[Liblas-commits] hg: update schemas
liblas-commits at liblas.org
Wed Mar 17 16:48:36 EDT 2010
changeset a7e50a69311b in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a7e50a69311b
summary: update schemas
diffstat:
schemas/LAS.xsd | 10 +++++++---
schemas/las.xml | 50 +++++++++++++++++++++++++-------------------------
2 files changed, 32 insertions(+), 28 deletions(-)
diffs (169 lines):
diff -r 864b87e78b9d -r a7e50a69311b schemas/LAS.xsd
--- a/schemas/LAS.xsd Wed Mar 17 15:31:17 2010 -0500
+++ b/schemas/LAS.xsd Wed Mar 17 15:42:56 2010 -0500
@@ -1,5 +1,9 @@
-<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:las="http://liblas.org/schemas/LAS/example" attributeFormDefault="qualified" targetNamespace="http://liblas.org/schemas/LAS/example" version="1.0">
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
+ xmlns:las="http://liblas.org/schemas/LAS/example"
+ elementFormDefault="qualified"
+ attributeFormDefault="unqualified"
+ targetNamespace="http://liblas.org/schemas/LAS/example" version="1.0">
<xs:simpleType name="sizeType">
<xs:annotation><xs:documentation>
@@ -41,10 +45,10 @@
<xs:attribute name="value" type="xs:decimal"></xs:attribute>
</xs:complexType>
- <xs:complexType name="dimesionType">
+ <xs:complexType name="dimensionType">
<xs:sequence>
<xs:element name="name" type="xs:string" />
- <xs:element name="description" type="xs:string" nillable="true"/>
+ <xs:element name="description" type="xs:string" minOccurs="0"/>
<xs:element name="position" type="xs:nonNegativeInteger" >
diff -r 864b87e78b9d -r a7e50a69311b schemas/las.xml
--- a/schemas/las.xml Wed Mar 17 15:31:17 2010 -0500
+++ b/schemas/las.xml Wed Mar 17 15:42:56 2010 -0500
@@ -1,8 +1,8 @@
<ns1:LASSchema xmlns:ns1="http://liblas.org/schemas/LAS/example"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
- xsi:schemaLocation="http://liblas.org/schemas/LAS/1.0 file:/Users/hobu/Desktop/LAS.xsd">
- <dimension>
+ xsi:schemaLocation="http://liblas.org/schemas/LAS/1.0 file:/Users/hobu/hg/liblas/schemas/LAS.xsd">
+ <ns1:dimension>
<name>X</name>
<description>
x coordinate as a long integer. You must use the scale and
@@ -15,8 +15,8 @@
<interpretation>uint32_t</interpretation>
<minimum ns1:units="double" ns1:value="-131600417.982"/>
<maximum ns1:units="double" ns1:value="404506682.749"/>
- </dimension>
- <dimension>
+ </ns1:dimension>
+ <ns1:dimension>
<name>Y</name>
<description>
y coordinate as a long integer. You must use the scale and
@@ -29,8 +29,8 @@
<minimum ns1:units="double" ns1:value="-586874.0"/>
<maximum ns1:units="double" ns1:value="123456789101112.9876"/>
- </dimension>
- <dimension>
+ </ns1:dimension>
+ <ns1:dimension>
<name>Z</name>
<description>
z coordinate as a long integer. You must use the scale and
@@ -43,8 +43,8 @@
<minimum ns1:units="double" ns1:value="0.00"/>
<maximum ns1:units="double" ns1:value="2512.26"/>
- </dimension>
- <dimension>
+ </ns1:dimension>
+ <ns1:dimension>
<name>Intensity</name>
<description>
The intensity value is the integer representation of the pulse
@@ -58,8 +58,8 @@
<interpretation>uint16_t</interpretation>
<minimum ns1:units="uint16_t" ns1:value="0"/>
<maximum ns1:units="uint16_t" ns1:value="14224"/>
- </dimension>
- <dimension>
+ </ns1:dimension>
+ <ns1:dimension>
<name>Return number</name>
<description>
Return Number: The Return Number is the pulse return number for
@@ -75,8 +75,8 @@
<interpretation>unknown</interpretation>
<maximum ns1:units="uint16_t" ns1:value="5"/>
- </dimension>
- <dimension>
+ </ns1:dimension>
+ <ns1:dimension>
<name>Number of Returns</name>
<description>
Number of Returns (for this emitted pulse): The Number of Returns
@@ -91,8 +91,8 @@
- </dimension>
- <dimension>
+ </ns1:dimension>
+ <ns1:dimension>
<name>Scan direction</name>
<description>
The Scan Direction Flag denotes the direction at which the
@@ -109,8 +109,8 @@
<minimum ns1:units="uint8_t" ns1:value="0"/>
<maximum ns1:units="uint8_t" ns1:value="1"/>
- </dimension>
- <dimension>
+ <ns1:dimension>
<name>Flight Line Edge</name>
<description>
The Edge of Flight Line data bit has a value of 1 only when
@@ -124,8 +124,8 @@
<minimum ns1:units="int8_t" ns1:value="0"/>
<maximum ns1:units="int8_t" ns1:value="1"/>
- </dimension>
- <dimension>
+ <ns1:dimension>
<name>Classification</name>
<description>
Classification in LAS 1.0 was essentially user defined and optional.
@@ -144,8 +144,8 @@
<interpretation>uint8_t</interpretation>
<minimum/>
<maximum/>
- </dimension>
- <dimension>
+ <ns1:dimension>
<name>Scan Angle</name>
<description>
The Scan Angle Rank is a signed one-byte number with a
@@ -165,8 +165,8 @@
<minimum ns1:units="int8_t" ns1:value="-90"/>
<maximum ns1:units="int8_t" ns1:value="90"/>
- </dimension>
- <dimension>
+ </ns1:dimension>
+ <ns1:dimension>
<name>User data</name>
<description>
This field may be used at the userâs discretion.
@@ -178,8 +178,8 @@
<minimum/>
<maximum/>
- </dimension>
- <dimension>
+ </ns1:dimension>
+ <ns1:dimension>
<name>Point Source ID </name>
<description>
This value indicates the file from which this point originated.
@@ -199,5 +199,5 @@
<minimum/>
<maximum/>
- </dimension>
+ </ns1:dimension>
</ns1:LASSchema>
More information about the Liblas-commits
