[Liblas-commits] hg: move PointFormat, FormatVersion,
and PointSize out into the ...
liblas-commits at liblas.org
Tue Jan 19 17:13:03 EST 2010
changeset a55ca271c41e in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a55ca271c41e
summary: move PointFormat, FormatVersion, and PointSize out into the liblas:: namespace instead of liblas::LASHeader
diffstat:
apps/ts2las.cpp | 8 +++---
include/liblas/lasformat.hpp | 47 ++++++++++++++-----------------------------
include/liblas/lasheader.hpp | 28 +-------------------------
include/liblas/liblas.hpp | 28 ++++++++++++++++++++++++++
src/detail/reader10.cpp | 24 +++++++++++-----------
src/detail/reader11.cpp | 24 +++++++++++-----------
src/detail/reader12.cpp | 32 ++++++++++++++--------------
src/detail/writer10.cpp | 4 +-
src/detail/writer11.cpp | 4 +-
src/detail/writer12.cpp | 8 +++---
src/las_c_api.cpp | 4 +-
src/lasformat.cpp | 17 ++++-----------
src/lasheader.cpp | 4 +-
13 files changed, 106 insertions(+), 126 deletions(-)
diffs (truncated from 575 to 300 lines):
diff -r 2e26e1c57ce4 -r a55ca271c41e apps/ts2las.cpp
--- a/apps/ts2las.cpp Tue Jan 19 15:48:21 2010 -0600
+++ b/apps/ts2las.cpp Tue Jan 19 16:08:36 2010 -0600
@@ -71,16 +71,16 @@
LASHeader header;
// Checks for time and color values
- liblas::LASHeader::PointFormat format = liblas::LASHeader::ePointFormat0;
+ liblas::PointFormat format = liblas::ePointFormat0;
if (hdr->Time) {
if (hdr->Color) {
- format = liblas::LASHeader::ePointFormat3;
+ format = liblas::ePointFormat3;
} else {
- format = liblas::LASHeader::ePointFormat1;
+ format = liblas::ePointFormat1;
} else if (hdr->Color) {
- format = liblas::LASHeader::ePointFormat2;
+ format = liblas::ePointFormat2;
header.SetVersionMinor(2);
header.SetDataFormatId(format);
diff -r 2e26e1c57ce4 -r a55ca271c41e include/liblas/lasformat.hpp
--- a/include/liblas/lasformat.hpp Tue Jan 19 15:48:21 2010 -0600
+++ b/include/liblas/lasformat.hpp Tue Jan 19 16:08:36 2010 -0600
@@ -50,15 +50,15 @@
namespace liblas {
-class LASFormat
+class LASPointFormat
public:
- LASFormat(liblas::uint8_t major, liblas::uint8_t minor, liblas::LASHeader::PointSize size);
- virtual ~LASFormat();
+ LASPointFormat(liblas::uint8_t major, liblas::uint8_t minor, liblas::PointSize size);
+ virtual ~LASPointFormat();
- virtual liblas::LASHeader::PointSize GetByteSize() const = 0;
- virtual void SetByteSize(liblas::LASHeader::PointSize& size) const = 0;
+ virtual liblas::PointSize GetByteSize() const = 0;
+ virtual void SetByteSize(liblas::PointSize& size) const = 0;
liblas::uint8_t GetVersionMajor() { return m_versionmajor; }
void SetVersionMajor(liblas::uint8_t v) {m_versionmajor = v; }
@@ -66,45 +66,30 @@
liblas::uint8_t GetVersionMinor() { return m_versionminor; }
void SetVersionMinor(liblas::uint8_t v) {m_versionminor = v; }
- bool IsCompressed() { return m_compressed; }
- void SetCompressed(bool v) {m_compressed = v;}
- virtual bool HasColor() const = 0;
- virtual bool HasTime() const = 0;
+ bool HasColor() const;
+ bool HasTime() const;
protected:
- liblas::LASHeader::PointSize m_size;
+ liblas::PointSize m_size;
uint8_t m_versionminor;
uint8_t m_versionmajor;
- bool m_compressed;
+ bool m_hasColor;
+ bool m_hasTime;
private:
// Blocked copying operations, declared but not defined.
- LASFormat(LASFormat const& other);
- LASFormat& operator=(LASFormat const& rhs);
+ LASPointFormat(LASPointFormat const& other);
+ LASPointFormat& operator=(LASPointFormat const& rhs);
-class LASPointFormat : public LASFormat
-public:
- typedef LASFormat Base;
- LASPointFormat(liblas::uint8_t major, liblas::uint8_t minor, liblas::LASHeader::PointSize size);
- bool HasColor() { return m_hasColor; }
- bool HasTime() { return m_hasTime; }
- bool IsCompressed() { return false; }
-private:
- bool m_hasColor;
- bool m_hasTime;
} // namespace liblas
diff -r 2e26e1c57ce4 -r a55ca271c41e include/liblas/lasheader.hpp
--- a/include/liblas/lasheader.hpp Tue Jan 19 15:48:21 2010 -0600
+++ b/include/liblas/lasheader.hpp Tue Jan 19 16:08:36 2010 -0600
@@ -49,6 +49,7 @@
#include <liblas/guid.hpp>
#include <liblas/detail/utility.hpp>
#include <liblas/detail/fwd.hpp>
+#include <liblas/liblas.hpp>
//std
#include <cstddef>
#include <string>
@@ -68,33 +69,6 @@
public:
- /// Range of allowed ASPRS LAS file format versions.
- enum FormatVersion
- eVersionMajorMin = 1, ///< Minimum of major component
- eVersionMajorMax = 1, ///< Maximum of major component
- eVersionMinorMin = 0, ///< Minimum of minor component
- eVersionMinorMax = 2 ///< Maximum of minor component
- /// Versions of point record format.
- enum PointFormat
- ePointFormat0 = 0, ///< Point Data Format \e 0
- ePointFormat1 = 1, ///< Point Data Format \e 1
- ePointFormat2 = 2, ///< Point Data Format \e 2
- ePointFormat3 = 3 ///< Point Data Format \e 3
- /// Number of bytes of point record storage in particular format.
- enum PointSize
- ePointSize0 = 20, ///< Size of point record in data format \e 0
- ePointSize1 = 28, ///< Size of point record in data format \e 1
- ePointSize2 = 26, ///< Size of point record in data format \e 2
- ePointSize3 = 34, ///< Size of point record in data format \e 3
- ePointSizeUnknown = -99
/// Official signature of ASPRS LAS file format, always \b "LASF".
static char const* const FileSignature;
diff -r 2e26e1c57ce4 -r a55ca271c41e include/liblas/liblas.hpp
--- a/include/liblas/liblas.hpp Tue Jan 19 15:48:21 2010 -0600
+++ b/include/liblas/liblas.hpp Tue Jan 19 16:08:36 2010 -0600
@@ -117,6 +117,34 @@
#endif
+/// Range of allowed ASPRS LAS file format versions.
+enum FormatVersion
+ eVersionMajorMin = 1, ///< Minimum of major component
+ eVersionMajorMax = 1, ///< Maximum of major component
+ eVersionMinorMin = 0, ///< Minimum of minor component
+ eVersionMinorMax = 2 ///< Maximum of minor component
+/// Versions of point record format.
+enum PointFormat
+ ePointFormat0 = 0, ///< Point Data Format \e 0
+ ePointFormat1 = 1, ///< Point Data Format \e 1
+ ePointFormat2 = 2, ///< Point Data Format \e 2
+ ePointFormat3 = 3 ///< Point Data Format \e 3
+/// Number of bytes of point record storage in particular format.
+enum PointSize
+ ePointSize0 = 20, ///< Size of point record in data format \e 0
+ ePointSize1 = 28, ///< Size of point record in data format \e 1
+ ePointSize2 = 26, ///< Size of point record in data format \e 2
+ ePointSize3 = 34, ///< Size of point record in data format \e 3
+ ePointSizeUnknown = -99
#endif // LIBLAS_HPP_INCLUDED
diff -r 2e26e1c57ce4 -r a55ca271c41e src/detail/reader10.cpp
--- a/src/detail/reader10.cpp Tue Jan 19 15:48:21 2010 -0600
+++ b/src/detail/reader10.cpp Tue Jan 19 16:08:36 2010 -0600
@@ -149,21 +149,21 @@
// 16. Point Data Format ID
read_n(n1, m_ifs, sizeof(n1));
- if (n1 == LASHeader::ePointFormat0)
+ if (n1 == liblas::ePointFormat0)
- header.SetDataFormatId(LASHeader::ePointFormat0);
+ header.SetDataFormatId(liblas::ePointFormat0);
- else if (n1 == LASHeader::ePointFormat1)
+ else if (n1 == liblas::ePointFormat1)
- header.SetDataFormatId(LASHeader::ePointFormat1);
+ header.SetDataFormatId(liblas::ePointFormat1);
- else if (n1 == LASHeader::ePointFormat2)
+ else if (n1 == liblas::ePointFormat2)
- header.SetDataFormatId(LASHeader::ePointFormat2);
+ header.SetDataFormatId(liblas::ePointFormat2);
- else if (n1 == LASHeader::ePointFormat3)
+ else if (n1 == liblas::ePointFormat3)
- header.SetDataFormatId(LASHeader::ePointFormat3);
+ header.SetDataFormatId(liblas::ePointFormat3);
else
@@ -248,7 +248,7 @@
detail::PointRecord record;
// TODO: Replace with compile-time assert
- assert(LASHeader::ePointSize0 == sizeof(record));
+ assert(liblas::ePointSize0 == sizeof(record));
try
@@ -265,7 +265,7 @@
Reader::FillPoint(record, point, header);
point.SetCoordinates(header, point.GetX(), point.GetY(), point.GetZ());
- if (header.GetDataFormatId() == LASHeader::ePointFormat1)
+ if (header.GetDataFormatId() == liblas::ePointFormat1)
double gpst(0);
@@ -297,7 +297,7 @@
// accounting to keep track of the fact that the DataRecordLength
// might not map to ePointSize0 or ePointSize1 (see http://liblas.org/ticket/142)
@@ -310,7 +310,7 @@
double gpst(0);
detail::read_n(gpst, m_ifs, sizeof(double));
diff -r 2e26e1c57ce4 -r a55ca271c41e src/detail/reader11.cpp
--- a/src/detail/reader11.cpp Tue Jan 19 15:48:21 2010 -0600
+++ b/src/detail/reader11.cpp Tue Jan 19 16:08:36 2010 -0600
@@ -150,21 +150,21 @@
// 17. Point Data Format ID
else
@@ -247,7 +247,7 @@
try
@@ -266,7 +266,7 @@
More information about the Liblas-commits
