[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jan 12 00:22:46 EST 2010
changeset 098d89056bcc in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=098d89056bcc
summary: added vertical coordinate system support
changeset 6123def8e21c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=6123def8e21c
summary: added python bindings for vertical cs stuff, and very modest tests
diffstat:
 apps/las2las.c                         |   64 ++++++++-
 apps/lascommon.c                       |    2 +-
 include/liblas/capi/liblas.h           |    6 +-
 include/liblas/lasspatialreference.hpp |   31 ++++-
 python/liblas/core.py                  |    9 +
 python/liblas/srs.py                   |   11 +-
 python/tests/SRS-GDAL.txt              |   12 +-
 src/gt_wkt_srs.cpp                     |  234 +++++++++++++++++++++++++++++++-
 src/las_c_api.cpp                      |   32 ++++-
 src/lasspatialreference.cpp            |   64 ++++++++-
 10 files changed, 445 insertions(+), 20 deletions(-)
diffs (truncated from 711 to 300 lines):
diff -r d4b4cdaefa95 -r 6123def8e21c apps/las2las.c
--- a/apps/las2las.c	Mon Jan 11 13:46:53 2010 -0500
+++ b/apps/las2las.c	Tue Jan 12 00:17:16 2010 -0500
@@ -140,6 +140,8 @@
     LASPointH surviving_point_max = NULL;
     double surviving_gps_time_min;
     double surviving_gps_time_max;
+    int verticalCSType = -1, verticalDatum = -1, verticalUnits = 9001;
+    const char *verticalCitation = "";
     int clipped = 0;
     int eliminated_return = 0;
@@ -336,6 +338,44 @@
                 do_reprojection = TRUE;
+        else if (   strcmp(argv[i],"--a_srs") == 0  ||
+                    strcmp(argv[i],"-a_srs") == 0
+            ++i;
+            if (LAS_IsGDALEnabled()) {
+                out_srs = LASSRS_Create();
+                ret = LASSRS_SetFromUserInput(out_srs, argv[i]);
+                if (ret) {
+                    LASError_Print("Unable to import output SRS");
+                    exit(1);
+        else if (   strcmp(argv[i],"--a_vertcs") == 0  ||
+                    strcmp(argv[i],"-a_vertcs") == 0
+            ++i;
+            verticalCSType = atoi(argv[i]);
+            ++i;
+            if( i < argc && argv[i][0] != '-' )
+                verticalCitation = argv[i];
+                ++i;
+                    verticalDatum = atoi(argv[i]);
+                    ++i;
+                        verticalUnits = atoi(argv[i]);
+                        ++i;
         else if (   strcmp(argv[i],"--scale") == 0  ||
                     strcmp(argv[i],"-scale") == 0
@@ -811,6 +851,22 @@
         LASHeader_SetDataOffset(surviving_header, LASHeader_GetDataOffset(surviving_header)+abs(header_pad));
+    /* Do we have vertical cs info to set? */
+    if( verticalCSType > 0 )
+        if( out_srs == NULL )
+            out_srs = LASHeader_GetSRS(surviving_header);
+        LASSRS_SetVerticalCS( out_srs,
+                              verticalCSType,
+                              verticalCitation,
+                              verticalDatum,
+                              verticalUnits );
     if (do_reprojection) {
         if (verbose) {
             proj4_text =  LASSRS_GetProj4(out_srs);
@@ -825,8 +881,14 @@
         LASHeader_SetSRS(surviving_header, out_srs);
+    /* Are we just assigning an override SRS? (-a_srs) */
+    else if( out_srs != NULL )
+        LASHeader_SetSRS(surviving_header, out_srs);
     if (verbose) {
         fprintf(stderr,
                 "second pass reading %d and writing %d points ...\n",
diff -r d4b4cdaefa95 -r 6123def8e21c apps/lascommon.c
--- a/apps/lascommon.c	Mon Jan 11 13:46:53 2010 -0500
+++ b/apps/lascommon.c	Tue Jan 12 00:17:16 2010 -0500
@@ -435,7 +435,7 @@
     pSRS = LASHeader_GetSRS(header);
     pszProj4 = LASSRS_GetProj4(pSRS);
-    pszWKT = LASSRS_GetWKT(pSRS);
+    pszWKT = LASSRS_GetWKT_CompoundOK(pSRS);
     pGTIF = LASSRS_GetGTIF(pSRS);
     nVLR = LASHeader_GetRecordsCount(header);
diff -r d4b4cdaefa95 -r 6123def8e21c include/liblas/capi/liblas.h
--- a/include/liblas/capi/liblas.h	Mon Jan 11 13:46:53 2010 -0500
+++ b/include/liblas/capi/liblas.h	Tue Jan 12 00:17:16 2010 -0500
@@ -1117,11 +1117,15 @@
 LAS_DLL const GTIF* LASSRS_GetGTIF(LASSRSH hSRS);
-LAS_DLL char* LASSRS_GetWKT(LASSRSH hSRS);
+LAS_DLL char* LASSRS_GetWKT(LASSRSH hSRS );
+LAS_DLL char* LASSRS_GetWKT_CompoundOK( LASSRSH hSRS );
 LAS_DLL LASError LASSRS_SetWKT(LASSRSH hSRS, const char* value);
 LAS_DLL LASError LASSRS_SetFromUserInput(LASSRSH hSRS, const char* value);
 LAS_DLL char* LASSRS_GetProj4(LASSRSH hSRS);
 LAS_DLL LASError LASSRS_SetProj4(LASSRSH hSRS, const char* value);
+LAS_DLL LASError LASSRS_SetVerticalCS(LASSRSH hSRS, int verticalCSType,
+                                      const char *citation, int verticalDatum,
+                                      int verticalUnits );
 LAS_DLL LASSRSH LASHeader_GetSRS(const LASHeaderH hHeader);
 LAS_DLL LASError LASHeader_SetSRS(LASHeaderH hHeader, const LASSRSH hSRS);
 LAS_DLL void LASSRS_Destroy(LASSRSH hSRS);
diff -r d4b4cdaefa95 -r 6123def8e21c include/liblas/lasspatialreference.hpp
--- a/include/liblas/lasspatialreference.hpp	Mon Jan 11 13:46:53 2010 -0500
+++ b/include/liblas/lasspatialreference.hpp	Tue Jan 12 00:17:16 2010 -0500
@@ -90,6 +90,11 @@
 class LASSpatialReference
 public:
+    enum WKTModeFlag
+        eHorizontalOnly = 1,
+        eCompoundOK = 2
     /// Default constructor.
     LASSpatialReference();
@@ -116,13 +121,35 @@
     /// Returns the OGC WKT describing Spatial Reference System.
     /// If GDAL is linked, it uses GDAL's operations and methods to determine
     /// the WKT.  If GDAL is not linked, no WKT is returned.
-    std::string GetWKT() const;
+    /// \param mode_flag May be eHorizontalOnly indicating the WKT will not
+    /// include vertical coordinate system info (the default), or
+    /// eCompoundOK indicating the the returned WKT may be a compound
+    /// coordinate system if there is vertical coordinate system info
+    /// available.
+    std::string GetWKT( WKTModeFlag mode_flag = eHorizontalOnly ) const;
     /// Sets the SRS using GDAL's OGC WKT. If GDAL is not linked, this
     /// operation has no effect.
     /// \param v - a string containing the WKT string.
     void SetWKT(std::string const& v);
+    /// Sets the vertical coordinate system using geotiff key values.
+    /// This operation should normally be done after setting the horizontal
+    /// portion of the coordinate system with something like SetWKT(),
+    /// SetProj4(), SetGTIF() or SetFromUserInput()
+    /// \param verticalCSType - An EPSG vertical coordinate system code,
+    /// normally in the range 5600 to 5799, or -1 if one is not available.
+    /// \param citation - a textual description of the vertical coordinate
+    /// system or an empty string if nothing is available.
+    /// \param verticalDatum - the EPSG vertical datum code, often in the
+    /// range 5100 to 5299 - implied by verticalCSType if that is provided, or
+    /// -1 if no value is available.
+    /// \param verticalUnits - the EPSG vertical units code, often 9001 for Metre.
+    void SetVerticalCS(int verticalCSType,
+                       std::string const& citation = "",
+                       int verticalDatum = -1,
+                       int verticalUnits = 9001 );
     /// Sets the SRS using GDAL's SetFromUserInput function. If GDAL is not linked, this
     /// \param v - a string containing the definition (filename, proj4, wkt, etc).
diff -r d4b4cdaefa95 -r 6123def8e21c python/liblas/core.py
--- a/python/liblas/core.py	Mon Jan 11 13:46:53 2010 -0500
+++ b/python/liblas/core.py	Tue Jan 12 00:17:16 2010 -0500
@@ -628,6 +628,15 @@
 las.LASSRS_SetProj4.argtypes = [ctypes.c_void_p, ctypes.c_char_p]
 las.LASSRS_SetProj4.errcheck = check_return
+las.LASSRS_SetVerticalCS.restype = ctypes.c_int
+las.LASSRS_SetVerticalCS.argtypes = [ctypes.c_void_p, ctypes.c_int,
+                                     ctypes.c_char_p, ctypes.c_int,
+                                     ctypes.c_int]
+las.LASSRS_SetVerticalCS.errcheck = check_return
+las.LASSRS_GetWKT_CompoundOK.argtypes = [ctypes.c_void_p]
+las.LASSRS_GetWKT_CompoundOK.errcheck = check_value_free
+las.LASSRS_GetWKT_CompoundOK.restype = ctypes.c_char_p
 las.LASSRS_GetWKT.argtypes = [ctypes.c_void_p]
 las.LASSRS_GetWKT.errcheck = check_value_free
 las.LASSRS_GetWKT.restype = ctypes.c_char_p
diff -r d4b4cdaefa95 -r 6123def8e21c python/liblas/srs.py
--- a/python/liblas/srs.py	Mon Jan 11 13:46:53 2010 -0500
+++ b/python/liblas/srs.py	Tue Jan 12 00:17:16 2010 -0500
@@ -55,9 +55,18 @@
         if self.owned:
             if self.handle and core:
                 core.las.LASSRS_Destroy(self.handle)
+    def set_verticalcs( self, verticalCSType, citation = '',
+                        verticalDatum = -1,
+                        verticalUnits = 9001 ):
+        return core.las.LASSRS_SetVerticalCS( self.handle, verticalCSType,
+                                              citation, verticalDatum,
+                                              verticalUnits )
     def get_wkt(self):
         return core.las.LASSRS_GetWKT(self.handle)
+    def get_wkt_compoundok(self):
+        return core.las.LASSRS_GetWKT_CompoundOK(self.handle)
     def set_wkt(self, value):
         return core.las.LASSRS_SetWKT(self.handle, value)
     wkt = property(get_wkt, set_wkt)
diff -r d4b4cdaefa95 -r 6123def8e21c python/tests/SRS-GDAL.txt
--- a/python/tests/SRS-GDAL.txt	Mon Jan 11 13:46:53 2010 -0500
+++ b/python/tests/SRS-GDAL.txt	Tue Jan 12 00:17:16 2010 -0500
@@ -115,4 +115,14 @@
   >>> os.remove('junk_srs_project.las')
\ No newline at end of file
+  >>> f = file.File('../test/data/srs_vertcs.las',mode='r')
+  >>> s = f.header.srs
+  >>> s.get_wkt_compoundok() == """COMPD_CS["unknown",PROJCS["WGS 84 / UTM zone 17N",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-81],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","32617"]],VERT_CS["North American Vertical Datum of 1988",VERT_DATUM["North American Vertical Datum 1988",2005,AUTHORITY["EPSG","5103"]],UNIT["metre",1.0,AUTHORITY["EPSG","9001"]],AXIS["Up",UP],AUTHORITY["EPSG","5703"]]]"""
+  True
+  >>> s2 = srs.SRS()
+  >>> s2.wkt = """PROJCS["WGS 84 / UTM zone 17N",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-81],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","32617"]]"""
+  >>> s2.set_verticalcs( 5703, 'abc', 5103, 9001 )
+  True
+  >>> s2.get_wkt_compoundok()
+  'COMPD_CS["unknown",PROJCS["WGS 84 / UTM zone 17N",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-81],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","32617"]],VERT_CS["abc",VERT_DATUM["North American Vertical Datum 1988",2005,AUTHORITY["EPSG","5103"]],UNIT["metre",1.0,AUTHORITY["EPSG","9001"]],AXIS["Up",UP],AUTHORITY["EPSG","5703"]]]'
diff -r d4b4cdaefa95 -r 6123def8e21c src/gt_wkt_srs.cpp
--- a/src/gt_wkt_srs.cpp	Mon Jan 11 13:46:53 2010 -0500
+++ b/src/gt_wkt_srs.cpp	Tue Jan 12 00:17:16 2010 -0500
@@ -1,5 +1,5 @@
- * $Id: gt_wkt_srs.cpp 16723 2009-04-06 16:15:17Z hobu $
+ * $Id: gt_wkt_srs.cpp 18490 2010-01-09 05:44:49Z warmerdam $
  * Project:  GeoTIFF Driver
  * Purpose:  Implements translation between GeoTIFF normalized projection
@@ -42,7 +42,6 @@
 #include "xtiffio.h"
 #include "cpl_multiproc.h"
 CPL_C_START
 void GTiffOneTimeInit();
 int CPL_DLL VSIFCloseL( FILE * );
@@ -122,6 +121,8 @@
     pszDatum = CPLStrdup(*ppszDatum);
     GTIFFreeMemory( *ppszDatum );
     *ppszDatum = pszDatum;
+    if (pszDatum[0] == '\0')
+        return;
 /*      Translate non-alphanumeric values to underscores.               */
@@ -177,11 +178,11 @@
 /* For example:
-   GTCitationGeoKey (Ascii,215): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 16723 $ $Date: 2009-04-06 11:15:17 -0500 (Mon, 06 Apr 2009) $\nProjection Name = UTM\nUnits = meters\nGeoTIFF Units = meters"
+   GTCitationGeoKey (Ascii,215): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 18490 $ $Date: 2010-01-09 00:44:49 -0500 (Sat, 09 Jan 2010) $\nProjection Name = UTM\nUnits = meters\nGeoTIFF Units = meters"
-   GeogCitationGeoKey (Ascii,267): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 16723 $ $Date: 2009-04-06 11:15:17 -0500 (Mon, 06 Apr 2009) $\nUnable to match Ellipsoid (Datum) to a GeographicTypeGeoKey value\nEllipsoid = Clarke 1866\nDatum = NAD27 (CONUS)"
+   GeogCitationGeoKey (Ascii,267): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 18490 $ $Date: 2010-01-09 00:44:49 -0500 (Sat, 09 Jan 2010) $\nUnable to match Ellipsoid (Datum) to a GeographicTypeGeoKey value\nEllipsoid = Clarke 1866\nDatum = NAD27 (CONUS)"
-   PCSCitationGeoKey (Ascii,214): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 16723 $ $Date: 2009-04-06 11:15:17 -0500 (Mon, 06 Apr 2009) $\nUTM Zone 10N\nEllipsoid = Clarke 1866\nDatum = NAD27 (CONUS)"
+   PCSCitationGeoKey (Ascii,214): "IMAGINE GeoTIFF Support\nCopyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved\n@(#)$RCSfile$ $Revision: 18490 $ $Date: 2010-01-09 00:44:49 -0500 (Sat, 09 Jan 2010) $\nUTM Zone 10N\nEllipsoid = Clarke 1866\nDatum = NAD27 (CONUS)"
@@ -229,6 +230,15 @@
     OGRSpatialReference	oSRS;
+/*  Handle non-standard coordinate systems where GTModelTypeGeoKey      */
+/*  is not defined, but ProjectedCSTypeGeoKey is defined (ticket #3019) */
+    if( psDefn->Model == KvUserDefined && psDefn->PCS != KvUserDefined)
+        psDefn->Model = ModelTypeProjected;
 /*      Handle non-standard coordinate systems as LOCAL_CS.             */
More information about the Liblas-commits mailing list
