[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Tue Aug 24 05:46:40 EDT 2010
changeset a9b14ba0eb8f in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a9b14ba0eb8f
summary: Missing <boost/cstdint.hpp> header.
changeset bb070c13d79e in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=bb070c13d79e
summary: Missing boost:: qualification
diffstat:
apps/las2las2.cpp | 8 +++++---
src/lasindex.cpp | 2 +-
src/lasvariablerecord.cpp | 2 +-
3 files changed, 7 insertions(+), 5 deletions(-)
diffs (63 lines):
diff -r 6e50f3513398 -r bb070c13d79e apps/las2las2.cpp
--- a/apps/las2las2.cpp Mon Aug 23 22:54:48 2010 -0500
+++ b/apps/las2las2.cpp Tue Aug 24 10:50:49 2010 +0100
@@ -12,6 +12,8 @@
#include <liblas/liblas.hpp>
#include "laskernel.hpp"
+#include <boost/cstdint.hpp>
// #include <fstream>
// #include <iostream>
// #include <sstream>
@@ -99,7 +101,7 @@
liblas::Header const& header,
std::vector<liblas::FilterI*>& filters,
std::vector<liblas::TransformI*>& transforms,
- uint32_t split_size,
+ boost::uint32_t split_size,
bool verbose)
@@ -202,7 +204,7 @@
int main(int argc, char* argv[])
- uint32_t split_size;
+ boost::uint32_t split_size;
std::string input;
std::string output;
@@ -224,7 +226,7 @@
file_options.add_options()
("help,h", "produce help message")
- ("split,s", po::value<uint32_t>(&split_size)->default_value(0), "Split file into multiple files with each being this size in MB or less. If this value is 0, no splitting is done")
+ ("split,s", po::value<boost::uint32_t>(&split_size)->default_value(0), "Split file into multiple files with each being this size in MB or less. If this value is 0, no splitting is done")
("input,i", po::value< string >(), "input LAS file")
("output,o", po::value< string >(&output)->default_value("output.las"), "output LAS file")
("verbose,v", po::value<bool>(&verbose)->zero_tokens(), "Verbose message output")
diff -r 6e50f3513398 -r bb070c13d79e src/lasindex.cpp
--- a/src/lasindex.cpp Mon Aug 23 22:54:48 2010 -0500
+++ b/src/lasindex.cpp Tue Aug 24 10:50:49 2010 +0100
@@ -520,7 +520,7 @@
// number of point records in subcell
boost::uint32_t SubCellNumRecords;
ReadVLRData_n(SubCellNumRecords, CompositeData, ReadPos);
- for (uint32_t SubCellPt = 0; SubCellPt < SubCellNumRecords; ++SubCellPt)
+ for (boost::uint32_t SubCellPt = 0; SubCellPt < SubCellNumRecords; ++SubCellPt)
boost::uint32_t PointID, LastPointID = static_cast<boost::uint32_t>(~0);
bool LastPtRead = 0;
diff -r 6e50f3513398 -r bb070c13d79e src/lasvariablerecord.cpp
--- a/src/lasvariablerecord.cpp Mon Aug 23 22:54:48 2010 -0500
+++ b/src/lasvariablerecord.cpp Tue Aug 24 10:50:49 2010 +0100
@@ -211,7 +211,7 @@
return sum;
-boost::property_tree::ptree VariableRecord::GetPTree( ) const
+boost::property_tree::ptree VariableRecord::GetPTree() const
using boost::property_tree::ptree;
ptree vlr;
More information about the Liblas-commits
