[Liblas-commits] hg: Added ::boost:: qualifcation to optional and
multi_index typ...
liblas-commits at liblas.org
Tue Aug 24 11:36:48 EDT 2010
changeset 1993c9a1648d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=1993c9a1648d
summary: Added ::boost:: qualifcation to optional and multi_index types used within property_tree - required after moving property_tree to liblas namespace.
diffstat:
include/liblas/property_tree/detail/ptree_implementation.hpp | 20 ++++++------
include/liblas/property_tree/string_path.hpp | 2 +-
2 files changed, 11 insertions(+), 11 deletions(-)
diffs (90 lines):
diff -r bc13be248ea8 -r 1993c9a1648d include/liblas/property_tree/detail/ptree_implementation.hpp
--- a/include/liblas/property_tree/detail/ptree_implementation.hpp Tue Aug 24 16:12:37 2010 +0100
+++ b/include/liblas/property_tree/detail/ptree_implementation.hpp Tue Aug 24 16:40:49 2010 +0100
@@ -43,10 +43,10 @@
> base_container;
#else
- typedef multi_index_container<value_type,
+ typedef ::boost::multi_index_container<value_type,
::boost::multi_index::indexed_by<
::boost::multi_index::sequenced<>,
- ::boost::multi_index::ordered_non_unique<::boost::multi_index::tag<by_name>,
+ ::boost::multi_index::ordered_non_unique< ::boost::multi_index::tag<by_name>,
::boost::multi_index::member<value_type, const key_type,
&value_type::first>,
key_compare
@@ -583,7 +583,7 @@
path_type p(path);
self_type *n = walk_path(p);
if (!n) {
- return optional<self_type&>();
+ return ::boost::optional<self_type&>();
return *n;
@@ -595,7 +595,7 @@
path_type p(path);
if (!n) {
- return optional<const self_type&>();
+ return ::boost::optional<const self_type&>();
return *n;
@@ -772,11 +772,11 @@
::boost::optional<Type> basic_ptree<K, D, C>::get_optional(const path_type &path,
Translator tr) const
- if (optional<const self_type&> child = get_child_optional(path))
+ if (::boost::optional<const self_type&> child = get_child_optional(path))
return child.get().
BOOST_NESTED_TEMPLATE get_value_optional<Type>(tr);
else
- return optional<Type>();
+ return ::boost::optional<Type>();
template<class K, class D, class C>
@@ -784,17 +784,17 @@
const path_type &path) const
return child.get().BOOST_NESTED_TEMPLATE get_value_optional<Type>();
else
template<class Type, class Translator>
void basic_ptree<K, D, C>::put_value(const Type &value, Translator tr)
- if(optional<data_type> o = tr.put_value(value)) {
+ if(::boost::optional<data_type> o = tr.put_value(value)) {
data() = *o;
} else {
BOOST_PROPERTY_TREE_THROW(ptree_bad_data(
@@ -815,7 +815,7 @@
basic_ptree<K, D, C> & basic_ptree<K, D, C>::put(
const path_type &path, const Type &value, Translator tr)
- if(optional<self_type &> child = get_child_optional(path)) {
+ if(::boost::optional<self_type &> child = get_child_optional(path)) {
child.get().put_value(value, tr);
return *child;
} else {
diff -r bc13be248ea8 -r 1993c9a1648d include/liblas/property_tree/string_path.hpp
--- a/include/liblas/property_tree/string_path.hpp Tue Aug 24 16:12:37 2010 +0100
+++ b/include/liblas/property_tree/string_path.hpp Tue Aug 24 16:40:49 2010 +0100
@@ -211,7 +211,7 @@
++m_start;
- if(optional<key_type> key = m_tr.get_value(part)) {
+ if(::boost::optional<key_type> key = m_tr.get_value(part)) {
return *key;
BOOST_PROPERTY_TREE_THROW(ptree_bad_path("Path syntax error", *this));
More information about the Liblas-commits
