[Liblas-commits] hg: don't provide << and >>, these are useless
liblas-commits at liblas.org
Wed Mar 17 12:22:50 EDT 2010
changeset 1c5cd5588c9e in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=1c5cd5588c9e
summary: don't provide << and >>, these are useless
diffstat:
src/lasvariablerecord.cpp | 49 -----------------------------------------------
1 files changed, 0 insertions(+), 49 deletions(-)
diffs (59 lines):
diff -r 24aa6508d530 -r 1c5cd5588c9e src/lasvariablerecord.cpp
--- a/src/lasvariablerecord.cpp Tue Mar 16 14:54:17 2010 -0600
+++ b/src/lasvariablerecord.cpp Wed Mar 17 11:17:08 2010 -0500
@@ -217,55 +217,6 @@
return static_cast<uint32_t>(sum);
-std::ostream& operator << ( std::ostream& out, VariableRecord const& d)
- // std::vector<uint8_t> data = d.GetData();
- std::streampos const begin = out.tellp();
- std::cout << "begin: " << begin << std::endl;
- std::cout << "Dumping " << d.GetRecordLength()
- <<" bytes out for VLR" << "Size is : " << d.GetData().size() <<std::endl;
- for (std::size_t i = 0; i < d.GetData().size(); ++i)
- // out << d.GetData()[i];
- out << &(d.GetData()[0]);
- std::streampos const end = out.tellp();
- std::cout << "end: " << end << std::endl;
- return out;
-std::istream& operator >> ( std::istream& in, VariableRecord& d)
- std::streampos const input_pos = in.tellg();
- in.seekg(0, std::ios::end);
- std::streampos const length = in.tellg();
- in.seekg(input_pos, std::ios::beg);
- std::cout << "Stream length: " << length << std::endl;
- // FIXME: If read_n throws, buffer will leak.
- // Replace with std::vector or any other RAII --mloskot
- std::size_t const buffersize = static_cast<std::size_t>(length);
- uint8_t* buffer = new uint8_t[buffersize];
- liblas::detail::read_n(buffer, in, length);
- // FIXME: This has probably already been properly swapped?
- // but I'm worried about the case where we have a
- // stream that is really some sort of zlib or bzip stream
- // and we don't know the orientation of the bytes - hobu
- LIBLAS_SWAP_BYTES_N(buffer, length);
- std::vector<uint8_t> data;
- for (std::size_t i = 0; i < buffersize; ++i)
- data.push_back(buffer[i]);
- delete buffer;
- d.SetData(data);
- return in;
} // namespace liblas
More information about the Liblas-commits
