[Liblas-commits] hg: update las2oci and las2ogr for removal of
liblas/cstdint.hpp
liblas-commits at liblas.org
Fri Jul 30 20:38:38 EDT 2010
changeset a21a73d99c7c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a21a73d99c7c
summary: update las2oci and las2ogr for removal of liblas/cstdint.hpp
diffstat:
apps/las2oci.cpp | 30 +++++++++++++++---------------
apps/las2ogr.cpp | 4 ++--
src/lastransform.cpp | 2 +-
3 files changed, 18 insertions(+), 18 deletions(-)
diffs (133 lines):
diff -r 646bcc90c951 -r a21a73d99c7c apps/las2oci.cpp
--- a/apps/las2oci.cpp Sat Jul 31 01:29:00 2010 +0100
+++ b/apps/las2oci.cpp Fri Jul 30 19:38:24 2010 -0500
@@ -44,7 +44,7 @@
#include <boost/array.hpp>
#include <boost/shared_ptr.hpp>
-typedef std::vector<liblas::uint32_t> IDVector;
+typedef std::vector<uint32_t> IDVector;
typedef boost::shared_ptr< IDVector > IDVectorPtr;
typedef struct
@@ -54,7 +54,7 @@
long* num_points;
OCILobLocator** locators; // =(OCILobLocator**) VSIMalloc( sizeof(OCILobLocator*) * 1 );
- std::vector<liblas::uint8_t>** blobs;
+ std::vector<uint8_t>** blobs;
long* srids;
long* gtypes;
@@ -81,7 +81,7 @@
class IndexResult
public:
- IndexResult(liblas::uint32_t id) : bounds(), m_id(id) {}
+ IndexResult(uint32_t id) : bounds(), m_id(id) {}
// /// Copy constructor.
// IndexResult(IndexResult const& other);
@@ -93,13 +93,13 @@
void SetIDs(IDVector& v) {ids = v;}
const liblas::Bounds GetBounds() const { return bounds; }
void SetBounds(const liblas::Bounds b) {bounds = b;}
- liblas::uint32_t GetID() const {return m_id;}
- void SetID(liblas::uint32_t v) {m_id = v;}
+ uint32_t GetID() const {return m_id;}
+ void SetID(uint32_t v) {m_id = v;}
private:
IDVector ids;
liblas::Bounds bounds;
- liblas::uint32_t m_id;
+ uint32_t m_id;
@@ -157,7 +157,7 @@
liblas::Bounds b(low[0], low[1], high[0],high[1]);
// SpatialIndex::Region* pr = new SpatialIndex::Region(low, high, 2);
// printf("Ids size: %d %.3f\n", ids.size(), pr->getLow(0));
- IndexResult result(static_cast<liblas::uint32_t>(id));
+ IndexResult result(static_cast<uint32_t>(id));
result.SetIDs(ids);
result.SetBounds(b);
m_results.push_back(result);
@@ -436,18 +436,18 @@
data.clear();
IDVector::const_iterator i;
- vector<liblas::uint8_t>::iterator pi;
+ vector<uint8_t>::iterator pi;
// list<SpatialIndex::id_type>::const_iterator i;
-// vector<liblas::uint8_t>::iterator pi;
+// vector<uint8_t>::iterator pi;
-// liblas::uint32_t block_id = result.GetID();
+// uint32_t block_id = result.GetID();
- std::vector<liblas::uint8_t> point_data;
+ std::vector<uint8_t> point_data;
for (i=ids.begin(); i!=ids.end(); ++i)
- liblas::uint32_t id = *i;
+ uint32_t id = *i;
// SpatialIndex::id_type id = *i;
bool doRead = reader->ReadPointAt(id);
@@ -536,7 +536,7 @@
b->pc_ids = (long*) malloc( size * sizeof(long));
b->block_ids = (long*) malloc ( size * sizeof(long));
b->num_points = (long*) malloc ( size * sizeof(long));
- b->blobs = (std::vector<liblas::uint8_t>**) malloc ( size * sizeof(std::vector<liblas::uint8_t>*));
+ b->blobs = (std::vector<uint8_t>**) malloc ( size * sizeof(std::vector<uint8_t>*));
b->locators =(OCILobLocator**) malloc( sizeof(OCILobLocator*) * size );
b->srids = (long*) malloc ( size * sizeof(long));
@@ -612,7 +612,7 @@
ostringstream oss;
IDVector const& ids = result.GetIDs();
liblas::Bounds b = result.GetBounds();
- liblas::uint32_t num_points =ids.size();
+ uint32_t num_points =ids.size();
ostringstream oss_geom;
ostringstream s_srid;
@@ -1257,7 +1257,7 @@
bool bUseSolidGeometry = false;
bool bUse3d = false;
- liblas::uint32_t nCapacity = 10000;
+ uint32_t nCapacity = 10000;
double dFillFactor = 0.99;
int srid = 0;
long precision = 8;
diff -r 646bcc90c951 -r a21a73d99c7c apps/las2ogr.cpp
--- a/apps/las2ogr.cpp Sat Jul 31 01:29:00 2010 +0100
+++ b/apps/las2ogr.cpp Fri Jul 30 19:38:24 2010 -0500
@@ -332,8 +332,8 @@
// Translation of points cloud to features set
- liblas::uint32_t i = 0;
- liblas::uint32_t const size = reader.GetHeader().GetPointRecordsCount();
+ uint32_t i = 0;
+ uint32_t const size = reader.GetHeader().GetPointRecordsCount();
std::cout << "Translating " << size << " points:\n";
diff -r 646bcc90c951 -r a21a73d99c7c src/lastransform.cpp
--- a/src/lastransform.cpp Sat Jul 31 01:29:00 2010 +0100
+++ b/src/lastransform.cpp Fri Jul 30 19:38:24 2010 -0500
@@ -80,7 +80,7 @@
msg << "Could not import input spatial reference for ReprojectionTransform:: "
<< CPLGetLastErrorMsg() << " code: " << result
<< "wkt: '" << inSRS.GetWKT() << "'";
- throw std::runtime_error(msg);
+ throw std::runtime_error(msg.str());
result = OSRSetFromUserInput(m_out_ref, outSRS.GetWKT().c_str());
More information about the Liblas-commits
