[Liblas-commits] hg: Removed BUILD_PEDANTIC option from CMake -
default mode anyw...
liblas-commits at liblas.org
Fri Jul 30 12:01:28 EDT 2010
changeset 6c316ce9fb1c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=6c316ce9fb1c
summary: Removed BUILD_PEDANTIC option from CMake - default mode anyway, no reason to disable.
diffstat:
CMakeLists.txt | 15 +--------------
1 files changed, 1 insertions(+), 14 deletions(-)
diffs (39 lines):
diff -r b4e076750a61 -r 6c316ce9fb1c CMakeLists.txt
--- a/CMakeLists.txt Fri Jul 30 16:54:12 2010 +0100
+++ b/CMakeLists.txt Fri Jul 30 17:05:09 2010 +0100
@@ -64,11 +64,7 @@
# Default to release mode
set(CMAKE_BUILD_TYPE Release CACHE STRING
- "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel"
-set(BUILD_PEDANTIC TRUE CACHE BOOL "Choose compilation in pedantic or relaxed mode")
+ "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel")
# TODO: Still testing the output paths --mloskot
set(LIBLAS_BUILD_OUTPUT_DIRECTORY ${PROJECT_BINARY_DIR}/bin/${CMAKE_BUILD_TYPE})
@@ -90,10 +86,6 @@
if(WIN32)
if (MSVC)
- if(BUILD_PEDANTIC)
- set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /W4")
- endif()
if (MSVC80 OR MSVC90 OR MSVC10)
add_definitions(-D_CRT_SECURE_NO_WARNINGS)
add_definitions(-D_CRT_NONSTDC_NO_WARNING)
@@ -111,11 +103,6 @@
if(CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -fPIC -Wall -Wno-long-long -ansi")
- set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -pedantic")
- endif()
if (CMAKE_COMPILER_IS_GNUCXX)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++98")
endif()
More information about the Liblas-commits
