[Liblas-commits] hg: 5 new changesets
liblas-commits at liblas.org
Tue Aug 24 11:59:56 EDT 2010
changeset f7770978e9b5 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=f7770978e9b5
summary: add #ifdefs around #pragmas for _MSC_VER
changeset 9886b370b197 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=9886b370b197
summary: oops, botched the merge
changeset c4401e07103e in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=c4401e07103e
summary: more namespace qualification
changeset 7913c2674eec in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=7913c2674eec
summary: Add Reader::Summarize method. Header prototype was added in r2096
changeset eac1c086c112 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=eac1c086c112
summary: fix up to use new libas copy of property_tree
diffstat:
apps/las2las2.cpp | 6 +-
apps/laskernel.cpp | 332 +++++-----
apps/laskernel.hpp | 6 +-
include/liblas/lasreader.hpp | 2 +
include/liblas/property_tree/detail/ptree_implementation.hpp | 7 +-
include/liblas/property_tree/detail/xml_parser_write.hpp | 2 +-
include/liblas/property_tree/string_path.hpp | 6 +-
src/lasreader.cpp | 167 +++++
8 files changed, 352 insertions(+), 176 deletions(-)
diffs (truncated from 666 to 300 lines):
diff -r 1993c9a1648d -r eac1c086c112 apps/las2las2.cpp
--- a/apps/las2las2.cpp Tue Aug 24 16:40:49 2010 +0100
+++ b/apps/las2las2.cpp Tue Aug 24 10:59:33 2010 -0500
@@ -175,11 +175,11 @@
std::cout << std::endl;
reader.Reset();
- boost::property_tree::ptree pts = SummarizePoints(reader);
- boost::property_tree::ptree top;
+ liblas::property_tree::ptree pts = reader.Summarize();
+ liblas::property_tree::ptree top;
top.add_child("summary.header",reader.GetHeader().GetPTree());
top.add_child("summary.points",pts);
- boost::property_tree::write_xml("junk.xml", top);
+ liblas::property_tree::write_xml("junk.xml", top);
delete writer;
delete ofs;
diff -r 1993c9a1648d -r eac1c086c112 apps/laskernel.cpp
--- a/apps/laskernel.cpp Tue Aug 24 16:40:49 2010 +0100
+++ b/apps/laskernel.cpp Tue Aug 24 10:59:33 2010 -0500
@@ -565,171 +565,173 @@
-boost::property_tree::ptree SummarizePoints(liblas::Reader& reader )
- using boost::property_tree::ptree;
- ptree pt;
- boost::array<boost::uint32_t, 32> classes;
- boost::uint32_t synthetic = 0;
- boost::uint32_t withheld = 0;
- boost::uint32_t keypoint = 0;
- boost::uint32_t count = 0;
- boost::array<boost::uint32_t, 8> points_by_return;
- boost::array<boost::uint32_t, 8> returns_of_given_pulse;
- classes.assign(0);
- points_by_return.assign(0);
- returns_of_given_pulse.assign(0);
- bool read = reader.ReadNextPoint();
- if (!read)
- throw std::runtime_error("Unable to read any points from file.");
- bool first = true;
- liblas::Point min;
- liblas::Point max;
- while (read)
+// boost::property_tree::ptree SummarizePoints(liblas::Reader& reader )
+// using boost::property_tree::ptree;
+// ptree pt;
+// boost::array<boost::uint32_t, 32> classes;
+// boost::uint32_t synthetic = 0;
+// boost::uint32_t withheld = 0;
+// boost::uint32_t keypoint = 0;
+// boost::uint32_t count = 0;
+// boost::array<boost::uint32_t, 8> points_by_return;
+// boost::array<boost::uint32_t, 8> returns_of_given_pulse;
+// classes.assign(0);
+// points_by_return.assign(0);
+// returns_of_given_pulse.assign(0);
+// bool read = reader.ReadNextPoint();
+// if (!read)
+// throw std::runtime_error("Unable to read any points from file.");
+// bool first = true;
+// liblas::Point min;
+// liblas::Point max;
+// while (read)
+// count++;
+// liblas::Point const& p = reader.GetPoint();
+// if (first) {
+// min = p;
+// max = p;
+// first = false;
+// min.SetX(std::min(p.GetX(), min.GetX()));
+// max.SetX(std::max(p.GetX(), max.GetX()));
+// min.SetY(std::min(p.GetY(), min.GetY()));
+// max.SetY(std::max(p.GetY(), max.GetY()));
+// min.SetZ(std::min(p.GetZ(), min.GetZ()));
+// max.SetZ(std::max(p.GetZ(), max.GetZ()));
+// min.SetIntensity(std::min(p.GetIntensity(), min.GetIntensity()));
+// max.SetIntensity(std::max(p.GetIntensity(), max.GetIntensity()));
+// min.SetTime(std::min(p.GetTime(), min.GetTime()));
+// max.SetTime(std::max(p.GetTime(), max.GetTime()));
+// min.SetReturnNumber(std::min(p.GetReturnNumber(), min.GetReturnNumber()));
+// max.SetReturnNumber(std::max(p.GetReturnNumber(), max.GetReturnNumber()));
+// min.SetNumberOfReturns(std::min(p.GetNumberOfReturns(), min.GetNumberOfReturns()));
+// max.SetNumberOfReturns(std::max(p.GetNumberOfReturns(), max.GetNumberOfReturns()));
+// min.SetScanDirection(std::min(p.GetScanDirection(), min.GetScanDirection()));
+// max.SetScanDirection(std::max(p.GetScanDirection(), max.GetScanDirection()));
+// min.SetFlightLineEdge(std::min(p.GetFlightLineEdge(), min.GetFlightLineEdge()));
+// max.SetFlightLineEdge(std::max(p.GetFlightLineEdge(), max.GetFlightLineEdge()));
+// min.SetScanAngleRank(std::min(p.GetScanAngleRank(), min.GetScanAngleRank()));
+// max.SetScanAngleRank(std::max(p.GetScanAngleRank(), max.GetScanAngleRank()));
+// min.SetUserData(std::min(p.GetUserData(), min.GetUserData()));
+// max.SetUserData(std::max(p.GetUserData(), max.GetUserData()));
+// min.SetPointSourceID(std::min(p.GetPointSourceID(), min.GetPointSourceID()));
+// max.SetPointSourceID(std::max(p.GetPointSourceID(), max.GetPointSourceID()));
+// liblas::Classification const& cls = p.GetClassification();
+// boost::uint8_t minc = std::min(cls.GetClass(), min.GetClassification().GetClass());
+// boost::uint8_t maxc = std::max(cls.GetClass(), max.GetClassification().GetClass());
+// classes[cls.GetClass()]++;
+// if (cls.IsWithheld()) withheld++;
+// if (cls.IsKeyPoint()) keypoint++;
+// if (cls.IsSynthetic()) synthetic++;
+// min.SetClassification(liblas::Classification(minc));
+// max.SetClassification(liblas::Classification(maxc));
+// liblas::Color const& color = p.GetColor();
+// liblas::Color::value_type red;
+// liblas::Color::value_type green;
+// liblas::Color::value_type blue;
+// red = std::min(color.GetRed(), min.GetColor().GetRed());
+// green = std::min(color.GetGreen(), min.GetColor().GetGreen());
+// blue = std::min(color.GetBlue(), min.GetColor().GetBlue());
+// min.SetColor(liblas::Color(red, green, blue));
+// red = std::max(color.GetRed(), max.GetColor().GetRed());
+// green = std::max(color.GetGreen(), max.GetColor().GetGreen());
+// blue = std::max(color.GetBlue(), max.GetColor().GetBlue());
+// max.SetColor(liblas::Color(red, green, blue));
+// points_by_return[p.GetReturnNumber()]++;
+// returns_of_given_pulse[p.GetNumberOfReturns()]++;
+// read = reader.ReadNextPoint();
+// ptree pmin = min.GetPTree();
+// ptree pmax = max.GetPTree();
+// pt.add_child("minimum", pmin);
+// pt.add_child("maximum", pmax);
+// ptree klasses;
+// for (boost::array<boost::uint32_t,32>::size_type i=0; i < classes.size(); i++) {
+// if (classes[i] != 0) {
+// liblas::Classification c = liblas::Classification(i, false, false, false);
+// std::string name = c.GetClassName();
+// klasses.put("name", name);
+// klasses.put("count", classes[i]);
+// klasses.put("id", i);
+// pt.add_child("classification.classification",klasses);
+// pt.put("classification.withheld", withheld);
+// pt.put("classification.keypoint", keypoint);
+// pt.put("classification.synthetic", synthetic);
+// ptree returns;
+// for (boost::array<boost::uint32_t,8>::size_type i=0; i < points_by_return.size(); i++) {
+// if (i == 0) continue;
+// if (points_by_return[i] != 0)
+// returns.put("id", i);
+// returns.put("count", points_by_return[i]);
+// pt.add_child("points_by_return.return", returns);
+// ptree pulses;
+// for (boost::array<boost::uint32_t,8>::size_type i=0; i < returns_of_given_pulse.size(); i++) {
+// if (returns_of_given_pulse[i] != 0) {
+// pulses.put("id",i);
+// pulses.put("count", returns_of_given_pulse[i]);
+// pt.add_child("returns_of_given_pulse.pulse", pulses);
+// pt.put("count", count);
+// std::cout << min;
+// std::cout << reader.GetHeader();
+// return pt;
- count++;
- liblas::Point const& p = reader.GetPoint();
- if (first) {
- min = p;
- max = p;
- first = false;
- min.SetX(std::min(p.GetX(), min.GetX()));
- max.SetX(std::max(p.GetX(), max.GetX()));
- min.SetY(std::min(p.GetY(), min.GetY()));
- max.SetY(std::max(p.GetY(), max.GetY()));
- min.SetZ(std::min(p.GetZ(), min.GetZ()));
- max.SetZ(std::max(p.GetZ(), max.GetZ()));
- min.SetIntensity(std::min(p.GetIntensity(), min.GetIntensity()));
- max.SetIntensity(std::max(p.GetIntensity(), max.GetIntensity()));
- min.SetTime(std::min(p.GetTime(), min.GetTime()));
- max.SetTime(std::max(p.GetTime(), max.GetTime()));
- min.SetReturnNumber(std::min(p.GetReturnNumber(), min.GetReturnNumber()));
- max.SetReturnNumber(std::max(p.GetReturnNumber(), max.GetReturnNumber()));
- min.SetNumberOfReturns(std::min(p.GetNumberOfReturns(), min.GetNumberOfReturns()));
- max.SetNumberOfReturns(std::max(p.GetNumberOfReturns(), max.GetNumberOfReturns()));
- min.SetScanDirection(std::min(p.GetScanDirection(), min.GetScanDirection()));
- max.SetScanDirection(std::max(p.GetScanDirection(), max.GetScanDirection()));
- min.SetFlightLineEdge(std::min(p.GetFlightLineEdge(), min.GetFlightLineEdge()));
- max.SetFlightLineEdge(std::max(p.GetFlightLineEdge(), max.GetFlightLineEdge()));
- min.SetScanAngleRank(std::min(p.GetScanAngleRank(), min.GetScanAngleRank()));
- max.SetScanAngleRank(std::max(p.GetScanAngleRank(), max.GetScanAngleRank()));
- min.SetUserData(std::min(p.GetUserData(), min.GetUserData()));
- max.SetUserData(std::max(p.GetUserData(), max.GetUserData()));
- min.SetPointSourceID(std::min(p.GetPointSourceID(), min.GetPointSourceID()));
- max.SetPointSourceID(std::max(p.GetPointSourceID(), max.GetPointSourceID()));
- liblas::Classification const& cls = p.GetClassification();
- boost::uint8_t minc = std::min(cls.GetClass(), min.GetClassification().GetClass());
- boost::uint8_t maxc = std::max(cls.GetClass(), max.GetClassification().GetClass());
- classes[cls.GetClass()]++;
- if (cls.IsWithheld()) withheld++;
- if (cls.IsKeyPoint()) keypoint++;
- if (cls.IsSynthetic()) synthetic++;
- min.SetClassification(liblas::Classification(minc));
- max.SetClassification(liblas::Classification(maxc));
- liblas::Color const& color = p.GetColor();
- liblas::Color::value_type red;
- liblas::Color::value_type green;
- liblas::Color::value_type blue;
- red = std::min(color.GetRed(), min.GetColor().GetRed());
- green = std::min(color.GetGreen(), min.GetColor().GetGreen());
- blue = std::min(color.GetBlue(), min.GetColor().GetBlue());
- min.SetColor(liblas::Color(red, green, blue));
- red = std::max(color.GetRed(), max.GetColor().GetRed());
- green = std::max(color.GetGreen(), max.GetColor().GetGreen());
- blue = std::max(color.GetBlue(), max.GetColor().GetBlue());
- max.SetColor(liblas::Color(red, green, blue));
- points_by_return[p.GetReturnNumber()]++;
More information about the Liblas-commits
