[Liblas-commits] hg: add schemas to source control
liblas-commits at liblas.org
Wed Mar 17 16:37:07 EDT 2010
changeset 864b87e78b9d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=864b87e78b9d
summary: add schemas to source control
diffstat:
README | 21 +++-
apps/las2oci.cpp | 157 ++++++++++++++++++++------------
apps/oci_wrapper.cpp | 24 ++++-
apps/oci_wrapper.h | 2 +
schemas/LAS.xsd | 101 +++++++++++++++++++++
schemas/las.xml | 203 +++++++++++++++++++++++++++++++++++++++++++
src/detail/writer/header.cpp | 3 -
7 files changed, 441 insertions(+), 70 deletions(-)
diffs (truncated from 684 to 300 lines):
diff -r 1c5cd5588c9e -r 864b87e78b9d README
--- a/README Wed Mar 17 11:17:08 2010 -0500
+++ b/README Wed Mar 17 15:31:17 2010 -0500
@@ -1,4 +1,5 @@
libLAS - LAS 1.0/1.1/1.2 ASPRS LiDAR data translation toolset
@@ -7,13 +8,20 @@
and as intermediate processing storage by some `LiDAR`_-related applications.
libLAS is available under the terms of the `BSD License`_. It builds on work
-by `Martin Isenburg and Jonathan Shewchuk`_ of the University of North
-Carolina in their `LAStools`_ project by replacing the base C++ library
+by `Martin Isenburg and Jonathan Shewchuk`_ of LLNL/UC Berkeley in their `LAStools`_
+project by replacing the base C++ library
with new development and porting Martin's tools this new code.
libLAS' initial development was supported by the `IGSB`_ of the Iowa DNR
for use in its state-wide `LIDAR`_ project.
+.. image:: http://2010.foss4g.org/images/logo_125x125.jpg
+ :height: 125px
+ :width: 125px
+ :alt: FOSS4G 2010 in Barcelona, Spain
+ :align: right
+ :target: http://2010.foss4g.org/
Download
@@ -67,12 +75,15 @@
The LAS Format Standard is maintained by `ASPRS Standards Committee`_. LAS
format standard documents are available in PDF format:
-* `LAS 1.3 Format Standard`_ (2009-07-14)
* `LAS 1.2 Format Standard`_ (2008-09-02)
* `LAS 1.1 Format Standard`_ (2005-05-07)
* `LAS 1.0 Format Standard`_ (2003-05-09)
* `LAS permutation matrix`_
+Installing liblas Python bindings using setuptools
+A quick `Python howto`_ for installing Python bindings and the Win32 liblas package
License
@@ -189,7 +200,6 @@
.. _`LAStools`: http://www.cs.unc.edu/~isenburg/lastools/
.. _`Martin Isenburg and Jonathan Shewchuk`: http://www.cs.unc.edu/~isenburg/lastools/
.. _`LAS Format`: http://www.lasformat.org/
-.. _`LAS 1.3 Format Standard`: http://liblas.org/raw-attachment/wiki/WikiStart/asprs_las_format_v13.pdf
.. _`LAS 1.2 Format Standard`: http://liblas.org/raw-attachment/wiki/WikiStart/asprs_las_format_v12.pdf
.. _`LAS 1.1 Format Standard`: http://liblas.org/raw-attachment/wiki/WikiStart/asprs_las_format_v11.pdf
.. _`LAS 1.0 Format Standard`: http://liblas.org/raw-attachment/wiki/WikiStart/asprs_las_format_v10.pdf
@@ -226,3 +236,4 @@
.. _`FOSS4G 2008`: http://liblas.org/raw-attachment/wiki/WikiStart/liblas_foss4g_2008.pdf
.. _`ASPRS Workshop Demo`: http://liblas.org/raw-attachment/wiki/WikiStart/ASPRS-Workshop-NOAA-Demo.pdf
.. _`vertical coordinate systems`: http://liblas.org/wiki/VerticalCS
+.. _`Python howto`: http://liblas.org/wiki/PythonHowTo
\ No newline at end of file
diff -r 1c5cd5588c9e -r 864b87e78b9d apps/las2oci.cpp
--- a/apps/las2oci.cpp Wed Mar 17 11:17:08 2010 -0500
+++ b/apps/las2oci.cpp Wed Mar 17 15:31:17 2010 -0500
@@ -44,12 +44,16 @@
long* pc_ids;
long* block_ids;
long* num_points;
+ OCILobLocator** locators; // =(OCILobLocator**) VSIMalloc( sizeof(OCILobLocator*) * 1 );
std::vector<liblas::uint8_t>** blobs;
long* srids;
long* gtypes;
OCIArray** element_arrays;
OCIArray** coordinate_arrays;
+ long size;
} blocks;
@@ -504,6 +508,7 @@
b->block_ids = (long*) malloc ( size * sizeof(long));
b->num_points = (long*) malloc ( size * sizeof(long));
b->blobs = (std::vector<liblas::uint8_t>**) malloc ( size * sizeof(std::vector<liblas::uint8_t>*));
+ b->locators =(OCILobLocator**) malloc( sizeof(OCILobLocator*) * size );
b->srids = (long*) malloc ( size * sizeof(long));
b->gtypes = (long*) malloc ( size * sizeof(long));
@@ -511,10 +516,13 @@
b->element_arrays = (OCIArray**) malloc ( size * sizeof(OCIArray*));
b->coordinate_arrays = (OCIArray**) malloc ( size * sizeof(OCIArray*));
+ b->size = size;
return b;
-bool FillBlock( OWConnection* connection,
+bool FillBlocks( OWConnection* connection,
OWStatement* statement,
const LASQueryResult& result,
liblas::Reader* reader,
@@ -532,40 +540,39 @@
list<SpatialIndex::id_type> const& ids = result.GetIDs();
- // TODO: This probably is a memory leak if the gotdata == false --mloskot
+ b->pc_ids[index] = pc_id;
+ b->srids[index] = (long)srid;
+ b->block_ids[index] = result.GetID();
+ b->num_points[index] = (long)ids.size();
std::vector<liblas::uint8_t>* blob = new std::vector<liblas::uint8_t>;
- // b->pc_ids[index] = pc_id;
- printf("Index: %d\n", index);
- b->srids[index] = (long)srid;
- // b->block_ids[index] = result.GetID();
- // b->num_points[index] = (long)ids.size();
+ bool gotdata = GetResultData(result, reader, *blob, nDimensions);
+ if (! gotdata) throw std::runtime_error("unable to fetch point data byte array");
- // std::vector<liblas::uint8_t>* blob = new std::vector<liblas::uint8_t>;
+ b->blobs[index] = blob;
+ // // FIXME: null srids not supported
+ b->srids[index] = srid;
+ b->gtypes[index] = gtype;
+ OCIArray* sdo_elem_info=0;
+ connection->CreateType(&sdo_elem_info, connection->GetElemInfoType());
+ SetElements(statement, sdo_elem_info, bUseSolidGeometry);
+ b->element_arrays[index] = sdo_elem_info;
- // bool gotdata = GetResultData(result, reader, *blob, nDimensions);
- // if (! gotdata) throw std::runtime_error("unable to fetch point data byte array");
- // b->blobs[index] = blob;
- // // FIXME: null srids not supported
- // b->srids[index] = srid;
- // b->gtypes[index] = gtype;
+ OCIArray* sdo_ordinates=0;
+ connection->CreateType(&sdo_ordinates, connection->GetOrdinateType());
- // OCIArray* sdo_elem_info=0;
- // connection->CreateType(&sdo_elem_info, connection->GetElemInfoType());
- // SetElements(statement, sdo_elem_info, bUseSolidGeometry);
- // b->element_arrays[index] = sdo_elem_info;
- // OCIArray* sdo_ordinates=0;
- // connection->CreateType(&sdo_ordinates, connection->GetOrdinateType());
- // extent* e = GetExtent(result.GetBounds(), bUse3d);
- // SetOrdinates(statement, sdo_ordinates, e);
- // b->coordinate_arrays[index] = sdo_ordinates;
+ extent* e = GetExtent(result.GetBounds(), bUse3d);
+ SetOrdinates(statement, sdo_ordinates, e);
+ b->coordinate_arrays[index] = sdo_ordinates;
return true;
@@ -591,7 +598,7 @@
return gtype;
-bool BindBlock(OWStatement* statement, blocks* b, OCILobLocator** locator, long commit_interval)
+bool BindBlock(OWStatement* statement, blocks* b, long index)
// oss << "INSERT INTO "<< table_name <<
// "(OBJ_ID, BLK_ID, NUM_POINTS, POINTS, "
@@ -609,10 +616,10 @@
statement->Bind( b->num_points);
// :4
- statement->Define( locator, (int)commit_interval );
+ statement->Define( b->locators, (int)b->size );
long max_size = 0;
- for (int i = 0; i < commit_interval; i++) {
+ for (int i = 0; i < b->size; i++) {
max_size = std::max(max_size, (long)b->blobs[i]->size());
@@ -790,42 +797,70 @@
statement = con->CreateStatement(oss.str().c_str());
long j = 0;
bool inserted = false;
+ std::vector<LASQueryResult> results_vec = std::vector<LASQueryResult>();
+ for (i = results.begin(); i != results.end(); i++) {
+ results_vec.push_back(*i);
+ long total_blocks = results.size();
+ long blocks_written = 0;
+ long blocks_left= 0;
+ long to_fill = 0;
+ for (j = 0; j < total_blocks; j+=commit_interval) {
+ blocks_left = total_blocks - blocks_written;
+ if (blocks_left < commit_interval) {
+ // only fill to this level
+ to_fill = blocks_left;
+ } else {
+ to_fill = commit_interval;
+ for (int t = 0; t< to_fill; t++) {
+ FillBlocks( con,
+ statement,
+ results_vec[t],
+ reader2,
+ b,
+ t,
+ srid,
+ pc_id,
+ GetGType(bUse3d, bUseSolidGeometry),
+ bUseSolidGeometry,
+ bUse3d,
+ nDimensions
- for (int t = 0; t < commit_interval; t++) {
- FillBlock( con,
- statement,
- *i,
- reader2,
- b,
- t,
- srid,
- pc_id,
- GetGType(bUse3d, bUseSolidGeometry),
- bUseSolidGeometry,
- bUse3d,
- nDimensions
+ t++;
+ blocks_written = blocks_written + to_fill;
- for (i=results.begin(); i!=results.end(); i++)
- inserted = InsertBlock(con,
- *i,
- b,
- j,
- srid,
- reader2,
- table_name.c_str(),
- precision,
- pc_id,
- bUse3d);
- j++;
+ // for (i=results.begin(); i!=results.end(); i++)
+ // inserted = InsertBlock(con,
+ // *i,
+ // b,
+ // j,
+ // srid,
+ // reader2,
+ // table_name.c_str(),
+ // precision,
+ // pc_id,
+ // bUseSolidGeometry,
+ // bUse3d);
+ // j++;
return inserted;
diff -r 1c5cd5588c9e -r 864b87e78b9d apps/oci_wrapper.cpp
--- a/apps/oci_wrapper.cpp Wed Mar 17 11:17:08 2010 -0500
+++ b/apps/oci_wrapper.cpp Wed Mar 17 15:31:17 2010 -0500
More information about the Liblas-commits
