[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Jun 28 13:12:03 EDT 2010
changeset 8d6f64ba6a6d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=8d6f64ba6a6d
summary: typo
changeset 171906ad655d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=171906ad655d
summary: rename
diffstat:
 schemas/LAS-example.dtd |  105 ------------------------------------------------
 schemas/LAS-example.xsd |  105 ++++++++++++++++++++++++++++++++++++++++++++++++
 2 files changed, 105 insertions(+), 105 deletions(-)
diffs (218 lines):
diff -r e56d75d202d0 -r 171906ad655d schemas/LAS-example.dtd
--- a/schemas/LAS-example.dtd	Mon Jun 28 10:54:42 2010 -0500
+++ /dev/null	Thu Jan 01 00:00:00 1970 +0000
@@ -1,105 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
-    xmlns:las="http://liblas.org/schemas/LAS/example"
-    elementFormDefault="qualified"
-    attributeFormDefault="unqualified"
-    targetNamespace="http://liblas.org/schemas/LAS/example" version="1.0">
-    <xs:simpleType name="sizeType">
-        <xs:annotation><xs:documentation>
-            The storage size type of the dimension.
-        </xs:documentation></xs:annotation>
-        <xs:restriction base="xs:string">
-            <xs:enumeration value="byte"></xs:enumeration>
-            <xs:enumeration value="bit"></xs:enumeration>
-        </xs:restriction>
-    </xs:simpleType>
-    <xs:simpleType name="interpretationType" >
-            Common interpretations of the data that may be used.  This
-            type may be extended under the expectation that clients
-            know how to consume the data.  In the case of string-like
-            data, use uint8_t (common byte) as the interpretation
-            and transform accordingly.  Because nulls (or even
-            multi-byte strings) might be allowed, there are
-            no common string interpretations provided by defaut.
-            <xs:enumeration value="int8_t"></xs:enumeration>
-            <xs:enumeration value="uint8_t"></xs:enumeration>
-            <xs:enumeration value="int16_t"></xs:enumeration>
-            <xs:enumeration value="uint16_t"></xs:enumeration>
-            <xs:enumeration value="int32_t"></xs:enumeration>
-            <xs:enumeration value="uint32_t"></xs:enumeration>
-            <xs:enumeration value="int64_t"></xs:enumeration>
-            <xs:enumeration value="uint64_t"></xs:enumeration>
-            <xs:enumeration value="double"></xs:enumeration>
-            <xs:enumeration value="float"></xs:enumeration>
-            <xs:enumeration value="unknown"></xs:enumeration>
-        </xs:restriction>
-    </xs:simpleType>
-    <xs:complexType name="rangeType">
-        <xs:attribute name="units" type="las:interpretationType"></xs:attribute>
-        <xs:attribute name="value" type="xs:decimal"></xs:attribute>
-    </xs:complexType>
-    <xs:complexType name="dimensionType">
-        <xs:sequence>
-            <xs:element name="name" type="xs:string"  />
-            <xs:element name="description" type="xs:string" minOccurs="0"/>
-            <xs:element name="position" type="xs:nonNegativeInteger" >
-                    The dimension's position in the block of point data (counting from 0)
-            </xs:element>
-            <xs:element name="active" type="xs:boolean">
-                    A dimension may have be holding its place in bytes but might not have actual
-                    values that mean anything.  This flag can be used to skip the dimension in
-                    that case.
-            </xs:element>
-            <!--Specify the size and units of the dimension's storage-->
-            <xs:element name="size" type="xs:nonNegativeInteger"></xs:element>
-            <xs:element name="units" type="las:sizeType"></xs:element>
-            <xs:element name="interpretation" type="las:interpretationType">
-                    This element describes how the data should be interpreted.
-                    In the case of conflicting data, for example when then size is 2, the units "byte",
-                    but the interpretation is "uint32_t", the size determines how much
-                    precision is available.
-            </xs:element>
-            <xs:element name="minimum" type="las:rangeType" minOccurs="0">
-                    The minimum value of this dimension.
-            </xs:element>
-            <xs:element name="maximum" type="las:rangeType">
-                    The maximum value of this dimension.
-            </xs:element>
-        </xs:sequence>
-    </xs:complexType>
-    <xs:element name="LASSchema" >
-        <xs:complexType>
-            <xs:sequence >
-                <xs:element name="dimension" type="las:dimesionType" minOccurs="1" maxOccurs="unbounded"></xs:element>
-            </xs:sequence>
-        </xs:complexType>
-    </xs:element>
-</xs:schema>
diff -r e56d75d202d0 -r 171906ad655d schemas/LAS-example.xsd
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/schemas/LAS-example.xsd	Mon Jun 28 12:11:55 2010 -0500
@@ -0,0 +1,105 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
+    xmlns:las="http://liblas.org/schemas/LAS/example"
+    elementFormDefault="qualified"
+    attributeFormDefault="unqualified"
+    targetNamespace="http://liblas.org/schemas/LAS/example" version="1.0">
+    <xs:simpleType name="sizeType">
+        <xs:annotation><xs:documentation>
+            The storage size type of the dimension.
+        </xs:documentation></xs:annotation>
+        <xs:restriction base="xs:string">
+            <xs:enumeration value="byte"></xs:enumeration>
+            <xs:enumeration value="bit"></xs:enumeration>
+        </xs:restriction>
+    </xs:simpleType>
+    <xs:simpleType name="interpretationType" >
+            Common interpretations of the data that may be used.  This
+            type may be extended under the expectation that clients
+            know how to consume the data.  In the case of string-like
+            data, use uint8_t (common byte) as the interpretation
+            and transform accordingly.  Because nulls (or even
+            multi-byte strings) might be allowed, there are
+            no common string interpretations provided by defaut.
+            <xs:enumeration value="int8_t"></xs:enumeration>
+            <xs:enumeration value="uint8_t"></xs:enumeration>
+            <xs:enumeration value="int16_t"></xs:enumeration>
+            <xs:enumeration value="uint16_t"></xs:enumeration>
+            <xs:enumeration value="int32_t"></xs:enumeration>
+            <xs:enumeration value="uint32_t"></xs:enumeration>
+            <xs:enumeration value="int64_t"></xs:enumeration>
+            <xs:enumeration value="uint64_t"></xs:enumeration>
+            <xs:enumeration value="double"></xs:enumeration>
+            <xs:enumeration value="float"></xs:enumeration>
+            <xs:enumeration value="unknown"></xs:enumeration>
+        </xs:restriction>
+    </xs:simpleType>
+    <xs:complexType name="rangeType">
+        <xs:attribute name="units" type="las:interpretationType"></xs:attribute>
+        <xs:attribute name="value" type="xs:decimal"></xs:attribute>
+    </xs:complexType>
+    <xs:complexType name="dimensionType">
+        <xs:sequence>
+            <xs:element name="name" type="xs:string"  />
+            <xs:element name="description" type="xs:string" minOccurs="0"/>
+            <xs:element name="position" type="xs:nonNegativeInteger" >
+                    The dimension's position in the block of point data (counting from 0)
+            </xs:element>
+            <xs:element name="active" type="xs:boolean">
+                    A dimension may have be holding its place in bytes but might not have actual
+                    values that mean anything.  This flag can be used to skip the dimension in
+                    that case.
+            </xs:element>
+            <!--Specify the size and units of the dimension's storage-->
+            <xs:element name="size" type="xs:nonNegativeInteger"></xs:element>
+            <xs:element name="units" type="las:sizeType"></xs:element>
+            <xs:element name="interpretation" type="las:interpretationType">
+                    This element describes how the data should be interpreted.
+                    In the case of conflicting data, for example when then size is 2, the units "byte",
+                    but the interpretation is "uint32_t", the size determines how much
+                    precision is available.
+            </xs:element>
+            <xs:element name="minimum" type="las:rangeType" minOccurs="0">
+                    The minimum value of this dimension.
+            </xs:element>
+            <xs:element name="maximum" type="las:rangeType">
+                    The maximum value of this dimension.
+            </xs:element>
+        </xs:sequence>
+    </xs:complexType>
+    <xs:element name="LASSchema" >
+        <xs:complexType>
+            <xs:sequence >
+                <xs:element name="dimension" type="las:dimensionType" minOccurs="1" maxOccurs="unbounded"></xs:element>
+            </xs:sequence>
+        </xs:complexType>
+    </xs:element>
+</xs:schema>
More information about the Liblas-commits mailing list
