[Liblas-commits] hg: Added public header <liblas/version.hpp>
liblas-commits at liblas.org
Fri Jul 30 20:29:10 EDT 2010
changeset 646bcc90c951 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=646bcc90c951
summary: Added public header <liblas/version.hpp>
diffstat:
include/liblas/version.hpp | 61 ++++++++++++++++++++++++++++++++++++++++++++++
1 files changed, 61 insertions(+), 0 deletions(-)
diffs (65 lines):
diff -r f60c9acafb82 -r 646bcc90c951 include/liblas/version.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/liblas/version.hpp Sat Jul 31 01:29:00 2010 +0100
@@ -0,0 +1,61 @@
+ * $Id$
+ * Project: libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose: Version information
+ * Author: Mateusz Loskot, mateusz at loskot.net
+ * Copyright (c) 2010, Mateusz Loskot
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ * * Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * * Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided
+ * with the distribution.
+ * * Neither the name of the Martin Isenburg or Iowa Department
+ * of Natural Resources nor the names of its contributors may be
+ * used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifndef LIBLAS_VERSION_HPP_INCLUDED
+#define LIBLAS_VERSION_HPP_INCLUDED
+// Caution, this is the only libLAS header that is guarenteed to change with
+// every libLAS release, including this header will cause a recompile every
+// time a new libLAS version is released.
+// LIBLAS_VERSION % 100 is the patch level
+// LIBLAS_VERSION / 100 % 1000 is the minor version
+// LIBLAS_VERSION / 100000 is the major version
+#define LIBLAS_VERSION 103000
+// LIBLAS_LIB_VERSION must be defined to be the same as LIBLAS_VERSION
+// but as a *string* in the form "x_y[_z]" where x is the major version
+// number, y is the minor version number, and z is the patch level if not 0.
+#define LIBLAS_LIB_VERSION "1_3"
+#endif // LIBLAS_VERSION_HPP_INCLUDED
More information about the Liblas-commits
