[Liblas-commits] hg: keep a reference to the point's header when it
is read
liblas-commits at liblas.org
Wed Jul 21 10:26:30 EDT 2010
changeset 4a7f891d09d1 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=4a7f891d09d1
summary: keep a reference to the point's header when it is read
diffstat:
include/liblas/laspoint.hpp | 21 +++++++++++++
include/liblas/lasreader.hpp | 4 +-
src/detail/reader/point.cpp | 9 +++++-
src/detail/reader/reader.cpp | 68 +++++++++++++++++++------------------------
src/laspoint.cpp | 11 +++++-
src/lasreader.cpp | 44 ++++++++++++++++++----------
6 files changed, 99 insertions(+), 58 deletions(-)
diffs (truncated from 404 to 300 lines):
diff -r 57a472166c20 -r 4a7f891d09d1 include/liblas/laspoint.hpp
--- a/include/liblas/laspoint.hpp Wed Jul 21 09:24:35 2010 -0500
+++ b/include/liblas/laspoint.hpp Wed Jul 21 09:26:24 2010 -0500
@@ -46,6 +46,7 @@
#include <liblas/detail/fwd.hpp>
#include <liblas/detail/utility.hpp>
#include <liblas/lasclassification.hpp>
+#include <liblas/lasheader.hpp>
#include <liblas/lascolor.hpp>
// std
@@ -53,10 +54,17 @@
#include <cstdlib> // std::size_t
#include <vector> // std::vector
+#include <boost/shared_ptr.hpp>
namespace liblas {
/// Point data record composed with X, Y, Z coordinates and attributes.
class Point
public:
@@ -187,6 +195,11 @@
std::vector<liblas::uint8_t> const& GetExtraData() const {return m_extra_data; }
void SetExtraData(std::vector<uint8_t> const& v) { m_extra_data = v;}
+ std::vector<liblas::uint8_t> const& GetData() const {return m_format_data; }
+ void SetData(std::vector<uint8_t> const& v) { m_format_data = v;}
+ void SetHeader(const liblas::Header& header);
+ const liblas::Header* GetHeader () { return m_hdr; }
private:
static std::size_t const coords_size = 3;
@@ -203,6 +216,9 @@
int8_t m_angleRank;
std::vector<uint8_t> m_extra_data;
+ std::vector<uint8_t> m_format_data;
+ const liblas::Header* m_hdr;
void throw_out_of_range() const
@@ -360,6 +376,11 @@
return m_coords[n];
+inline void Point::SetHeader(const liblas::Header& header)
+ m_hdr = &header;
} // namespace liblas
#endif // LIBLAS_LASPOINT_HPP_INCLUDED
diff -r 57a472166c20 -r 4a7f891d09d1 include/liblas/lasreader.hpp
--- a/include/liblas/lasreader.hpp Wed Jul 21 09:24:35 2010 -0500
+++ b/include/liblas/lasreader.hpp Wed Jul 21 09:26:24 2010 -0500
@@ -171,10 +171,12 @@
void Init(); // throws on error
const std::auto_ptr<ReaderI> m_pimpl;
- Header m_header;
+ Header* m_header;
Point* m_point;
Point* m_empty_point;
// Set if the user provides a header to override the header as
// read from the istream
bool bCustomHeader;
diff -r 57a472166c20 -r 4a7f891d09d1 src/detail/reader/point.cpp
--- a/src/detail/reader/point.cpp Wed Jul 21 09:24:35 2010 -0500
+++ b/src/detail/reader/point.cpp Wed Jul 21 09:26:24 2010 -0500
@@ -81,12 +81,17 @@
liblas::uint16_t red(0);
liblas::uint16_t blue(0);
liblas::uint16_t green(0);
+ // raw byte data necessary to fill out the point format
+ std::vector<uint8_t> format_data;
+ format_data.resize(m_format.GetBaseByteSize());
detail::PointRecord record;
// TODO: Replace with compile-time assert
assert(liblas::ePointSize0 == sizeof(record));
- // const PointFormat& format = m_header.GetPointFormat();
try
@@ -159,6 +164,8 @@
throw std::runtime_error(msg.str());
+ m_point.SetHeader(m_header);
diff -r 57a472166c20 -r 4a7f891d09d1 src/detail/reader/reader.cpp
--- a/src/detail/reader/reader.cpp Wed Jul 21 09:24:35 2010 -0500
+++ b/src/detail/reader/reader.cpp Wed Jul 21 09:26:24 2010 -0500
@@ -197,35 +197,36 @@
void CachedReaderImpl::CacheData(liblas::uint32_t position, const liblas::Header& header)
- std::vector<uint8_t>::size_type old_cache_start_position = m_cache_start_position;
- m_cache_start_position = position;
+ std::vector<uint8_t>::size_type old_cache_start_position = m_cache_start_position;
+ m_cache_start_position = position;
std::vector<uint8_t>::size_type header_size = static_cast<std::vector<uint8_t>::size_type>(header.GetPointRecordsCount());
std::vector<uint8_t>::size_type left_to_cache = std::min(m_cache_size, header_size - m_cache_start_position);
std::vector<uint8_t>::size_type to_mark = std::min(m_cache_size, header_size - old_cache_start_position);
- for (uint32_t i = 0; i < to_mark; ++i) {
- m_mask[old_cache_start_position + i] = 0;
+ for (uint32_t i = 0; i < to_mark; ++i) {
+ m_mask[old_cache_start_position + i] = 0;
+ // if these aren't equal, we've hopped around with ReadPointAt
+ // and we need to seek to the proper position.
+ if (m_current != position) {
+ CachedReaderImpl::Seek(position, header);
+ m_current = position;
+ m_cache_read_position = position;
+ for (uint32_t i = 0; i < left_to_cache; ++i)
+ try {
+ m_mask[m_current] = 1;
+ m_cache[i] = ReaderImpl::ReadNextPoint(header);
+ } catch (std::out_of_range&) {
+ // cached to the end
+ break;
- // if these aren't equal, we've hopped around with ReadPointAt
- // and we need to seek to the proper position.
- if (m_current != position) {
- CachedReaderImpl::Seek(position, header);
- m_current = position;
- m_cache_read_position = position;
- for (uint32_t i = 0; i < left_to_cache; ++i)
- try {
- m_mask[m_current] = 1;
- m_cache[i] = ReaderImpl::ReadNextPoint(header);
- } catch (std::out_of_range&) {
- // cached to the end
- break;
@@ -304,7 +305,9 @@
} else if (m_size < n) {
std::ostringstream output;
- output << "ReadPointAt:: Inputted value: " << n << " is greater than the number of points: " << m_size;
+ output << "ReadPointAt:: Inputted value: "
+ << n << " is greater than the number of points: "
+ << m_size;
std::string out(output.str());
throw std::runtime_error(out);
@@ -336,6 +339,7 @@
m_cache_start_position = 0;
m_cache_read_position = 0;
ReaderImpl::Reset(header);
@@ -350,20 +354,8 @@
m_cache_read_position = n;
ReaderImpl::Seek(n,header);
-// void CachedReaderImpl::SetOutputSRS(const SpatialReference& srs, const liblas::Header& header)
-// // We need to wipe out the cache if we've set the output srs.
-// std::vector<uint8_t>::size_type header_size = static_cast<std::vector<uint8_t>::size_type>(header.GetPointRecordsCount());
-// std::vector<uint8_t>::size_type left_to_cache = std::min(m_cache_size, header_size - m_cache_start_position);
-// std::vector<uint8_t>::size_type to_mark = std::max(m_cache_size, left_to_cache);
-// for (uint32_t i = 0; i < to_mark; ++i) {
-// m_mask[m_cache_start_position + i] = 0;
-// ReaderImpl::SetOutputSRS(srs, header);
// ReaderImpl* ReaderFactory::Create(std::istream& ifs)
diff -r 57a472166c20 -r 4a7f891d09d1 src/laspoint.cpp
--- a/src/laspoint.cpp Wed Jul 21 09:24:35 2010 -0500
+++ b/src/laspoint.cpp Wed Jul 21 09:26:24 2010 -0500
@@ -55,10 +55,12 @@
m_pointSourceId(0),
m_flags(0),
m_userData(0),
- m_angleRank(0)
+ m_angleRank(0),
+ m_hdr(0)
std::memset(m_coords, 0, sizeof(m_coords));
m_extra_data.resize(0);
+ m_format_data.resize(0);
Point::Point(Point const& other) :
@@ -69,10 +71,13 @@
m_pointSourceId(other.m_pointSourceId),
m_flags(other.m_flags),
m_userData(other.m_userData),
- m_angleRank(other.m_angleRank)
+ m_angleRank(other.m_angleRank),
+ m_hdr(other.m_hdr)
std::memcpy(m_coords, other.m_coords, sizeof(m_coords));
std::vector<uint8_t>(other.m_extra_data).swap(m_extra_data);
+ std::vector<uint8_t>(other.m_format_data).swap(m_format_data);
Point& Point::operator=(Point const& rhs)
@@ -91,6 +96,8 @@
m_gpsTime = rhs.m_gpsTime;
m_color = rhs.m_color;
std::vector<uint8_t>(rhs.m_extra_data).swap(m_extra_data);
+ std::vector<uint8_t>(rhs.m_format_data).swap(m_format_data);
+ m_hdr = rhs.m_hdr;
return *this;
diff -r 57a472166c20 -r 4a7f891d09d1 src/lasreader.cpp
--- a/src/lasreader.cpp Wed Jul 21 09:24:35 2010 -0500
+++ b/src/lasreader.cpp Wed Jul 21 09:26:24 2010 -0500
@@ -58,6 +58,7 @@
Reader::Reader(std::istream& ifs) :
m_pimpl(new detail::CachedReaderImpl(ifs,3)),
+ m_header(0),
m_point(0),
m_empty_point(new Point()),
bCustomHeader(false),
@@ -70,6 +71,7 @@
Reader::Reader(ReaderI* reader) :
m_pimpl(reader),
+ m_header(0),
m_point(0),
@@ -82,15 +84,17 @@
Reader::Reader(std::istream& ifs, Header& header) :
+ m_header(new Header()),
m_point(0),
- bCustomHeader(false),
+ bCustomHeader(true),
m_filters(0),
m_transforms(0),
m_reprojection_transform(TransformPtr())
- m_header = header;
- bCustomHeader = true;
+ // if we have a custom header, create a slot for it and then copy
+ // the header we were given
+ *m_header = header;
Init();
@@ -100,11 +104,14 @@
// std::auto_ptr with incomplete type (Reader).
delete m_empty_point;
More information about the Liblas-commits
