>(&verbose)->zero_tokens(), "Keep only valid points")
+ ("keep-intensity", po::value< string >(), "Range in which to keep intensity.\nThe following expression types are supported: \n--keep-intensity 0-100 \n--keep-intensity <200 \n--keep-intensity >400 \n--keep-intensity >=200")
+ ("drop-intensity", po::value< string >(), "Range in which to drop intensity.\nThe following expression types are supported: \n--drop-intensity <200 \n--drop-intensity >400 \n--drop-intensity >=200")
+ ("keep-time", po::value< string >(), "Range in which to keep time.\nThe following expression types are supported: \n--keep-time 413665.2336-414092.8462 \n--keep-time <414094.8462 \n--keep-time >413665.2336 \n--keep-time >=413665.2336")
+ ("drop-time", po::value< string >(), "Range in which to drop time.\nThe following expression types are supported: \n--drop-time <413666.2336 \n--drop-time >413665.2336 \n--drop-time >=413665.2336")
+ ("verbose,v", po::value<bool>(&verbose)->zero_tokens(), "Keep only valid points")
+ ("a_srs", po::value< string >(), "Coordinate system to assign to input LAS file")
+ ("t_srs", po::value< string >(), "Coordinate system to reproject output LAS file to. Use --a_srs or verify that your input LAS file has a coordinate system according to lasinfo")
@@ -335,6 +334,14 @@
boost::char_separator<char> sep(SEPARATORS);
+ if (vm.count("input"))
+ input = vm["input"].as< string >();
+ } else {
+ std::cerr << "Input LAS file not specified!\n" << desc << "\n";
+ return 1;
if (vm.count("keep-classes"))
std::string returns = vm["keep-classes"].as< string >();
@@ -436,6 +443,41 @@
filters.push_back(time_filter);
+ if (vm.count("t_srs"))
+ liblas::SpatialReference in_ref;
+ liblas::SpatialReference out_ref;
+ std::string output_srs = vm["t_srs"].as< string >();
+ out_ref.SetFromUserInput(output_srs);
+ if (vm.count("a_srs")){
+ std::string input_srs = vm["a_srs"].as< string >();
+ in_ref.SetFromUserInput(input_srs);
+ } else {
+ // If the user didn't assign an input SRS, we'll read the
+ // file and fetch it from there.
+ std::ifstream ifs;
+ if (verbose)
+ std::cout << "Opening " << input << " to fetch SRS" << std::endl;
+ if (!liblas::Open(ifs, input.c_str()))
+ std::cerr << "Cannot open " << input << "for read. Exiting...";
+ return 1;
+ liblas::Reader reader(ifs);
+ in_ref = reader.GetHeader().GetSRS();
+ if (in_ref.GetVLRs().size() == 0)
+ std::cerr << "No input SRS is available on the file you have specified. Please use --a_srs to assign one" << std::endl;
+ return 1;
+ liblas::TransformI* srs_transform = new liblas::ReprojectionTransform(in_ref, out_ref);
+ transforms.push_back(srs_transform);
if (thin > 0)
liblas::ThinFilter* thin_filter = new ThinFilter(thin);
@@ -468,17 +510,12 @@
- if (vm.count("input"))
- input = vm["input"].as< string >();
- } else {
- std::cerr << "Input LAS file not specified!\n" << desc << "\n";
- return 1;
bool op = process( input,
output,
filters,
+ transforms,
split_size,
verbose
More information about the Liblas-commits
