[Liblas-commits] hg: add VertCS link
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jan 12 09:23:12 EST 2010
changeset 1576dbef2f3d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=1576dbef2f3d
summary: add VertCS link
diffstat:
 README |  7 +++++--
 1 files changed, 5 insertions(+), 2 deletions(-)
diffs (25 lines):
diff -r 6123def8e21c -r 1576dbef2f3d README
--- a/README	Tue Jan 12 00:17:16 2010 -0500
+++ b/README	Tue Jan 12 08:15:54 2010 -0600
@@ -1,4 +1,4 @@
 libLAS - LAS 1.0/1.1/1.2 ASPRS LiDAR data translation toolset
@@ -104,7 +104,9 @@
 Linked against a 1.2.5+ version of `libgeotiff`_, you can set and get the spatial reference
 systems of LAS files using simple `proj.4`_ coordinate system definitions.
 Alternatively, with libLAS 1.2, you can link against `GDAL`_ to be able to
-manipulate spatial references using WKT.
+manipulate spatial references using WKT.  The current development version of
+libLAS can be used in combination with `GDAL`_ 1.7 to support `vertical coordinate systems`_
+as well.
 Simple Variable Length Record Abstraction
@@ -221,3 +223,4 @@
 .. _`dotnetLibLAS API`: http://liblas.org/wiki/dotnetapi
 .. _`FOSS4G 2008`: http://liblas.org/raw-attachment/wiki/WikiStart/liblas_foss4g_2008.pdf
 .. _`ASPRS Workshop Demo`: http://liblas.org/raw-attachment/wiki/WikiStart/ASPRS-Workshop-NOAA-Demo.pdf
+.. _`vertical coordinate systems`: http://liblas.org/wiki/VerticalCS
More information about the Liblas-commits mailing list
