[Liblas-commits] hg: add buildout configuration
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Mar 24 23:13:42 EDT 2010
changeset 8c59e277b8be in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=8c59e277b8be
summary: add buildout configuration
diffstat:
 buildout/README.txt   |   15 ++
 buildout/bootstrap.py |   55 ++++++++++
 buildout/buildout.cfg |  254 ++++++++++++++++++++++++++++++++++++++++++++++++++
 buildout/setenv.in    |    5 +
 4 files changed, 329 insertions(+), 0 deletions(-)
diffs (truncated from 345 to 300 lines):
diff -r 0b95a35c7f8f -r 8c59e277b8be buildout/README.txt
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/buildout/README.txt	Wed Mar 24 22:08:00 2010 -0500
@@ -0,0 +1,15 @@
+libLAS and friends builout
+Completely stolen from Shapely/gispython.org
+To begin:
+  $ virtualenv .
+  $ source ./bin/activate
+  $ python bootstrap.py
+  $ buildout
+  $ . ./setenv
+  $ labpy
+  >>> from osgeo import gdal
diff -r 0b95a35c7f8f -r 8c59e277b8be buildout/bootstrap.py
+++ b/buildout/bootstrap.py	Wed Mar 24 22:08:00 2010 -0500
@@ -0,0 +1,55 @@
+# Copyright (c) 2006 Zope Corporation and Contributors.
+# All Rights Reserved.
+# This software is subject to the provisions of the Zope Public License,
+# Version 2.1 (ZPL).  A copy of the ZPL should accompany this distribution.
+# THIS SOFTWARE IS PROVIDED "AS IS" AND ANY AND ALL EXPRESS OR IMPLIED
+# WARRANTIES ARE DISCLAIMED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+# WARRANTIES OF TITLE, MERCHANTABILITY, AGAINST INFRINGEMENT, AND FITNESS
+# FOR A PARTICULAR PURPOSE.
+"""Bootstrap a buildout-based project
+Simply run this script in a directory containing a buildout.cfg.
+The script accepts buildout command-line options, so you can
+use the -c option to specify an alternate configuration file.
+$Id$
+import os, shutil, sys, tempfile, urllib2
+tmpeggs = tempfile.mkdtemp()
+try:
+    import pkg_resources
+except ImportError:
+    ez = {}
+    exec urllib2.urlopen('http://peak.telecommunity.com/dist/ez_setup.py'
+                         ).read() in ez
+    ez['use_setuptools'](to_dir=tmpeggs, download_delay=0)
+cmd = 'from setuptools.command.easy_install import main; main()'
+if sys.platform == 'win32':
+    cmd = '"%s"' % cmd # work around spawn lamosity on windows
+ws = pkg_resources.working_set
+assert os.spawnle(
+    os.P_WAIT, sys.executable, sys.executable,
+    '-c', cmd, '-mqNxd', tmpeggs, 'zc.buildout',
+    dict(os.environ,
+         PYTHONPATH=
+         ws.find(pkg_resources.Requirement.parse('setuptools')).location
+    ) == 0
+ws.add_entry(tmpeggs)
+ws.require('zc.buildout')
+import zc.buildout.buildout
+zc.buildout.buildout.main(sys.argv[1:] + ['bootstrap'])
+shutil.rmtree(tmpeggs)
diff -r 0b95a35c7f8f -r 8c59e277b8be buildout/buildout.cfg
+++ b/buildout/buildout.cfg	Wed Mar 24 22:08:00 2010 -0500
@@ -0,0 +1,254 @@
+[buildout]
+parts =
+    source-svn
+    source-liblas-hg
+    cmake-download
+    cmake-configure
+    cmake-build
+    libtiff
+    libproj
+    libproj-datum
+    libgeos
+    libexpat
+    libspatialite
+    autogen-geotiff
+    libgeotiff
+    autogen-spatialindex
+    libspatialindex
+    rtree
+    libgdal
+    cmake-liblas
+    make-liblas
+    liblas-python
+    setenv
+eggs =
+    simplejson
+    geojson
+    numpy
+[python]
+executable = ${buildout:directory}/bin/python
+[platform]
+so_extension = dylib
+#so_extension = so
+[autogen-spatialindex]
+recipe = plone.recipe.command
+command = cd ${source-svn:location}/spatialindex; ./autogen.sh
+update-command = cd ${source-svn:location}/spatialindex; ./autogen.sh
+stop-on-error = yes
+[autogen-geotiff]
+command = cd ${source-svn:location}/geotiff; ./autogen.sh
+update-command = cd ${source-svn:location}/geotiff; ./autogen.sh
+[autogen-liblas]
+command = cd ${source-liblas-hg:location}; ./autogen.sh
+update-command = cd ${source-svn:location}; ./autogen.sh
+[source-svn]
+recipe = infrae.subversion
+location = source
+urls =
+    http://svn.gispython.org/svn/spatialindex/spatialindex/trunk spatialindex
+    http://svn.gispython.org/svn/gispy/Rtree/trunk rtree
+    http://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff geotiff
+    http://svn.osgeo.org/gdal/trunk/gdal gdal
+[source-liblas-hg]
+recipe = mercurialrecipe
+repository = http://hg.liblas.org/main
+location = source/liblas
+[libspatialindex]
+recipe = hexagonit.recipe.cmmi
+location = ${source-svn:location}/spatialindex
+path =
+    ${source-svn:location}/spatialindex
+configure-options =
+    --enable-debug
+prefix=${buildout:directory}
+[rtree]
+recipe = z3c.recipe.egg:setup
+setup = ${source-svn:location}/rtree
+egg = Rtree
+args =
+    clean
+    build
+    test
+    install
+include-dirs =
+    ${libspatialindex:location}/include
+library-dirs =
+    ${libspatialindex:location}/lib
+rpath =
+libraries = spatialindex
+[cmake-liblas]
+command =
+    cd ${source-liblas-hg:location}; \
+    ${buildout:directory}/bin/cmake \
+    -DCMAKE_INSTALL_PREFIX:PATH=${buildout:directory} \
+    -DGDAL_INCLUDE_DIR:PATH=${buildout:directory}/include \
+    -DGDAL_LIBRARY:STRING=${buildout:directory}/lib/libgdal.${platform:so_extension} \
+    -DGEOTIFF_INCLUDE_DIR:PATH=${buildout:directory}/include \
+    -DGEOTIFF_LIBRARY:FILEPATH=${buildout:directory}/lib/libgeotiff.${platform:so_extension} \
+    -DSPATIALINDEX_INCLUDE_DIR:PATH=${buildout:directory}/include \
+    -DSPATIALINDEX_LIBRARY:FILEPATH=${buildout:directory}/lib/libspatialindex.${platform:so_extension} \
+    -DTIFF_INCLUDE_DIR:PATH=${buildout:directory}/include \
+    -DTIFF_LIBRARY:FILEPATH=${buildout:directory}/lib/libtiff.${platform:so_extension} \
+    -DWITH_GEOTIFF:BOOL=ON \
+    -DWITH_GDAL:BOOL=ON \
+    -DWITH_SPATIALINDEX:BOOL=ON \
+[make-liblas]
+command =
+    make ; make install
+[libproj-datum]
+recipe = hexagonit.recipe.download
+url = http://download.osgeo.org/proj/proj-datumgrid-1.5.zip
+destination = ${libproj:location}/share/proj/
+[cmake-download]
+url = http://www.cmake.org/files/v2.8/cmake-2.8.1.tar.gz
+destination = ${buildout:directory}/source/cmake
+[cmake-configure]
+command = cd ${buildout:directory}/source/cmake/cmake-2.8.1; ./bootstrap --prefix=${buildout:directory}
+[cmake-build]
+command = cd ${buildout:directory}/source/cmake/cmake-2.8.1; make;make install
+[libtiff]
+url = http://download.osgeo.org/libtiff/tiff-4.0.0beta5.tar.gz
+[libproj]
+url = http://download.osgeo.org/proj/proj-4.7.0.tar.gz
+[libgeotiff]
+location = ${source-svn:location}/geotiff
+path =
+    ${source-svn:location}/geotiff
+    --with-libtiff=${libtiff:location}
+    --with-proj=${libproj:location}
+[libgeos]
+url = http://download.osgeo.org/geos/geos-3.2.0.tar.bz2
+[libexpat]
+url = http://sourceforge.net/projects/expat/files/expat/2.0.1/expat-2.0.1.tar.gz/download
+[libspatialite]
+url = http://www.gaia-gis.it/spatialite/libspatialite-amalgamation-2.3.1.tar.gz
+    --with-geos=${libgeos:location}
+[libgdal]
+location = ${source-svn:location}/gdal
+path =
+    ${source-svn:location}/gdal
+    --enable-debug
+    --with-proj=${buildout:directory}
+    --with-libtiff=${buildout:directory}
+    --with-geotiff=${buildout:directory}
+    --with-png=internal
+    --with-jpeg=internal
+    --with-geos=${buildout:directory}/bin/geos-config
+    --without-python
+    --without-xerces
+    --with-expat=${buildout:directory}
+    --with-spatialite=${buildout:directory}
+[liblas-python]
+setup = ${source-svn:location}/liblas/python
+args =
+    clean
+    build
+    test
+    install
+egg = libLAS
+include-dirs =
+    ${buildout:directory}/include
+library-dirs =
+    ${buildout:directory}/lib
+rpath =
+libraries = liblas_c
More information about the Liblas-commits mailing list
