[Liblas-commits] hg: Added source groups to CMake configuration to
display source...
liblas-commits at liblas.org
Fri Jul 30 11:50:35 EDT 2010
changeset b4e076750a61 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=b4e076750a61
summary: Added source groups to CMake configuration to display source files groupped properly making it easier to navigate.
diffstat:
src/CMakeLists.txt | 70 +++++++++++++++++++++++++++++++++--------------------
1 files changed, 43 insertions(+), 27 deletions(-)
diffs (117 lines):
diff -r 8ee2e5eee714 -r b4e076750a61 src/CMakeLists.txt
--- a/src/CMakeLists.txt Fri Jul 30 10:26:47 2010 -0500
+++ b/src/CMakeLists.txt Fri Jul 30 16:54:12 2010 +0100
@@ -19,7 +19,6 @@
set(LIBLAS_HEADERS_DIR ../include/liblas)
set(LIBLAS_HPP
${LIBLAS_HEADERS_DIR}/cstdint.hpp
${LIBLAS_HEADERS_DIR}/exception.hpp
@@ -44,17 +43,20 @@
set(LIBLAS_DETAIL_HPP
${LIBLAS_HEADERS_DIR}/detail/endian.hpp
${LIBLAS_HEADERS_DIR}/detail/fwd.hpp
+ ${LIBLAS_HEADERS_DIR}/detail/sha1.hpp
+ ${LIBLAS_HEADERS_DIR}/detail/timer.hpp
+ ${LIBLAS_HEADERS_DIR}/detail/utility.hpp)
+set(LIBLAS_DETAIL_READER_HPP
${LIBLAS_HEADERS_DIR}/detail/reader/reader.hpp
${LIBLAS_HEADERS_DIR}/detail/reader/header.hpp
- ${LIBLAS_HEADERS_DIR}/detail/reader/point.hpp
- ${LIBLAS_HEADERS_DIR}/detail/sha1.hpp
- ${LIBLAS_HEADERS_DIR}/detail/timer.hpp
- ${LIBLAS_HEADERS_DIR}/detail/utility.hpp
+ ${LIBLAS_HEADERS_DIR}/detail/reader/point.hpp)
+set(LIBLAS_DETAIL_WRITER_HPP
${LIBLAS_HEADERS_DIR}/detail/writer/writer.hpp
${LIBLAS_HEADERS_DIR}/detail/writer/base.hpp
${LIBLAS_HEADERS_DIR}/detail/writer/point.hpp
- ${LIBLAS_HEADERS_DIR}/detail/writer/header.hpp
+ ${LIBLAS_HEADERS_DIR}/detail/writer/header.hpp)
set(LIBLAS_CPP
lasbounds.cpp
@@ -71,32 +73,31 @@
lasvariablerecord.cpp
laswriter.cpp)
-set(LIBLAS_DETAIL_CPP
+set(LIBLAS_DETAIL_CPP) # Currently empty
+set(LIBLAS_DETAIL_READER_CPP
detail/reader/header.cpp
detail/reader/point.cpp
- detail/reader/reader.cpp
+ detail/reader/reader.cpp)
+set(LIBLAS_DETAIL_WRITER_CPP
detail/writer/base.cpp
detail/writer/header.cpp
detail/writer/point.cpp
detail/writer/writer.cpp)
-set(LIBLAS_SOURCES
- ${LIBLAS_HPP}
- ${LIBLAS_DETAIL_HPP}
- ${LIBLAS_INDEX_HPP}
- ${LIBLAS_CPP}
- ${LIBLAS_DETAIL_CPP}
- ${LIBLAS_GDAL_CPP})
-set(LIBLAS_C_SOURCES
- ${LIBLAS_HEADERS_DIR}/capi/las_config.h
- ${LIBLAS_HEADERS_DIR}/capi/las_version.h
- ${LIBLAS_HEADERS_DIR}/capi/liblas.h
- las_c_api.cpp)
+# Group source files for IDE source explorers (e.g. Visual Studio)
source_group("CMake Files" FILES CMakeLists.txt)
-source_group("Header Files" FILES ${LIBLAS_HPP} ${LIBLAS_DETAIL_HPP})
-source_group("Source Files" FILES ${LIBLAS_CPP} ${LIBLAS_DETAIL_CPP})
+source_group("Header Files" FILES ${LIBLAS_HPP})
+source_group("Header Files\\detail" FILES ${LIBLAS_DETAIL_HPP})
+source_group("Header Files\\detail\\reader" FILES ${LIBLAS_DETAIL_READER_HPP})
+source_group("Header Files\\detail\\writer" FILES ${LIBLAS_DETAIL_WRITER_HPP})
+source_group("Source Files" FILES ${LIBLAS_CPP})
+source_group("Source Files\\reader" FILES ${LIBLAS_DETAIL_READER_CPP})
+source_group("Source Files\\writer" FILES ${LIBLAS_DETAIL_WRITER_CPP})
+if(GDAL_FOUND)
+ source_group("Source Files\\gdal" FILES ${LIBLAS_GDAL_CPP})
+endif()
# Diable Visual C++ language extensions when building libLAS library
if (WIN32)
@@ -111,11 +112,26 @@
# Targets settings
+set(LIBLAS_SOURCES
+ ${LIBLAS_HPP}
+ ${LIBLAS_DETAIL_HPP}
+ ${LIBLAS_DETAIL_READER_HPP}
+ ${LIBLAS_DETAIL_WRITER_HPP}
+ ${LIBLAS_CPP}
+ ${LIBLAS_DETAIL_CPP}
+ ${LIBLAS_DETAIL_READER_CPP}
+ ${LIBLAS_DETAIL_WRITER_CPP}
+ ${LIBLAS_GDAL_CPP})
+set(LIBLAS_C_SOURCES
+ ${LIBLAS_HEADERS_DIR}/capi/las_config.h
+ ${LIBLAS_HEADERS_DIR}/capi/las_version.h
+ ${LIBLAS_HEADERS_DIR}/capi/liblas.h
+ las_c_api.cpp)
# Static libLAS C++ library
add_library(${LIBLAS_LIB_NAME} STATIC ${LIBLAS_SOURCES})
# Shared libLAS C library
add_library(${LIBLAS_C_LIB_NAME} SHARED ${LIBLAS_C_SOURCES})
More information about the Liblas-commits
