[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Jul 30 12:52:53 EDT 2010
changeset e0d2d9052f56 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=e0d2d9052f56
summary: update to latest svn
changeset d4cea42a18e2 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d4cea42a18e2
summary: pull forward Ivan's array binding code, not yet working
diffstat:
 apps/las2oci.cpp     |  836 +++++++++++++++++++++-------------------------
 apps/oci_wrapper.cpp |  897 +++++++++++++++++++++++++++-----------------------
 apps/oci_wrapper.h   |  195 +++++++---
 3 files changed, 997 insertions(+), 931 deletions(-)
diffs (truncated from 2776 to 300 lines):
diff -r 6c316ce9fb1c -r d4cea42a18e2 apps/las2oci.cpp
--- a/apps/las2oci.cpp	Fri Jul 30 17:05:09 2010 +0100
+++ b/apps/las2oci.cpp	Fri Jul 30 11:52:25 2010 -0500
@@ -1,3 +1,6 @@
+#include <stdlib.h>
 // god-awful hack because of GDAL/GeoTIFF's shitty include structure
 #define CPL_SERV_H_INCLUDED
@@ -10,7 +13,6 @@
 #include <liblas/laspoint.hpp>
 #include <liblas/lasreader.hpp>
 #include <liblas/lasheader.hpp>
-#include <liblas/lasbounds.hpp>
 #include <string>
 #include <sstream>
@@ -24,6 +26,8 @@
 #include <sys/stat.h>
+#include <liblas/lasbounds.hpp>
 #include <oci.h>
 using namespace std;
@@ -35,12 +39,46 @@
 #define compare_no_case(a,b,n)  strncasecmp( (a), (b), (n) )
 #endif
+// #define MAX_POINTS_PER_ROW 1000
 #include <boost/array.hpp>
 #include <boost/shared_ptr.hpp>
 typedef std::vector<liblas::uint32_t> IDVector;
 typedef boost::shared_ptr< IDVector > IDVectorPtr;
+typedef struct
+    long* pc_ids;
+    long* block_ids;
+    long* num_points;
+    OCILobLocator** locators; // =(OCILobLocator**) VSIMalloc( sizeof(OCILobLocator*) * 1 );
+    std::vector<liblas::uint8_t>** blobs;
+    long* srids;
+    long* gtypes;
+    OCIArray** element_arrays;
+    OCIArray** coordinate_arrays;
+    long size;
+} blocks;
+typedef struct
+    double x0;
+    double x1;
+    double y0;
+    double y1;
+    double z0;
+    double z1;
+    bool bUse3d;
+} extent;
 class IndexResult
 public:
@@ -126,41 +164,9 @@
         m_results.push_back(result);
-    liblas::Bounds b2(mins[0], mins[1], maxs[0], maxs[1]);
-    (*bounds) = b2;
+    bounds = boost::shared_ptr<liblas::Bounds>(new liblas::Bounds(mins[0], mins[1], maxs[0], maxs[1]));
-typedef struct
-    long* pc_ids;
-    long* block_ids;
-    long* num_points;
-    OCILobLocator** locators; // =(OCILobLocator**) VSIMalloc( sizeof(OCILobLocator*) * 1 );
-    std::vector<liblas::uint8_t>** blobs;
-    long* srids;
-    long* gtypes;
-    OCIArray** element_arrays;
-    OCIArray** coordinate_arrays;
-    long size;
-} blocks;
-typedef struct
-    double x0;
-    double x1;
-    double y0;
-    double y1;
-    double z0;
-    double z1;
-    bool bUse3d;
-} extent;
 bool KDTreeIndexExists(std::string& filename)
     struct stat stats;
@@ -177,7 +183,6 @@
     return output;
 std::istream* OpenInput(std::string filename, bool bEnd)
     std::ios::openmode mode = std::ios::in | std::ios::binary;
@@ -246,6 +251,7 @@
     return true;
 bool IsGeographic(OWConnection* connection, long srid) {
     ostringstream oss;
@@ -278,10 +284,11 @@
         return true;
     free(kind);
     return false;
 OWStatement* Run(OWConnection* connection, ostringstream& command)
     OWStatement* statement = 0;
@@ -318,25 +325,24 @@
     if (statement != 0) delete statement;
     oss.str("");
-    return true;
+    connection->Commit();
+    return true;
 bool CreateBlockTable(OWConnection* connection, const char* tableName)
     ostringstream oss;
-    oss << "CREATE TABLE "<< tableName <<" (OBJ_ID NUMBER, BLK_ID NUMBER, "
-                                         " BLK_EXTENT MDSYS.SDO_GEOMETRY, BLK_DOMAIN MDSYS.SDO_ORGSCL_TYPE,"
-                                         " PCBLK_MIN_RES NUMBER, PCBLK_MAX_RES NUMBER, NUM_POINTS NUMBER, "
-                                         " NUM_UNSORTED_POINTS NUMBER, PT_SORT_DIM NUMBER, POINTS BLOB)";
+    oss << "CREATE TABLE " << tableName << " AS SELECT * FROM MDSYS.SDO_PC_BLK_TABLE";
     statement = Run(connection, oss);
     if (statement != 0) delete statement; else return false;
     oss.str("");
     return true;
@@ -403,69 +409,19 @@
     oss.str("");
     return true;
-bool GetPointData(  liblas::Point const& p,
-                    bool bTime,
-                    std::vector<liblas::uint8_t>& point_data)
-    // This function returns an array of bytes describing the
-    // x,y,z and optionally time values for the point.
-    point_data.clear();
-    double x = p.GetX();
-    double y = p.GetY();
-    double z = p.GetZ();
-    double t = p.GetTime();
-    liblas::uint8_t* x_b =  reinterpret_cast<liblas::uint8_t*>(&x);
-    liblas::uint8_t* y_b =  reinterpret_cast<liblas::uint8_t*>(&y);
-    liblas::uint8_t* z_b =  reinterpret_cast<liblas::uint8_t*>(&z);
-    liblas::uint8_t* t_b =  reinterpret_cast<liblas::uint8_t*>(&t);
-    // doubles are 8 bytes long.  For each double, push back the
-    // byte.  We do this for all four values (x,y,z,t)
-    // // little-endian
-    // for (int i=0; i<sizeof(double); i++) {
-    //     point_data.push_back(y_b[i]);
-    // big-endian
-    for (int i = sizeof(double) - 1; i >= 0; i--) {
-        point_data.push_back(x_b[i]);
-        point_data.push_back(y_b[i]);
-        point_data.push_back(z_b[i]);
-    if (bTime)
-            point_data.push_back(t_b[i]);
-    return true;
 bool GetResultData( const IndexResult& result,
                     liblas::Reader* reader,
-                    std::vector<liblas::uint8_t>& data,
+                    std::vector<double>& data,
                     int nDimension)
     IDVector const& ids = result.GetIDs();
+    // list<SpatialIndex::id_type> const& ids = result.GetIDs();
     // d 8-byte IEEE  big-endian doubles, where d is the PC_TOT_DIMENSIONS value
@@ -473,51 +429,38 @@
     // 4-byte big-endian integer for the PT_ID value
     bool bTime = false;
-    if (nDimension == 4)
-        bTime = true;
+    // if (nDimension == 4)
+    //     bTime = true;
     data.clear();
+    IDVector::const_iterator i;
+    vector<liblas::uint8_t>::iterator pi;
-    IDVector::const_iterator i;
-    vector<liblas::uint8_t>::iterator pi;
+    // list<SpatialIndex::id_type>::const_iterator i;
+//    vector<liblas::uint8_t>::iterator pi;
-    liblas::uint32_t block_id = result.GetID();
+//    liblas::uint32_t block_id = result.GetID();
     std::vector<liblas::uint8_t> point_data;
     for (i=ids.begin(); i!=ids.end(); ++i)
         liblas::uint32_t id = *i;
+        // SpatialIndex::id_type id = *i;
         bool doRead = reader->ReadPointAt(id);
         if (doRead) {
             liblas::Point const& p = reader->GetPoint();
-            // d 8-byte IEEE  big-endian doubles, where d is the PC_TOT_DIMENSIONS value
-            bool gotdata = GetPointData(p, bTime, point_data);
-            if (!gotdata) { throw std::runtime_error("Unable to fetch Point Data"); exit(1);}
-            std::vector<liblas::uint8_t>::const_iterator d;
-            for (d = point_data.begin(); d!=point_data.end(); ++d) {
-                data.push_back(*d);
-            liblas::uint8_t* id_b = reinterpret_cast<liblas::uint8_t*>(&id);
More information about the Liblas-commits mailing list
