[Liblas-commits] hg: make an explicit example
liblas-commits at liblas.org
Mon Jun 28 11:54:48 EDT 2010
changeset e56d75d202d0 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=e56d75d202d0
summary: make an explicit example
diffstat:
schemas/LAS-example.dtd | 105 +++++++++++++++++++++++++++++++++++++++++++
schemas/las.xml | 2 +-
src/detail/reader/header.cpp | 74 ++++++++++++++++++-----------
src/lasvariablerecord.cpp | 10 ++-
4 files changed, 159 insertions(+), 32 deletions(-)
diffs (250 lines):
diff -r 6bdf6773f8de -r e56d75d202d0 schemas/LAS-example.dtd
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/schemas/LAS-example.dtd Mon Jun 28 10:54:42 2010 -0500
@@ -0,0 +1,105 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
+ xmlns:las="http://liblas.org/schemas/LAS/example"
+ elementFormDefault="qualified"
+ attributeFormDefault="unqualified"
+ targetNamespace="http://liblas.org/schemas/LAS/example" version="1.0">
+ <xs:simpleType name="sizeType">
+ <xs:annotation><xs:documentation>
+ The storage size type of the dimension.
+ </xs:documentation></xs:annotation>
+ <xs:restriction base="xs:string">
+ <xs:enumeration value="byte"></xs:enumeration>
+ <xs:enumeration value="bit"></xs:enumeration>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:simpleType name="interpretationType" >
+ Common interpretations of the data that may be used. This
+ type may be extended under the expectation that clients
+ know how to consume the data. In the case of string-like
+ data, use uint8_t (common byte) as the interpretation
+ and transform accordingly. Because nulls (or even
+ multi-byte strings) might be allowed, there are
+ no common string interpretations provided by defaut.
+ <xs:enumeration value="int8_t"></xs:enumeration>
+ <xs:enumeration value="uint8_t"></xs:enumeration>
+ <xs:enumeration value="int16_t"></xs:enumeration>
+ <xs:enumeration value="uint16_t"></xs:enumeration>
+ <xs:enumeration value="int32_t"></xs:enumeration>
+ <xs:enumeration value="uint32_t"></xs:enumeration>
+ <xs:enumeration value="int64_t"></xs:enumeration>
+ <xs:enumeration value="uint64_t"></xs:enumeration>
+ <xs:enumeration value="double"></xs:enumeration>
+ <xs:enumeration value="float"></xs:enumeration>
+ <xs:enumeration value="unknown"></xs:enumeration>
+ </xs:restriction>
+ </xs:simpleType>
+ <xs:complexType name="rangeType">
+ <xs:attribute name="units" type="las:interpretationType"></xs:attribute>
+ <xs:attribute name="value" type="xs:decimal"></xs:attribute>
+ </xs:complexType>
+ <xs:complexType name="dimensionType">
+ <xs:sequence>
+ <xs:element name="name" type="xs:string" />
+ <xs:element name="description" type="xs:string" minOccurs="0"/>
+ <xs:element name="position" type="xs:nonNegativeInteger" >
+ The dimension's position in the block of point data (counting from 0)
+ </xs:element>
+ <xs:element name="active" type="xs:boolean">
+ A dimension may have be holding its place in bytes but might not have actual
+ values that mean anything. This flag can be used to skip the dimension in
+ that case.
+ </xs:element>
+ <!--Specify the size and units of the dimension's storage-->
+ <xs:element name="size" type="xs:nonNegativeInteger"></xs:element>
+ <xs:element name="units" type="las:sizeType"></xs:element>
+ <xs:element name="interpretation" type="las:interpretationType">
+ This element describes how the data should be interpreted.
+ In the case of conflicting data, for example when then size is 2, the units "byte",
+ but the interpretation is "uint32_t", the size determines how much
+ precision is available.
+ </xs:element>
+ <xs:element name="minimum" type="las:rangeType" minOccurs="0">
+ The minimum value of this dimension.
+ </xs:element>
+ <xs:element name="maximum" type="las:rangeType">
+ The maximum value of this dimension.
+ </xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ <xs:element name="LASSchema" >
+ <xs:complexType>
+ <xs:sequence >
+ <xs:element name="dimension" type="las:dimesionType" minOccurs="1" maxOccurs="unbounded"></xs:element>
+ </xs:sequence>
+ </xs:complexType>
+ </xs:element>
+</xs:schema>
diff -r 6bdf6773f8de -r e56d75d202d0 schemas/las.xml
--- a/schemas/las.xml Fri Jun 25 12:27:30 2010 -0500
+++ b/schemas/las.xml Mon Jun 28 10:54:42 2010 -0500
@@ -1,7 +1,7 @@
<ns1:LASSchema xmlns:ns1="http://liblas.org/schemas/LAS/example"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
- xsi:schemaLocation="http://liblas.org/schemas/LAS/1.0 file:/Users/hobu/hg/liblas/schemas/LAS.xsd">
+ xsi:schemaLocation="http://liblas.org/schemas/LAS-example.dtd">
<ns1:dimension>
<name>X</name>
<description>
diff -r 6bdf6773f8de -r e56d75d202d0 src/detail/reader/header.cpp
--- a/src/detail/reader/header.cpp Fri Jun 25 12:27:30 2010 -0500
+++ b/src/detail/reader/header.cpp Mon Jun 28 10:54:42 2010 -0500
@@ -128,9 +128,11 @@
// 14. Header Size
// NOTE: Size of the stanard header block must always be 227 bytes
read_n(n2, m_ifs, sizeof(n2));
+ m_header.SetHeaderSize(n2);
// 15. Offset to data
read_n(n4, m_ifs, sizeof(n4));
if (n4 < m_header.GetHeaderSize())
std::ostringstream msg;
@@ -169,6 +171,14 @@
m_header.SetDataFormatId(liblas::ePointFormat3);
+ else if (n1 == liblas::ePointFormat4)
+ m_header.SetDataFormatId(liblas::ePointFormat4);
+ else if (n1 == liblas::ePointFormat5)
+ m_header.SetDataFormatId(liblas::ePointFormat5);
else
throw std::domain_error("invalid point data format");
@@ -217,6 +227,8 @@
m_header.SetMax(x1, y1, z1);
m_header.SetMin(x2, y2, z2);
// We're going to check the two bytes off the end of the header to
// see if they're pad bytes anyway. Some softwares, notably older QTModeler,
@@ -245,35 +257,41 @@
// If we're eof, we need to reset the state
if (m_ifs.eof())
m_ifs.clear();
- // Seek to the beginning
- m_ifs.seekg(0, std::ios::beg);
- std::ios::pos_type beginning = m_ifs.tellg();
- // Seek to the end
- m_ifs.seekg(0, std::ios::end);
- std::ios::pos_type end = m_ifs.tellg();
- std::ios::off_type size = end - beginning;
- // Figure out how many points we have
- std::ios::off_type count = (end - static_cast<std::ios::off_type>(m_header.GetDataOffset())) /
- static_cast<std::ios::off_type>(m_header.GetDataRecordLength());
- if ( m_header.GetPointRecordsCount() != static_cast<uint32_t>(count)) {
- std::ostringstream msg;
- msg << "The number of points in the header that was set "
- "by the software '" << m_header.GetSoftwareId() <<
- "' does not match the actual number of points in the file "
- "as determined by subtracting the data offset ("
- <<m_header.GetDataOffset() << ") from the file length ("
- << size << ") and dividing by the point record length("
- << m_header.GetDataRecordLength() << "). "
- " Actual number of points: " << count <<
- " Header-specified number of points: "
- << m_header.GetPointRecordsCount() ;
- throw std::runtime_error(msg.str());
+ // NOTE: This section is commented out because we now have to believe
+ // the header's GetPointRecordsCount due to the fact that the LAS 1.3
+ // specification no longer mandates that the end of the file is the end
+ // of the points. See http://trac.liblas.org/ticket/147 for more
+ // details on this issue and why the seek is a problem in the windows
+ // case.
+ // // Seek to the beginning
+ // m_ifs.seekg(0, std::ios::beg);
+ // std::ios::pos_type beginning = m_ifs.tellg();
+ // // Seek to the end
+ // m_ifs.seekg(0, std::ios::end);
+ // std::ios::pos_type end = m_ifs.tellg();
+ // std::ios::off_type size = end - beginning;
+ // // Figure out how many points we have
+ // std::ios::off_type count = (end - static_cast<std::ios::off_type>(m_header.GetDataOffset())) /
+ // static_cast<std::ios::off_type>(m_header.GetDataRecordLength());
+ // if ( m_header.GetPointRecordsCount() != static_cast<uint32_t>(count)) {
+ // std::ostringstream msg;
+ // msg << "The number of points in the header that was set "
+ // "by the software '" << m_header.GetSoftwareId() <<
+ // "' does not match the actual number of points in the file "
+ // "as determined by subtracting the data offset ("
+ // <<m_header.GetDataOffset() << ") from the file length ("
+ // << size << ") and dividing by the point record length("
+ // << m_header.GetDataRecordLength() << "). "
+ // " Actual number of points: " << count <<
+ // " Header-specified number of points: "
+ // << m_header.GetPointRecordsCount() ;
+ // throw std::runtime_error(msg.str());
// Seek to the data offset so we can start reading points
m_ifs.seekg(m_header.GetDataOffset());
diff -r 6bdf6773f8de -r e56d75d202d0 src/lasvariablerecord.cpp
--- a/src/lasvariablerecord.cpp Fri Jun 25 12:27:30 2010 -0500
+++ b/src/lasvariablerecord.cpp Mon Jun 28 10:54:42 2010 -0500
@@ -132,9 +132,13 @@
void VariableRecord::SetUserId(std::string const& v)
- if (v.size() > eUIDSize)
- throw std::invalid_argument("user id too long");
+ if (v.size() > eUIDSize) {
+ std::ostringstream output;
+ output << "User ID for VLR is too long: " << v.size() ;
+ std::string out(output.str());
+ throw std::invalid_argument(out);
std::fill(m_userId, m_userId + eUIDSize, 0);
std::strncpy(m_userId, v.c_str(), eUIDSize);
More information about the Liblas-commits
