[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Wed May 12 16:11:06 EDT 2010
changeset 24ef2ec5718c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=24ef2ec5718c
summary: add LASWriter_GetHeader
changeset 1aaebd2d44da in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=1aaebd2d44da
summary: more better header accounting
diffstat:
include/liblas/capi/liblas.h | 7 +++++++
python/liblas/core.py | 4 ++++
python/liblas/file.py | 32 +++++++++++++++++++++++++-------
src/las_c_api.cpp | 9 +++++++++
4 files changed, 45 insertions(+), 7 deletions(-)
diffs (133 lines):
diff -r f9067b68b402 -r 1aaebd2d44da include/liblas/capi/liblas.h
--- a/include/liblas/capi/liblas.h Wed May 12 11:28:58 2010 -0500
+++ b/include/liblas/capi/liblas.h Wed May 12 15:10:56 2010 -0500
@@ -898,6 +898,13 @@
LAS_DLL void LASWriter_Destroy(LASWriterH hWriter);
+/** Returns a LASHeaderH representing the header for the file
+ * @param hWriter the LASWriterH instance
+ * @return a LASHeaderH representing the header for the file. NULL is returned
+ * in the event of an error. Use the LASError_GetLastError* methods to check
+ * in the event of a NULL return.
+LAS_DLL LASHeaderH LASWriter_GetHeader(const LASWriterH hWriter);
LAS_DLL LASError LASWriter_SetSRS(LASWriterH hWriter, const LASSRSH hSRS);
LAS_DLL LASError LASWriter_SetInputSRS(LASWriterH hWriter, const LASSRSH hSRS);
diff -r f9067b68b402 -r 1aaebd2d44da python/liblas/core.py
--- a/python/liblas/core.py Wed May 12 11:28:58 2010 -0500
+++ b/python/liblas/core.py Wed May 12 15:10:56 2010 -0500
@@ -554,6 +554,10 @@
las.LASWriter_SetOutputSRS.argtypes = [ctypes.c_void_p, ctypes.c_void_p]
las.LASWriter_SetOutputSRS.errcheck = check_return
+las.LASWriter_GetHeader.restype = ctypes.c_void_p
+las.LASWriter_GetHeader.argtypes = [ctypes.c_void_p]
+las.LASWriter_GetHeader.errcheck = check_void
las.LASWriter_Destroy.argtypes = [ctypes.c_void_p]
las.LASWriter_Destroy.errcheck = check_void_done
las.LASWriter_Destroy.restype = None
diff -r f9067b68b402 -r 1aaebd2d44da python/liblas/file.py
--- a/python/liblas/file.py Wed May 12 11:28:58 2010 -0500
+++ b/python/liblas/file.py Wed May 12 15:10:56 2010 -0500
@@ -95,13 +95,20 @@
self.filename = os.path.abspath(filename)
self._header = None
- if header:
- self._header = core.las.LASHeader_Copy(header.handle)
+ self.ownheader = True
+ # import pdb;pdb.set_trace()
+ if header != None:
+ self.ownheader = False
+ self._header = header.handle
self.handle = None
self._mode = mode.lower()
self.in_srs = in_srs
self.out_srs = out_srs
#check in the registry if we already have the file open
if mode == 'r':
for f in files['write'] + files['append']:
@@ -122,6 +129,7 @@
def open(self):
"""Open the file for processing, called by __init__
if self._mode == 'r' or self._mode == 'rb':
if self._header == None:
@@ -130,7 +138,7 @@
else:
self.handle = \
core.las.LASReader_CreateWithHeader(self.filename,
- self._header.handle)
+ self._header)
self.mode = 0
try:
@@ -149,6 +157,7 @@
self._header = core.las.LASHeader_Create()
self.handle = core.las.LASWriter_Create(self.filename,
self._header,
1)
@@ -205,8 +214,10 @@
except:
files['write'].remove(self.filename)
core.las.LASWriter_Destroy(self.handle)
- core.las.LASHeader_Destroy(self._header)
+ if self.ownheader:
+ core.las.LASHeader_Destroy(self._header)
self._header = None
self.handle = None
@@ -246,9 +257,16 @@
def get_header(self):
"""Returns the liblas.header.Header for the file"""
- if self._header:
- return lasheader.Header(handle=self._header, copy=True)
+ if not self.handle:
+ return None
+ if self.mode == 0:
+ return lasheader.Header(handle=core.las.LASReader_GetHeader(self.handle))
+ else:
+ return lasheader.Header(handle=core.las.LASWriter_GetHeader(self.handle))
return None
def set_header(self, header):
"""Sets the liblas.header.Header for the file. If the file is in \
append mode, the header will be overwritten in the file."""
diff -r f9067b68b402 -r 1aaebd2d44da src/las_c_api.cpp
--- a/src/las_c_api.cpp Wed May 12 11:28:58 2010 -0500
+++ b/src/las_c_api.cpp Wed May 12 15:10:56 2010 -0500
@@ -1513,6 +1513,15 @@
return LE_None;
+ VALIDATE_LAS_POINTER1(hWriter, "LASWriter_GetHeader", NULL);
+ liblas::Header header = ((liblas::Writer*) hWriter)->GetHeader();
+ return (LASHeaderH) new liblas::Header( header );
LAS_DLL void LASError_Print(const char* message) {
char* errmsg= NULL;
More information about the Liblas-commits
