[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Wed Jul 21 10:24:47 EDT 2010
changeset ce3942ea9e06 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=ce3942ea9e06
summary: notes about not knowing why this test is failing
changeset 57a472166c20 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=57a472166c20
summary: add lasblock docs
diffstat:
doc/images/lasblock_big.png | 0
doc/images/lasblock_small.png | 0
doc/utilities/index.txt | 3 +-
doc/utilities/las2ogr.txt | 8 +++--
doc/utilities/lasblock.txt | 49 ++++++++++++++++++++++++++++++++++
test/unit/lasreader_iterator_test.cpp | 20 +++++++++++++
6 files changed, 76 insertions(+), 4 deletions(-)
diffs (120 lines):
diff -r 9a5ce4fa49d8 -r 57a472166c20 doc/images/lasblock_big.png
Binary file doc/images/lasblock_big.png has changed
diff -r 9a5ce4fa49d8 -r 57a472166c20 doc/images/lasblock_small.png
Binary file doc/images/lasblock_small.png has changed
diff -r 9a5ce4fa49d8 -r 57a472166c20 doc/utilities/index.txt
--- a/doc/utilities/index.txt Tue Jul 20 21:16:40 2010 -0500
+++ b/doc/utilities/index.txt Wed Jul 21 09:24:35 2010 -0500
@@ -14,4 +14,5 @@
lasdiff
las2ogr
txt2las
- las2oci
\ No newline at end of file
+ las2oci
+ lasblock
diff -r 9a5ce4fa49d8 -r 57a472166c20 doc/utilities/las2ogr.txt
--- a/doc/utilities/las2ogr.txt Tue Jul 20 21:16:40 2010 -0500
+++ b/doc/utilities/las2ogr.txt Wed Jul 21 09:24:35 2010 -0500
@@ -21,9 +21,11 @@
data exchange and processing.
In order to build las2ogr utility, one has to link libLAS against GDAL library.
-For Unix, use ./configure script option --with-gdal.
-For Windows, edit nmake.opt file and set GDAL_HOME variable.
-Windows users can instal GDAL binaries using friendly installer from OSGeo4W package.
+See :ref:`compilation` for details on how to link against GDAL.
+.. note::
+ Windows users can install GDAL binaries using friendly installer from OSGeo4W package.
Usage
diff -r 9a5ce4fa49d8 -r 57a472166c20 doc/utilities/lasblock.txt
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/doc/utilities/lasblock.txt Wed Jul 21 09:24:35 2010 -0500
@@ -0,0 +1,49 @@
+.. raw:: pdf
+ PageBreak
+.. _lasblock:
+ lasblock
+:Author: Howard Butler
+:Contact: hobu.inc at gmail.com
+lasblock is a utility for pre-processing an LAS file into "chips" or "blocks".
+These blocks are a custom point partitioning process that aims to optimize
+the fill capacity, shape, and speed of processing. More specifically,
+it attempts to keep the blocks as full as possible and as square as possible
+to augment querying characteristics for `Oracle Point Cloud`_.
+This pre-processing is needed as precursor
+step in the processing chain that ends with actually loading the data via
+:ref:`las2oci`.
+Usage
+ $ lasblock -c 3000 myfile.las
+.. note::
+ If no capacity is specified with ``-c``, 10000 is assumed.
+.. note::
+ lasblock will always write out a myfile.las.kdx file name by default,
+ but you can override the output name with a ``-o`` command-line switch.
+.. figure:: ./images/lasblock_small.png
+ :alt: lasblock output
+.. figure:: ./images/lasblock_big.png
+.. _`Oracle Point Cloud`: http://download.oracle.com/docs/cd/B28359_01/appdev.111/b28400/sdo_pc_pkg_ref.htm
diff -r 9a5ce4fa49d8 -r 57a472166c20 test/unit/lasreader_iterator_test.cpp
--- a/test/unit/lasreader_iterator_test.cpp Tue Jul 20 21:16:40 2010 -0500
+++ b/test/unit/lasreader_iterator_test.cpp Wed Jul 21 09:24:35 2010 -0500
@@ -385,9 +385,29 @@
bbox_t lasbbox(point_t(h.GetMinX(), h.GetMinY(), h.GetMinZ()),
point_t(h.GetMaxX(), h.GetMaxY(), h.GetMaxZ()));
+ // I don't know why this is failing -- hobu
+ // std::cout << std::endl;
+ // std::cout << "minx: " << h.GetMinX()
+ // << " miny: " << h.GetMinY()
+ // << " minz: " << h.GetMinZ()
+ // << " maxx: " << h.GetMaxX()
+ // << " maxy: " << h.GetMaxY()
+ // << " maxz: " << h.GetMaxZ();
// Accumulate points extents to common bounding box
bbox_calculator calculator;
std::for_each(it, end, calculator);
+ // bbox_t b = calculator.get_result();
+ // std::cout << "minx: " << b.min.x
+ // << " miny: " << b.min.y
+ // << " minz: " << b.min.z
+ // << " maxx: " << b.max.x
+ // << " maxy: " << b.max.y
+ // << " maxz: " << b.max.z;
ensure(lasbbox == calculator.get_result());
More information about the Liblas-commits
