[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org
Mon May 17 11:32:56 EDT 2010
changeset 06df450d2c43 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=06df450d2c43
summary: a big slug of doc migration from trac
changeset d996ce2ba976 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d996ce2ba976
summary: remove unused build stuff
changeset 80e46c5687da in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=80e46c5687da
summary: more doc work
diffstat:
build/msvc60/las.dsw | 113 -----
build/msvc60/las2las.dsp | 134 ------
build/msvc60/las2txt.dsp | 126 ------
build/msvc60/lasdiff.dsp | 126 ------
build/msvc60/lasinfo.dsp | 126 ------
build/msvc60/lasmerge.dsp | 126 ------
build/msvc60/lasview.dsp | 126 ------
build/msvc60/laszip.dsp | 134 ------
build/msvc60/txt2las.dsp | 126 ------
build/msvc80/clean.bat | 26 -
build/msvc80/las2las/las2las.vcproj | 191 ---------
build/msvc80/las2ogr/las2ogr.vcproj | 186 ---------
build/msvc80/las2ogr/las2ogr.vsprops | 20 -
build/msvc80/las2txt/las2txt.vcproj | 191 ---------
build/msvc80/lasdiff/lasdiff.vcproj | 189 ---------
build/msvc80/lasinfo/lasinfo.vcproj | 191 ---------
build/msvc80/lasmerge/lasmerge.vcproj | 189 ---------
build/msvc80/liblas.sln | 107 -----
build/msvc80/liblas.vsprops | 26 -
build/msvc80/liblas_c_dll/liblas_c_dll.vcproj | 207 ----------
build/msvc80/liblas_dll/liblas_dll.vcproj | 261 -------------
build/msvc80/liblas_lib/liblas_lib.vcproj | 387 -------------------
build/msvc80/liblas_test/liblas_test.vcproj | 256 -------------
build/msvc80/txt2las/txt2las.vcproj | 189 ---------
build/msvc90/clean.bat | 26 -
build/msvc90/las2las/las2las.vcproj | 193 ---------
build/msvc90/las2ogr/las2ogr.vcproj | 190 ---------
build/msvc90/las2txt/las2txt.vcproj | 191 ---------
build/msvc90/lasdiff/lasdiff.vcproj | 190 ---------
build/msvc90/lasinfo/lasinfo.vcproj | 191 ---------
build/msvc90/lasmerge/lasmerge.vcproj | 191 ---------
build/msvc90/liblas.sln | 110 -----
build/msvc90/liblas.vsprops | 31 -
build/msvc90/liblas_c_dll/liblas_c_dll.vcproj | 207 ----------
build/msvc90/liblas_dll/liblas_dll.vcproj | 261 -------------
build/msvc90/liblas_lib/liblas_lib.vcproj | 389 --------------------
build/msvc90/liblas_test/liblas_test.vcproj | 268 -------------
build/msvc90/txt2las/txt2las.vcproj | 191 ---------
doc/_static/ASPRS-Workshop-NOAA-Demo.pdf | 0
doc/_static/LAS-1.0-1.3-feature-matrix.pdf | 0
doc/_static/liblas-color-pallette.css | 32 +
doc/_static/liblas_foss4g_2008.pdf | 0
doc/_static/liblaslogo.png | 0
doc/_static/pdf.png | 0
doc/_static/specifications/asprs_las_format_v10.pdf | 0
doc/_static/specifications/asprs_las_format_v11.pdf | 0
doc/_static/specifications/asprs_las_format_v12.pdf | 0
doc/_static/specifications/asprs_las_format_v13.pdf | 0
doc/_static/sphinx.css | 244 ++++++++++++
doc/_templates/indexsidebar.html | 4 +
doc/_templates/layout.html | 32 +
doc/base/index.txt | 2 +-
doc/compilation.txt | 229 +++++++++++
doc/conf.py | 11 +-
doc/development/buildbot.txt | 25 +
doc/development/format_elements.txt | 161 ++++++++
doc/development/index.txt | 16 +
doc/development/source.txt | 12 +
doc/development/specifications.txt | 21 +
doc/docs.txt | 18 +
doc/download.txt | 104 +++++
doc/faq.txt | 79 ++++
doc/index.txt | 139 +------
doc/lastools.txt | 63 +++
doc/liblas.json | 326 ++++++++++++++++
doc/python/classes.txt | 2 +-
doc/python/tutorial.txt | 220 -----------
doc/styles/liblas-color-pallette.css | 32 -
doc/tutorial/boo.txt | 42 ++
doc/tutorial/cpp.txt | 206 ++++++++++
doc/tutorial/csharp.txt | 56 ++
doc/tutorial/index.txt | 16 +
doc/tutorial/ironpython.txt | 36 +
doc/tutorial/python.txt | 222 +++++++++++
doc/tutorial/qhull.txt | 108 +++++
doc/tutorial/vbnet.txt | 42 ++
doc/utilities/las2las.txt | 3 -
doc/utilities/las2ogr.txt | 2 -
doc/utilities/las2txt.txt | 2 -
doc/utilities/lasdiff.txt | 2 -
doc/utilities/lasinfo.txt | 2 -
doc/utilities/lasmerge.txt | 2 -
doc/utilities/txt2las.txt | 2 -
83 files changed, 2109 insertions(+), 6788 deletions(-)
diffs (truncated from 9374 to 300 lines):
diff -r 1aaebd2d44da -r 80e46c5687da build/msvc60/las.dsw
--- a/build/msvc60/las.dsw Wed May 12 15:10:56 2010 -0500
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,113 +0,0 @@
-Microsoft Developer Studio Workspace File, Format Version 6.00
-# WARNING: DO NOT EDIT OR DELETE THIS WORKSPACE FILE!
-Project: "las2las"=.\tools\las2las.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "las2txt"=.\tools\las2txt.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "lasdiff"=.\tools\lasdiff.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "lasinfo"=.\tools\lasinfo.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "lasmerge"=.\tools\lasmerge.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "lasview"=.\tools\lasview.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "laszip"=.\tools\laszip.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Project: "txt2las"=.\tools\txt2las.dsp - Package Owner=<4>
-Package=<5>
-Package=<4>
-Global:
-Package=<5>
-Package=<3>
diff -r 1aaebd2d44da -r 80e46c5687da build/msvc60/las2las.dsp
--- a/build/msvc60/las2las.dsp Wed May 12 15:10:56 2010 -0500
@@ -1,134 +0,0 @@
-# Microsoft Developer Studio Project File - Name="las2las" - Package Owner=<4>
-# Microsoft Developer Studio Generated Build File, Format Version 6.00
-# ** DO NOT EDIT **
-# TARGTYPE "Win32 (x86) Console Application" 0x0103
-CFG=las2las - Win32 Debug
-!MESSAGE This is not a valid makefile. To build this project using NMAKE,
-!MESSAGE use the Export Makefile command and run
-!MESSAGE
-!MESSAGE NMAKE /f "las2las.mak".
-!MESSAGE
-!MESSAGE You can specify a configuration when running NMAKE
-!MESSAGE by defining the macro CFG on the command line. For example:
-!MESSAGE
-!MESSAGE NMAKE /f "las2las.mak" CFG="las2las - Win32 Debug"
-!MESSAGE
-!MESSAGE Possible choices for configuration are:
-!MESSAGE
-!MESSAGE "las2las - Win32 Release" (based on "Win32 (x86) Console Application")
-!MESSAGE "las2las - Win32 Debug" (based on "Win32 (x86) Console Application")
-!MESSAGE
-# Begin Project
-# PROP AllowPerConfigDependencies 0
-# PROP Scc_ProjName ""
-# PROP Scc_LocalPath ""
-CPP=cl.exe
-RSC=rc.exe
-!IF "$(CFG)" == "las2las - Win32 Release"
-# PROP BASE Use_MFC 0
-# PROP BASE Use_Debug_Libraries 0
-# PROP BASE Output_Dir "Release"
-# PROP BASE Intermediate_Dir "Release"
-# PROP BASE Target_Dir ""
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 0
-# PROP Output_Dir "Release"
-# PROP Intermediate_Dir "Release"
-# PROP Ignore_Export_Lib 0
-# PROP Target_Dir ""
-# ADD BASE CPP /nologo /W3 /GX /O2 /D "WIN32" /D "NDEBUG" /D "_CONSOLE" /D "_MBCS" /YX /FD /c
-# ADD CPP /nologo /W3 /GX /O2 /I "..\inc" /I "..\stl" /I "..\src" /D "NDEBUG" /D "WIN32" /D "_CONSOLE" /D "_MBCS" /YX /FD /c
-# ADD BASE RSC /l 0x409 /d "NDEBUG"
-# ADD RSC /l 0x409 /i "../src" /d "NDEBUG"
-BSC32=bscmake.exe
-# ADD BASE BSC32 /nologo
-# ADD BSC32 /nologo
-LINK32=link.exe
-# ADD BASE LINK32 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /subsystem:console /machine:I386
-# ADD LINK32 ../lib/LASlib.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /subsystem:console /machine:I386
-# Begin Special Build Tool
-SOURCE="$(InputPath)"
-PostBuild_Cmds=copy Release\las2las.exe ..\bin\las2las.exe
-# End Special Build Tool
-!ELSEIF "$(CFG)" == "las2las - Win32 Debug"
-# PROP BASE Use_Debug_Libraries 1
-# PROP BASE Output_Dir "Debug"
-# PROP BASE Intermediate_Dir "Debug"
-# PROP Use_MFC 0
-# PROP Use_Debug_Libraries 1
-# PROP Output_Dir "Debug"
-# PROP Intermediate_Dir "Debug"
-# ADD BASE CPP /nologo /W3 /Gm /GX /ZI /Od /D "WIN32" /D "_DEBUG" /D "_CONSOLE" /D "_MBCS" /YX /FD /GZ /c
-# ADD CPP /nologo /W3 /Gm /GX /ZI /Od /I "..\inc" /I "..\stl" /I "..\src" /D "_DEBUG" /D "WIN32" /D "_CONSOLE" /D "_MBCS" /YX /FD /GZ /c
-# ADD BASE RSC /l 0x409 /d "_DEBUG"
-# ADD RSC /l 0x409 /i "..\..\src" /d "_DEBUG"
-BSC32=bscmake.exe
-LINK32=link.exe
-# ADD BASE LINK32 kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /subsystem:console /debug /machine:I386 /pdbtype:sept
-# ADD LINK32 ../libD/LASlib.lib kernel32.lib user32.lib gdi32.lib winspool.lib comdlg32.lib advapi32.lib shell32.lib ole32.lib oleaut32.lib uuid.lib odbc32.lib odbccp32.lib /nologo /subsystem:console /debug /machine:I386 /pdbtype:sept
-PostBuild_Cmds=copy Debug\las2las.exe ..\bin\las2las.exe
-!ENDIF
-# Begin Target
-# Name "las2las - Win32 Release"
-# Name "las2las - Win32 Debug"
-# Begin Group "Source Files"
-# PROP Default_Filter "cpp;c;cxx;rc;def;r;odl;idl;hpj;bat"
-# Begin Source File
-SOURCE=.\src\fopengzipped.cpp
-# End Source File
-SOURCE=.\src\las2las.cpp
-# End Source File
-# End Group
-# Begin Group "Header Files"
-# PROP Default_Filter "h;hpp;hxx;hm;inl"
-SOURCE=..\inc\lasdefinitions.h
-# End Source File
-SOURCE=..\inc\laspointreader.h
-# End Source File
-SOURCE=..\inc\laspointwriter.h
-# End Source File
-SOURCE=..\inc\lasreader.h
-# End Source File
-SOURCE=..\inc\laswriter.h
-# End Source File
-# End Group
-# Begin Group "Resource Files"
-# PROP Default_Filter "ico;cur;bmp;dlg;rc2;rct;bin;rgs;gif;jpg;jpeg;jpe"
-# End Group
-# End Target
-# End Project
diff -r 1aaebd2d44da -r 80e46c5687da build/msvc60/las2txt.dsp
--- a/build/msvc60/las2txt.dsp Wed May 12 15:10:56 2010 -0500
@@ -1,126 +0,0 @@
-# Microsoft Developer Studio Project File - Name="las2txt" - Package Owner=<4>
-CFG=las2txt - Win32 Debug
-!MESSAGE
-!MESSAGE NMAKE /f "las2txt.mak".
-!MESSAGE
-!MESSAGE
-!MESSAGE NMAKE /f "las2txt.mak" CFG="las2txt - Win32 Debug"
-!MESSAGE
-!MESSAGE
-!MESSAGE "las2txt - Win32 Release" (based on "Win32 (x86) Console Application")
-!MESSAGE "las2txt - Win32 Debug" (based on "Win32 (x86) Console Application")
-!MESSAGE
-# Begin Project
-CPP=cl.exe
-RSC=rc.exe
-!IF "$(CFG)" == "las2txt - Win32 Release"
-# PROP Use_MFC 0
More information about the Liblas-commits
