[Liblas-commits] hg: doxygen-related stuff
liblas-commits at liblas.org liblas-commits at liblas.org
Mon May 17 15:53:30 EDT 2010
changeset 5c3cb0178182 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=5c3cb0178182
summary: doxygen-related stuff
diffstat:
 doc/api/doxygen.conf |    6 +-
 doc/api/doxygen.css  |  390 +++++++++++++++++++++++++++++++++++++++++++++++++++
 doc/base/index.txt   |   13 +-
 doc/compilation.txt  |    7 +
 doc/conf.py          |    6 +-
 doc/docs.txt         |    4 +-
 doc/features.txt     |   19 ++-
 doc/index.txt        |   22 +-
 8 files changed, 442 insertions(+), 25 deletions(-)
diffs (truncated from 598 to 300 lines):
diff -r 0b86d9451d34 -r 5c3cb0178182 doc/api/doxygen.conf
--- a/doc/api/doxygen.conf	Mon May 17 13:18:59 2010 -0500
+++ b/doc/api/doxygen.conf	Mon May 17 14:53:25 2010 -0500
@@ -669,13 +669,13 @@
 # each generated HTML page. If it is left blank doxygen will generate a
 # standard header.
-HTML_HEADER            = TracHeader.html
+#HTML_HEADER            =
 # The HTML_FOOTER tag can be used to specify a personal HTML footer for
 # standard footer.
-HTML_FOOTER            = TracHeader.html
+#HTML_FOOTER            =
 # The HTML_STYLESHEET tag can be used to specify a user-defined cascading
 # style sheet that is used by each HTML page. It can be used to
@@ -684,7 +684,7 @@
 # the style sheet file to the HTML output directory, so don't put your own
 # stylesheet in the HTML output directory as well, or it will be erased!
-HTML_STYLESHEET        =
+HTML_STYLESHEET        = doxygen.css
 # If the HTML_ALIGN_MEMBERS tag is set to YES, the members of classes,
 # files or namespaces will be aligned in HTML using tables. If set to
diff -r 0b86d9451d34 -r 5c3cb0178182 doc/api/doxygen.css
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/doc/api/doxygen.css	Mon May 17 14:53:25 2010 -0500
@@ -0,0 +1,390 @@
+/* override a few trac styles */
+:link, :visited, :link:hover, :visited:hover {
+ border-bottom-style: none;
+/* tabs */
+div.tabs *
+  display: inline;
+div.tabs ul
+  display: block;
+  margin: 0em;
+  padding: 0.5em 0em;
+  font-size: 10px;
+  list-style: none;
+  text-align: left;
+div.tabs li
+  border-right: 1px solid #d7d7d7;
+  padding: 0em 0.75em;
+  white-space: nowrap;
+  margin: 3px;
+div.tabs form
+  margin: 3px;
+div.tabs #current a, div.tabs a:hover {
+  background-color: #fdc; /* blue: #eef3f5 */
+  padding: 3px;
+  border-width: 1px;
+  border-style: solid;
+  border-color: #d00; /* blue: #dedeee */
+  -moz-border-radius: 8px 8px 8px 8px;
+div.tabs a {
+  padding: 3px;
+  border-style: dotted;
+  border-color: #ffffff;
+div.tabs a:visited
+  color: #2A3798;
+h1 {
+  text-align: center;
+  font-size: 160%;
+h2 {
+  font-size: 120%;
+h3 {
+  font-size: 100%;
+caption { font-weight: bold }
+div.qindex {
+  width: 100%;
+  background-color: #e8eef2;
+  border: 1px solid #84b0c7;
+  margin: 2px;
+  padding: 2px;
+  line-height: 140%;
+a.qindex {
+       text-decoration: none;
+       font-weight: bold;
+       color: #1A419D;
+a.qindex:visited {
+       color: #1A419D
+a.qindex:hover {
+  background-color: #ddddff;
+a.qindexHL {
+  background-color: #6666cc;
+  color: #ffffff;
+  border: 1px double #9295C2;
+a.qindexHL:hover {
+  color: #ffffff;
+a.qindexHL:visited { text-decoration: none; background-color: #6666cc; color: #ffffff }
+a.el { text-decoration: none; font-weight: bold }
+a.elRef { font-weight: bold }
+a.code:link { text-decoration: none; font-weight: normal; color: #0000FF}
+a.code:visited { text-decoration: none; font-weight: normal; color: #0000FF}
+a.codeRef:link { font-weight: normal; color: #0000FF}
+a.codeRef:visited { font-weight: normal; color: #0000FF}
+a:hover { text-decoration: none; background-color: #f2f2ff }
+dl.el { margin-left: -1cm }
+.fragment {
+       font-family: monospace, fixed;
+       font-size: 95%;
+pre.fragment {
+  border: 1px solid #CCCCCC;
+  background-color: #f5f5f5;
+  margin-top: 4px;
+  margin-bottom: 4px;
+  margin-left: 2px;
+  margin-right: 8px;
+  padding-left: 6px;
+  padding-right: 6px;
+  padding-top: 4px;
+  padding-bottom: 4px;
+div.ah { background-color: black; font-weight: bold; color: #ffffff; margin-bottom: 3px; margin-top: 3px }
+div.groupHeader {
+  margin-left: 16px;
+  margin-top: 12px;
+  margin-bottom: 6px;
+div.groupText {
+  font-style: italic;
+  font-size: 90%
+td.indexkey {
+  padding-right  : 10px;
+  padding-top    : 2px;
+  padding-left   : 10px;
+  padding-bottom : 2px;
+  margin-left    : 0px;
+  margin-right   : 0px;
+  margin-top     : 2px;
+  margin-bottom  : 2px;
+td.indexvalue {
+  margin-top     : 2px;
+tr.memlist {
+   background-color: #f0f0f0;
+p.formulaDsp { text-align: center; }
+img.formulaDsp { }
+img.formulaInl { vertical-align: middle; }
+span.keyword       { color: #008000 }
+span.keywordtype   { color: #604020 }
+span.keywordflow   { color: #e08000 }
+span.comment       { color: #800000 }
+span.preprocessor  { color: #806020 }
+span.stringliteral { color: #002080 }
+span.charliteral   { color: #008080 }
+.mdescLeft {
+       padding: 0px 8px 4px 8px;
+  font-size: 80%;
+  background-color: #FAFAFA;
+  border-top: 1px none #E0E0E0;
+  border-right: 1px none #E0E0E0;
+  border-bottom: 1px none #E0E0E0;
+  border-left: 1px none #E0E0E0;
+  margin: 0px;
+.mdescRight {
+  font-size: 80%;
+  margin: 0px;
+.memItemLeft {
+  padding: 1px 0px 0px 8px;
+  margin: 4px;
+  border-top-width: 1px;
+  border-right-width: 1px;
+  border-bottom-width: 1px;
+  border-left-width: 1px;
+  border-top-color: #E0E0E0;
+  border-right-color: #E0E0E0;
+  border-bottom-color: #E0E0E0;
+  border-left-color: #E0E0E0;
+  border-top-style: solid;
+  border-right-style: none;
+  border-left-style: none;
+  font-size: 80%;
+.memItemRight {
+  padding: 1px 8px 0px 8px;
+  margin: 4px;
+  font-size: 80%;
+.memTemplItemLeft {
+  margin: 4px;
+  border-top-style: none;
+  font-size: 80%;
+.memTemplItemRight {
+  margin: 4px;
More information about the Liblas-commits mailing list
