[Liblas-commits] hg: fix up build type detection for bigfile debug
test, be more ...
liblas-commits at liblas.org
Mon Jul 12 17:30:12 EDT 2010
changeset 5d5c0da9d980 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=5d5c0da9d980
summary: fix up build type detection for bigfile debug test, be more specific testing for libspatialindex headers that don't have the same name as GEOS headers
diffstat:
CMakeLists.txt | 4 +++-
apps/CMakeLists.txt | 2 +-
cmake/modules/FindSpatialIndex.cmake | 2 +-
3 files changed, 5 insertions(+), 3 deletions(-)
diffs (46 lines):
diff -r d1dbe75b5b93 -r 5d5c0da9d980 CMakeLists.txt
--- a/CMakeLists.txt Mon Jul 12 12:01:59 2010 -0500
+++ b/CMakeLists.txt Mon Jul 12 16:30:04 2010 -0500
@@ -63,8 +63,9 @@
# General build settings
# Default to release mode
-set(CMAKE_BUILD_TYPE Release CACHE STRING
+set(CMAKE_BUILD_TYPE Release CACHE STRING
"Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel"
+ FORCE
set(BUILD_PEDANTIC TRUE CACHE BOOL "Choose compilation in pedantic or relaxed mode")
@@ -123,6 +124,7 @@
if (APPLE)
set(SO_EXT dylib)
+ set(CMAKE_FIND_FRAMEWORK "LAST")
elseif(WIN32)
set(SO_EXT dll)
else()
diff -r d1dbe75b5b93 -r 5d5c0da9d980 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt Mon Jul 12 12:01:59 2010 -0500
+++ b/apps/CMakeLists.txt Mon Jul 12 16:30:04 2010 -0500
@@ -22,7 +22,7 @@
set(LAS2LAS2 las2las2 )
string(TOUPPER ${CMAKE_BUILD_TYPE} BUILD_TYPE_UPPER)
-if (CMAKE_BUILD_TYPE EQUAL ${BUILD_TYPE_UPPER})
+if (BUILD_TYPE_UPPER EQUAL "DEBUG")
set(BIGFILE_TEST bigfile_test)
endif()
diff -r d1dbe75b5b93 -r 5d5c0da9d980 cmake/modules/FindSpatialIndex.cmake
--- a/cmake/modules/FindSpatialIndex.cmake Mon Jul 12 12:01:59 2010 -0500
+++ b/cmake/modules/FindSpatialIndex.cmake Mon Jul 12 16:30:04 2010 -0500
@@ -37,7 +37,7 @@
endif()
find_path(SPATIALINDEX_INCLUDE_DIR
- NAMES SpatialIndex.h RTree.h
+ NAMES MVRTree.h
HINTS
${OSGEO4W_ROOT_DIR}/include
PATHS
More information about the Liblas-commits
