[Liblas-commits] hg: Added file_ptr_stream,
hpp with custom buffer and streams imp...
liblas-commits at liblas.org
Tue Aug 24 07:48:28 EDT 2010
changeset ec8b76f9bedb in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=ec8b76f9bedb
summary: Added file_ptr_stream,hpp with custom buffer and streams implementation helpful to wrap FILE* with stream semantic.
diffstat:
include/liblas/detail/file_ptr_stream.hpp | 113 ++++++++++++++++++++++++++++++
1 files changed, 113 insertions(+), 0 deletions(-)
diffs (118 lines):
diff -r bb070c13d79e -r ec8b76f9bedb include/liblas/detail/file_ptr_stream.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/liblas/detail/file_ptr_stream.hpp Tue Aug 24 12:52:25 2010 +0100
@@ -0,0 +1,113 @@
+ * $Id: lasspatialreference.hpp 1091 2009-03-10 20:17:35Z hobu $
+ * Project: libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose: LAS Spatial Reference class
+ * Author: Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2009, Howard Butler
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ * * Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * * Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided
+ * with the distribution.
+ * * Neither the name of the Martin Isenburg or Iowa Department
+ * of Natural Resources nor the names of its contributors may be
+ * used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifndef LIBLAS_DETAIL_FILE_PTR_STREAM_HPP_INCLUDED
+#define LIBLAS_DETAIL_FILE_PTR_STREAM_HPP_INCLUDED
+#include <cstdio>
+#include <istream>
+#include <ostream>
+#include <streambuf>
+namespace liblas { namespace detail {
+class file_ptr_streambuf : public std::streambuf
+public:
+ file_ptr_streambuf(FILE* fp) : std::streambuf() , fp(fp) {}
+protected:
+ virtual int overflow(int c)
+ return EOF != c ? std::fputc(c, fp) : EOF;
+ virtual int underflow()
+ int const c = std::getc(fp);
+ if (c != EOF)
+ std::ungetc(c, fp);
+ return c;
+ virtual int uflow()
+ return std::getc(fp);
+ virtual int pbackfail(int c)
+ return EOF != c ? std::ungetc(c, fp) : EOF;
+ virtual int sync()
+ return std::fflush(fp);
+private:
+ FILE* fp;
+#pragma warning(push)
+#pragma warning(disable: 4355)
+class file_ptr_istream : private file_ptr_streambuf, public std::istream
+public:
+ explicit file_ptr_istream(FILE* fp) : file_ptr_streambuf(fp), std::istream(this) {}
+class file_ptr_ostream : private file_ptr_streambuf, public std::ostream
+public:
+ explicit file_ptr_ostream(FILE* fp) : file_ptr_streambuf(fp), std::ostream(this) {}
+#pragma warning(pop)
+}} //namespace liblas::detail
+#endif // LIBLAS_DETAIL_FILE_PTR_STREAM_HPP_INCLUDED
\ No newline at end of file
More information about the Liblas-commits
