[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org
Tue Jul 13 13:50:42 EDT 2010
changeset 0a05c3766864 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0a05c3766864
summary: make a few libxml parameters advanced
changeset dda11297d232 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=dda11297d232
summary: don't force Release mode all the time, only if we're not in the cache already
changeset 2270b232d125 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2270b232d125
summary: add liblas::Bounds class for describing chips and bboxes for spatial index querieis
diffstat:
CMakeLists.txt | 4 +-
apps/CMakeLists.txt | 7 ++
include/liblas/lasbounds.hpp | 96 ++++++++++++++++++++++++++++
include/liblas/lastransform.hpp | 9 +--
src/CMakeLists.txt | 2 +
src/lasbounds.cpp | 136 ++++++++++++++++++++++++++++++++++++++++
6 files changed, 243 insertions(+), 11 deletions(-)
diffs (truncated from 318 to 300 lines):
diff -r 5d5c0da9d980 -r 2270b232d125 CMakeLists.txt
--- a/CMakeLists.txt Mon Jul 12 16:30:04 2010 -0500
+++ b/CMakeLists.txt Tue Jul 13 12:50:32 2010 -0500
@@ -65,7 +65,7 @@
# Default to release mode
set(CMAKE_BUILD_TYPE Release CACHE STRING
"Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel"
- FORCE
set(BUILD_PEDANTIC TRUE CACHE BOOL "Choose compilation in pedantic or relaxed mode")
@@ -139,10 +139,8 @@
if(WITH_LIBXML2)
find_package(LibXml2)
- mark_as_advanced(CLEAR LIBXML2_FOUND)
mark_as_advanced(CLEAR LIBXML2_INCLUDE_DIR)
mark_as_advanced(CLEAR LIBXML2_LIBRARIES)
- mark_as_advanced(CLEAR LIBXML2_DEFINITIONS)
if(LIBXML2_FOUND)
include_directories(${LIBXML2_INCLUDE_DIR})
add_definitions(-DHAVE_LIBXML2=1)
diff -r 5d5c0da9d980 -r 2270b232d125 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt Mon Jul 12 16:30:04 2010 -0500
+++ b/apps/CMakeLists.txt Tue Jul 13 12:50:32 2010 -0500
@@ -21,6 +21,13 @@
set(TXT2LAS txt2las)
set(LAS2LAS2 las2las2 )
+# Set the build type to release if it is not explicitly set by the user and
+# isn't in the cache yet
+if (NOT CMAKE_BUILD_TYPE )
+set(CMAKE_BUILD_TYPE "Release")
+endif()
string(TOUPPER ${CMAKE_BUILD_TYPE} BUILD_TYPE_UPPER)
if (BUILD_TYPE_UPPER EQUAL "DEBUG")
set(BIGFILE_TEST bigfile_test)
diff -r 5d5c0da9d980 -r 2270b232d125 include/liblas/lasbounds.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/liblas/lasbounds.hpp Tue Jul 13 12:50:32 2010 -0500
@@ -0,0 +1,96 @@
+ * $Id$
+ * Project: libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose: LAS bounds class
+ * Author: Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2010, Howard Butler
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ * * Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * * Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided
+ * with the distribution.
+ * * Neither the name of the Martin Isenburg or Iowa Department
+ * of Natural Resources nor the names of its contributors may be
+ * used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifndef LIBLAS_LASFILTER_HPP_INCLUDED
+#define LIBLAS_LASFILTER_HPP_INCLUDED
+#include <liblas/lasversion.hpp>
+#include <liblas/lasheader.hpp>
+#include <liblas/laspoint.hpp>
+#include <liblas/detail/fwd.hpp>
+#include <liblas/liblas.hpp>
+#include <vector>
+#include <boost/array.hpp>
+#include <boost/shared_ptr.hpp>
+namespace liblas
+typedef boost::array <double, 3> Array;
+typedef boost::shared_ptr< Array > ArrayPtr;
+class Bounds
+public:
+ Bounds();
+ Bounds( double minx,
+ double miny,
+ double maxx,
+ double maxy,
+ double minz,
+ double maxz);
+ double miny,
+ double maxx,
+ double maxy);
+ Bounds(Bounds const& other);
+ Bounds& operator=(Bounds const& rhs);
+ double min(liblas::uint32_t i) { return (*mins)[i]; }
+ double max(liblas::uint32_t i) { return (*maxs)[i]; }
+private:
+ ArrayPtr mins;
+ ArrayPtr maxs;
+ void verify();
+} // namespace liblas
+#endif // ndef LIBLAS_LASFILTER_HPP_INCLUDED
diff -r 5d5c0da9d980 -r 2270b232d125 include/liblas/lastransform.hpp
--- a/include/liblas/lastransform.hpp Mon Jul 12 16:30:04 2010 -0500
+++ b/include/liblas/lastransform.hpp Tue Jul 13 12:50:32 2010 -0500
@@ -54,14 +54,7 @@
namespace liblas
-// class TransformI
-// public:
-// virtual bool transform(Point& point) = 0;
-// virtual ~TransformI() {};
#ifndef HAVE_GDAL
typedef struct OGRCoordinateTransformationHS *OGRCoordinateTransformationH;
diff -r 5d5c0da9d980 -r 2270b232d125 src/CMakeLists.txt
--- a/src/CMakeLists.txt Mon Jul 12 16:30:04 2010 -0500
+++ b/src/CMakeLists.txt Tue Jul 13 12:50:32 2010 -0500
@@ -43,6 +43,7 @@
${LIBLAS_HEADERS_DIR}/exception.hpp
${LIBLAS_HEADERS_DIR}/guid.hpp
${LIBLAS_HEADERS_DIR}/iterator.hpp
+ ${LIBLAS_HEADERS_DIR}/lasbounds.hpp
${LIBLAS_HEADERS_DIR}/lasclassification.hpp
${LIBLAS_HEADERS_DIR}/lascolor.hpp
${LIBLAS_HEADERS_DIR}/laserror.hpp
@@ -75,6 +76,7 @@
set(LIBLAS_CPP
+ lasbounds.cpp
lasclassification.cpp
lascolor.cpp
laserror.cpp
diff -r 5d5c0da9d980 -r 2270b232d125 src/lasbounds.cpp
+++ b/src/lasbounds.cpp Tue Jul 13 12:50:32 2010 -0500
@@ -0,0 +1,136 @@
+ * $Id$
+ * Purpose: LAS bounds for C++ libLAS
+ * OF SUCH DAMAGE.
+#include <liblas/lasbounds.hpp>
+#include <cmath>
+#include <limits>
+#include <string>
+#include <sstream>
+namespace liblas {
+Bounds::Bounds()
+ : mins(ArrayPtr()), maxs(ArrayPtr())
+ for (int i = 0; i < 3; ++i) {
+ (*mins)[i] = 0;
+ (*maxs)[i] = 0;
+Bounds::Bounds( double minx,
+ double miny,
+ double maxx,
+ double maxy,
+ double minz,
+ double maxz)
+ (*mins)[0] = minx;
+ (*mins)[1] = miny;
+ (*mins)[2] = minz;
+ (*maxs)[0] = maxx;
+ (*maxs)[1] = maxy;
+ (*maxs)[2] = maxz;
+#ifdef DEBUG
+ verify();
+#endif
+ double miny,
+ double maxx,
+ double maxy)
+ (*mins)[2] = 0;
+ (*maxs)[2] = 0;
+#ifdef DEBUG
+ verify();
+#endif
+Bounds::Bounds(Bounds const& other)
+: mins(other.mins), maxs(other.maxs)
+Bounds& Bounds::operator=(Bounds const& rhs)
+ if (&rhs != this)
+ mins = rhs.mins;
+ maxs = rhs.maxs;
+ return *this;
+void Bounds::verify()
+ for (uint32_t d = 0; d < 3; ++d)
More information about the Liblas-commits
