[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Mon Mar 22 14:28:01 EDT 2010
changeset 325df9d68f4d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=325df9d68f4d
summary: add install_name to liblas_c target for APPLE
changeset e8ee49101fc0 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=e8ee49101fc0
summary: that last PointFormat patch was stupid :)
diffstat:
include/liblas/detail/reader/point.hpp | 1 -
include/liblas/detail/writer/point.hpp | 1 -
include/liblas/lasformat.hpp | 1 +
include/liblas/lasheader.hpp | 2 +
src/CMakeLists.txt | 12 +++++++
src/detail/reader/point.cpp | 18 +++++-----
src/detail/writer/point.cpp | 7 +--
src/lasformat.cpp | 11 ++++++
src/lasheader.cpp | 55 ++++++++++++++++++++-------------
9 files changed, 71 insertions(+), 37 deletions(-)
diffs (truncated from 301 to 300 lines):
diff -r 0a681a3a232a -r e8ee49101fc0 include/liblas/detail/reader/point.hpp
--- a/include/liblas/detail/reader/point.hpp Sun Mar 21 21:56:56 2010 -0500
+++ b/include/liblas/detail/reader/point.hpp Mon Mar 22 13:22:25 2010 -0500
@@ -93,7 +93,6 @@
const liblas::Header& m_header;
liblas::Point m_point;
OGRCoordinateTransformationH m_transform;
- const liblas::PointFormat& m_format;
void project();
diff -r 0a681a3a232a -r e8ee49101fc0 include/liblas/detail/writer/point.hpp
--- a/include/liblas/detail/writer/point.hpp Sun Mar 21 21:56:56 2010 -0500
+++ b/include/liblas/detail/writer/point.hpp Mon Mar 22 13:22:25 2010 -0500
@@ -100,7 +100,6 @@
PointRecord m_record;
void project();
void setup();
diff -r 0a681a3a232a -r e8ee49101fc0 include/liblas/lasformat.hpp
--- a/include/liblas/lasformat.hpp Sun Mar 21 21:56:56 2010 -0500
+++ b/include/liblas/lasformat.hpp Mon Mar 22 13:22:25 2010 -0500
@@ -67,6 +67,7 @@
bool bTime);
PointFormat& operator=(PointFormat const& rhs);
PointFormat(PointFormat const& other);
+ PointFormat();
~PointFormat() {};
diff -r 0a681a3a232a -r e8ee49101fc0 include/liblas/lasheader.hpp
--- a/include/liblas/lasheader.hpp Sun Mar 21 21:56:56 2010 -0500
+++ b/include/liblas/lasheader.hpp Mon Mar 22 13:22:25 2010 -0500
@@ -50,6 +50,7 @@
#include <liblas/liblas.hpp>
#include <liblas/lasvariablerecord.hpp>
#include <liblas/lasspatialreference.hpp>
+#include <liblas/lasformat.hpp>
#include <liblas/guid.hpp>
//std
@@ -376,6 +377,7 @@
PointExtents m_extents;
std::vector<VariableRecord> m_vlrs;
SpatialReference m_srs;
+ PointFormat m_format;
} // namespace liblas
diff -r 0a681a3a232a -r e8ee49101fc0 src/CMakeLists.txt
--- a/src/CMakeLists.txt Sun Mar 21 21:56:56 2010 -0500
+++ b/src/CMakeLists.txt Mon Mar 22 13:22:25 2010 -0500
@@ -128,9 +128,21 @@
# Static libLAS C++ library
add_library(${LIBLAS_LIB_NAME} STATIC ${LIBLAS_SOURCES})
# Shared libLAS C library
add_library(${LIBLAS_C_LIB_NAME} SHARED ${LIBLAS_C_SOURCES})
+if (APPLE)
+ set_target_properties(
+ ${LIBLAS_C_LIB_NAME}
+ PROPERTIES
+ INSTALL_NAME_DIR "${CMAKE_INSTALL_PREFIX}/lib"
+endif(APPLE)
target_link_libraries(${LIBLAS_C_LIB_NAME}
${LIBLAS_LIB_NAME}
${ZLIB_LIBRARIES}
diff -r 0a681a3a232a -r e8ee49101fc0 src/detail/reader/point.cpp
--- a/src/detail/reader/point.cpp Sun Mar 21 21:56:56 2010 -0500
+++ b/src/detail/reader/point.cpp Mon Mar 22 13:22:25 2010 -0500
@@ -54,7 +54,7 @@
Point::Point(std::istream& ifs, const liblas::Header& header) :
- m_ifs(ifs), m_header(header), m_point(liblas::Point()), m_transform(0), m_format(header.GetPointFormat())
+ m_ifs(ifs), m_header(header), m_point(liblas::Point()), m_transform(0)
setup();
@@ -62,7 +62,7 @@
Point::Point( std::istream& ifs,
const liblas::Header& header,
OGRCoordinateTransformationH transform) :
- m_ifs(ifs), m_header(header), m_point(liblas::Point()), m_transform(transform), m_format(header.GetPointFormat())
+ m_ifs(ifs), m_header(header), m_point(liblas::Point()), m_transform(transform)
setup();
@@ -106,14 +106,14 @@
// Reader::FillPoint(record, m_point, m_header);
m_point.SetCoordinates(m_header, m_point.GetX(), m_point.GetY(), m_point.GetZ());
- if (m_format.HasTime())
+ if (m_header.GetPointFormat().HasTime())
detail::read_n(gpst, m_ifs, sizeof(double));
m_point.SetTime(gpst);
bytesread += sizeof(double);
- if (m_format.HasColor())
+ if (m_header.GetPointFormat().HasColor())
detail::read_n(red, m_ifs, sizeof(uint16_t));
detail::read_n(green, m_ifs, sizeof(uint16_t));
@@ -125,7 +125,7 @@
bytesread += 3 * sizeof(uint16_t);
} else {
@@ -137,17 +137,17 @@
- if (bytesread != m_format.GetByteSize()) {
+ if (bytesread != m_header.GetPointFormat().GetByteSize()) {
std::ostringstream msg;
msg << "The number of bytes that were read ("<< bytesread <<") does not "
"match the number of bytes the point's format "
"says it should have (" <<
- m_format.GetByteSize() << ")";
+ m_header.GetPointFormat().GetByteSize() << ")";
throw std::runtime_error(msg.str());
- if (m_format.GetByteSize() != m_header.GetDataRecordLength())
+ if (m_header.GetPointFormat().GetByteSize() != m_header.GetDataRecordLength())
std::size_t bytesleft = m_header.GetDataRecordLength() - bytesread;
diff -r 0a681a3a232a -r e8ee49101fc0 src/detail/writer/point.cpp
--- a/src/detail/writer/point.cpp Sun Mar 21 21:56:56 2010 -0500
+++ b/src/detail/writer/point.cpp Mon Mar 22 13:22:25 2010 -0500
@@ -62,8 +62,7 @@
m_ofs(ofs),
m_header(header),
- m_transform(0),
- m_format(header.GetPointFormat())
+ m_transform(0)
setup();
@@ -72,7 +71,7 @@
liblas::uint32_t& count,
OGRCoordinateTransformationH transform) : Base(ofs, count),
- m_ofs(ofs), m_header(header), m_point(liblas::Point()), m_transform(transform), m_format(header.GetPointFormat())
+ m_ofs(ofs), m_header(header), m_point(liblas::Point()), m_transform(transform)
setup();
@@ -142,7 +141,7 @@
// write in our extra data that the user set on the
// point up to the header's specified DataRecordLength
- if (m_format.GetByteSize() != m_header.GetDataRecordLength()) {
+ if (m_header.GetPointFormat().GetByteSize() != m_header.GetDataRecordLength()) {
std::vector<uint8_t> const& data = point.GetExtraData();
std::streamsize const size = static_cast<std::streamsize>(m_header.GetDataRecordLength() - data.size());
diff -r 0a681a3a232a -r e8ee49101fc0 src/lasformat.cpp
--- a/src/lasformat.cpp Sun Mar 21 21:56:56 2010 -0500
+++ b/src/lasformat.cpp Mon Mar 22 13:22:25 2010 -0500
@@ -84,6 +84,17 @@
updatesize();
+PointFormat::PointFormat( ) :
+ m_size(0),
+ m_versionminor(2),
+ m_versionmajor(1),
+ m_hasColor(false),
+ m_hasTime(false)
+ updatesize();
// copy constructor
PointFormat::PointFormat(PointFormat const& other) :
m_size(other.m_size),
diff -r 0a681a3a232a -r e8ee49101fc0 src/lasheader.cpp
--- a/src/lasheader.cpp Sun Mar 21 21:56:56 2010 -0500
+++ b/src/lasheader.cpp Mon Mar 22 13:22:25 2010 -0500
@@ -90,7 +90,8 @@
m_scales(other.m_scales),
m_offsets(other.m_offsets),
m_extents(other.m_extents),
- m_srs(other.m_srs)
+ m_srs(other.m_srs),
+ m_format(other.m_format)
void* p = 0;
@@ -147,6 +148,7 @@
m_offsets = rhs.m_offsets;
m_extents = rhs.m_extents;
m_srs = rhs.m_srs;
+ m_format = rhs.m_format;
return *this;
@@ -586,6 +588,8 @@
// Zero scale value is useless, so we need to use a small value.
SetScale(0.01, 0.01, 0.01);
+ SetPointFormat(m_format);
void Header::ClearGeoKeyVLRs()
@@ -667,6 +671,7 @@
return m_srs;
void Header::SetSRS(SpatialReference& srs)
m_srs = srs;
@@ -674,26 +679,27 @@
PointFormat Header::GetPointFormat() const
- bool bHasColor(false);
- bool bHasTime(false);
- if (GetDataFormatId() == liblas::ePointFormat3) {
- bHasColor = true;
- bHasTime = true;
- } else if (GetDataFormatId() == liblas::ePointFormat2) {
- bHasColor = true;
- bHasTime = false;
- } else if (GetDataFormatId() == liblas::ePointFormat1) {
- bHasColor = false;
- bHasTime = true;
+ // bool bHasColor(false);
+ // bool bHasTime(false);
+ // if (GetDataFormatId() == liblas::ePointFormat3) {
+ // bHasColor = true;
+ // bHasTime = true;
+ // } else if (GetDataFormatId() == liblas::ePointFormat2) {
+ // bHasTime = false;
+ // } else if (GetDataFormatId() == liblas::ePointFormat1) {
+ // bHasColor = false;
- return PointFormat( GetVersionMajor(),
- GetVersionMinor(),
- GetDataRecordLength(),
- bHasColor,
- bHasTime);
+ return m_format;
+ // return PointFormat( GetVersionMajor(),
+ // GetVersionMinor(),
+ // GetDataRecordLength(),
+ // bHasColor,
+ // bHasTime);
void Header::SetPointFormat(const PointFormat& format)
@@ -722,10 +728,15 @@
SetDataFormatId(liblas::ePointFormat1);
SetDataRecordLength(std::max( static_cast<uint16_t>(ePointSize1),
static_cast<uint16_t>(format.GetByteSize())));
- } else
+ } else {
SetDataFormatId(liblas::ePointFormat0);
SetDataRecordLength(std::max( static_cast<uint16_t>(ePointSize0),
+ m_format = format;
More information about the Liblas-commits
