[Liblas-commits] hg: link to 1.3 spec
liblas-commits at liblas.org
Tue Jan 19 16:52:49 EST 2010
changeset 2e26e1c57ce4 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2e26e1c57ce4
summary: link to 1.3 spec
diffstat:
README | 2 ++
1 files changed, 2 insertions(+), 0 deletions(-)
diffs (19 lines):
diff -r d4ebd0716d8a -r 2e26e1c57ce4 README
--- a/README Mon Jan 18 23:27:11 2010 -0500
+++ b/README Tue Jan 19 15:48:21 2010 -0600
@@ -67,6 +67,7 @@
The LAS Format Standard is maintained by `ASPRS Standards Committee`_. LAS
format standard documents are available in PDF format:
+* `LAS 1.3 Format Standard`_ (2009-07-14)
* `LAS 1.2 Format Standard`_ (2008-09-02)
* `LAS 1.1 Format Standard`_ (2005-05-07)
* `LAS 1.0 Format Standard`_ (2003-05-09)
@@ -188,6 +189,7 @@
.. _`LAStools`: http://www.cs.unc.edu/~isenburg/lastools/
.. _`Martin Isenburg and Jonathan Shewchuk`: http://www.cs.unc.edu/~isenburg/lastools/
.. _`LAS Format`: http://www.lasformat.org/
+.. _`LAS 1.3 Format Standard`: http://liblas.org/raw-attachment/wiki/WikiStart/asprs_las_format_v13.pdf
.. _`LAS 1.2 Format Standard`: http://liblas.org/raw-attachment/wiki/WikiStart/asprs_las_format_v12.pdf
.. _`LAS 1.1 Format Standard`: http://liblas.org/raw-attachment/wiki/WikiStart/asprs_las_format_v11.pdf
.. _`LAS 1.0 Format Standard`: http://liblas.org/raw-attachment/wiki/WikiStart/asprs_las_format_v10.pdf
More information about the Liblas-commits
