[Liblas-commits] hg: 4 new changesets
liblas-commits at liblas.org
Tue Mar 23 23:12:06 EDT 2010
changeset 971f707cd156 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=971f707cd156
summary: cache reference to PointFormat
changeset 574098e37379 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=574098e37379
summary: whitespace normalization
changeset d7a3fc6e99bc in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d7a3fc6e99bc
summary: ignore more stuff
changeset 0b95a35c7f8f in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0b95a35c7f8f
summary: copy README to README.txt to satisfy CPack
diffstat:
.hgignore | 3 +++
CMakeLists.txt | 3 +++
cmake/modules/BuildOSGeo4W.cmake | 24 ------------------------
include/liblas/detail/reader/point.hpp | 2 --
src/detail/reader/point.cpp | 14 ++++++++------
5 files changed, 14 insertions(+), 32 deletions(-)
diffs (126 lines):
diff -r e8ee49101fc0 -r 0b95a35c7f8f .hgignore
--- a/.hgignore Mon Mar 22 13:22:25 2010 -0500
+++ b/.hgignore Tue Mar 23 22:06:24 2010 -0500
@@ -72,3 +72,6 @@
test/data/*.dat
test/data/*.idx
.dirstamp
+CMakeScripts
+libLAS.xcodeproj
+build/libLAS.build
diff -r e8ee49101fc0 -r 0b95a35c7f8f CMakeLists.txt
--- a/CMakeLists.txt Mon Mar 22 13:22:25 2010 -0500
+++ b/CMakeLists.txt Tue Mar 23 22:06:24 2010 -0500
@@ -70,6 +70,9 @@
# Output directory in which to build ARCHIVE target files.
set(CMAKE_ARCHIVE_OUTPUT_DIRECTORY ${LIBLAS_BUILD_OUTPUT_DIRECTORY})
+file(READ "README" README )
+file(WRITE "README.txt" "${README}")
# Platform and compiler specific settings
diff -r e8ee49101fc0 -r 0b95a35c7f8f cmake/modules/BuildOSGeo4W.cmake
--- a/cmake/modules/BuildOSGeo4W.cmake Mon Mar 22 13:22:25 2010 -0500
+++ b/cmake/modules/BuildOSGeo4W.cmake Tue Mar 23 22:06:24 2010 -0500
@@ -4,28 +4,4 @@
-if(WIN32)
- set(DEFAULT_LIB_SUBDIR lib)
- set(DEFAULT_DATA_SUBDIR .)
- set(DEFAULT_INCLUDE_SUBDIR include)
- if (MSVC)
- set(DEFAULT_BIN_SUBDIR bin)
- else()
- set(DEFAULT_BIN_SUBDIR .)
- endif()
-else()
- # Common locatoins for Unix and Mac OS X
- set(DEFAULT_DATA_SUBDIR share/liblas)
-endif()
- ADD_CUSTOM_COMMAND(
- OUTPUT ${CMAKE_CURRENT_SOURCE_DIR}/README.txt
- COMMAND ${CMAKE_COMMAND} xcopy /y /r/d /f ${CMAKE_CURRENT_SOURCE_DIR}/README ${CMAKE_CURRENT_SOURCE_DIR}/README.txt
- DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/README
-ADD_CUSTOM_TARGET(generate_readme DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/README.txt)
\ No newline at end of file
diff -r e8ee49101fc0 -r 0b95a35c7f8f include/liblas/detail/reader/point.hpp
--- a/include/liblas/detail/reader/point.hpp Mon Mar 22 13:22:25 2010 -0500
+++ b/include/liblas/detail/reader/point.hpp Tue Mar 23 22:06:24 2010 -0500
@@ -87,8 +87,6 @@
Point(Point const& other);
Point& operator=(Point const& rhs);
std::istream& m_ifs;
const liblas::Header& m_header;
liblas::Point m_point;
diff -r e8ee49101fc0 -r 0b95a35c7f8f src/detail/reader/point.cpp
--- a/src/detail/reader/point.cpp Mon Mar 22 13:22:25 2010 -0500
+++ b/src/detail/reader/point.cpp Tue Mar 23 22:06:24 2010 -0500
@@ -92,6 +92,8 @@
// TODO: Replace with compile-time assert
assert(liblas::ePointSize0 == sizeof(record));
+ const PointFormat& format = m_header.GetPointFormat();
try
detail::read_n(record, m_ifs, sizeof(PointRecord));
@@ -106,14 +108,14 @@
// Reader::FillPoint(record, m_point, m_header);
m_point.SetCoordinates(m_header, m_point.GetX(), m_point.GetY(), m_point.GetZ());
- if (m_header.GetPointFormat().HasTime())
+ if (format.HasTime())
detail::read_n(gpst, m_ifs, sizeof(double));
m_point.SetTime(gpst);
bytesread += sizeof(double);
- if (m_header.GetPointFormat().HasColor())
+ if (format.HasColor())
detail::read_n(red, m_ifs, sizeof(uint16_t));
detail::read_n(green, m_ifs, sizeof(uint16_t));
@@ -125,7 +127,7 @@
bytesread += 3 * sizeof(uint16_t);
} else {
@@ -138,16 +140,16 @@
- if (bytesread != m_header.GetPointFormat().GetByteSize()) {
+ if (bytesread != format.GetByteSize()) {
std::ostringstream msg;
msg << "The number of bytes that were read ("<< bytesread <<") does not "
"match the number of bytes the point's format "
"says it should have (" <<
- m_header.GetPointFormat().GetByteSize() << ")";
+ format.GetByteSize() << ")";
throw std::runtime_error(msg.str());
- if (m_header.GetPointFormat().GetByteSize() != m_header.GetDataRecordLength())
+ if (format.GetByteSize() != m_header.GetDataRecordLength())
std::size_t bytesleft = m_header.GetDataRecordLength() - bytesread;
More information about the Liblas-commits
