[Liblas-commits] hg: 4 new changesets
liblas-commits at liblas.org
Tue May 18 15:22:50 EDT 2010
changeset 124fbfc8473c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=124fbfc8473c
summary: typos
changeset b288701a85cd in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=b288701a85cd
summary: add back README to satisfy autoconf for now
changeset 688db5798374 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=688db5798374
summary: add a stackable filter implementation
changeset 5586d2510818 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=5586d2510818
summary: doc work
diffstat:
apps/CMakeLists.txt | 9 +-
apps/las2las2.cpp | 249 +++++++++++++++++++++++++++++++++++++++++++
apps/las2ogr.cpp | 6 +-
doc/conf.py | 8 +-
doc/docs.txt | 1 +
include/liblas/lasfilter.hpp | 96 ++++++++++++++++
include/liblas/lasreader.hpp | 9 +
include/liblas/liblas.hpp | 11 +
src/CMakeLists.txt | 2 +
src/lasfilter.cpp | 130 ++++++++++++++++++++++
src/lasreader.cpp | 24 ++++
11 files changed, 539 insertions(+), 6 deletions(-)
diffs (truncated from 694 to 300 lines):
diff -r 5c3cb0178182 -r 5586d2510818 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt Mon May 17 14:53:25 2010 -0500
+++ b/apps/CMakeLists.txt Tue May 18 14:22:39 2010 -0500
@@ -19,7 +19,7 @@
set(LAS2LAS las2las)
set(LAS2TXT las2txt)
set(TXT2LAS txt2las)
+set(LAS2LAS2 las2las2 )
# Utilities depending on 3rd-pary libraries
if(GDAL_FOUND)
set(LAS2OGR las2ogr)
@@ -35,7 +35,7 @@
set(LIBLAS_UTILITIES
${LASINFO} ${LASMERGE} ${LAS2LAS} ${LAS2TXT} ${TXT2LAS}
- ${LAS2OGR} ${LASINDEX} ${LAS2OCI})
+ ${LAS2OGR} ${LASINDEX} ${LAS2OCI} ${LAS2LAS2})
# TODO: Experimental and requires testing --mloskot
# Generate user-specific settings for Visual Studio project
@@ -77,6 +77,11 @@
target_link_libraries(${LAS2LAS} ${LIBLAS_C_LIB_NAME})
endif()
+if(LAS2LAS2)
+ add_executable(${LAS2LAS2} las2las2.cpp)
+ target_link_libraries(${LAS2LAS2} ${APPS_CPP_DEPENDENCIES})
+endif()
# Build las2txt
if(LAS2TXT)
set(LAS2TXT_SRC lascommon.c ${LAS2TXT}.c)
diff -r 5c3cb0178182 -r 5586d2510818 apps/las2las2.cpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/apps/las2las2.cpp Tue May 18 14:22:39 2010 -0500
@@ -0,0 +1,249 @@
+// $Id$
+// ts2las translates TerraSolid .bin file to ASPRS LAS file.
+// TerraSolid format: http://cdn.terrasolid.fi/tscan.pdf
+// (C) Copyright Howard Butler 2009, hobu.inc at gmail.com
+// Distributed under the BSD License
+// (See accompanying file LICENSE.txt or copy at
+// http://www.opensource.org/licenses/bsd-license.php)
+// liblas
+#include <liblas/liblas.hpp>
+#include <liblas/laspoint.hpp>
+#include <liblas/lasreader.hpp>
+#include <liblas/laswriter.hpp>
+#include <liblas/lasfilter.hpp>
+#include <liblas/cstdint.hpp>
+#include <fstream>
+#include <iostream>
+#include <string>
+#include <vector>
+#include <string>
+using namespace liblas;
+#ifdef _WIN32
+#define compare_no_case(a,b,n) _strnicmp( (a), (b), (n) )
+#else
+#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
+#endif
+bool term_progress(std::ostream& os, double complete)
+ static int lastTick = -1;
+ int tick = static_cast<int>(complete * 40.0);
+ tick = std::min(40, std::max(0, tick));
+ // Have we started a new progress run?
+ if (tick < lastTick && lastTick >= 39)
+ lastTick = -1;
+ if (tick <= lastTick)
+ return true;
+ while (tick > lastTick)
+ lastTick++;
+ if (lastTick % 4 == 0)
+ os << (lastTick / 4) * 10;
+ else
+ os << ".";
+ if( tick == 40 )
+ os << " - done.\n";
+ else
+ os.flush();
+ return true;
+void tokenize(const std::string& str,
+ std::vector<std::string>& tokens,
+ const std::string& delimiters = ",")
+ // stolen from http://www.linuxselfhelp.com/HOWTO/C++Programming-HOWTO-7.html
+ // Skip delimiters at beginning.
+ std::string::size_type lastPos = str.find_first_not_of(delimiters, 0);
+ // Find first "non-delimiter".
+ std::string::size_type pos = str.find_first_of(delimiters, lastPos);
+ while (std::string::npos != pos || std::string::npos != lastPos)
+ // Found a token, add it to the vector.
+ tokens.push_back(str.substr(lastPos, pos - lastPos));
+ // Skip delimiters. Note the "not_of"
+ lastPos = str.find_first_not_of(delimiters, pos);
+ // Find next "non-delimiter"
+ pos = str.find_first_of(delimiters, lastPos);
+void usage() {}
+int main(int argc, char* argv[])
+ int rc = 0;
+ std::vector<std::string> tokens;
+ std::vector<liblas::uint8_t> classes;
+ std::vector<double> bounds;
+ std::vector<liblas::FilterI*> filters;
+ try
+ // Parse command-line options
+ std::string in_file;
+ std::string out_file;
+ std::string keep_classes;
+ int on_arg = 1;
+ while (on_arg < argc)
+ std::string arg(argv[on_arg]);
+ if (arg == "-h")
+ usage();
+ return 0;
+ else if (arg == "-i" && (on_arg + 1 < argc))
+ ++on_arg;
+ assert(on_arg < argc);
+ in_file = argv[on_arg];
+ else if (arg == "-c" && (on_arg + 1 < argc))
+ ++on_arg;
+ tokenize(std::string(argv[on_arg]), tokens);
+ std::vector<std::string>::const_iterator i;
+ for (i = tokens.begin(); i != tokens.end(); ++i) {
+ classes.push_back(atoi((*i).c_str()));
+ std::cout << ", "<<*i;
+ std::cout << std::endl;
+ tokens.clear();
+ else if (arg == "-b" && (on_arg + 1 < argc))
+ ++on_arg;
+ bounds.push_back(atof((*i).c_str()));
+ tokens.clear();
+ else if (arg == "-o" && (on_arg + 1 < argc))
+ ++on_arg;
+ out_file = argv[on_arg];
+ else
+ throw std::runtime_error(std::string("unrecognized parameter: ") + arg);
+ ++on_arg;
+ if (in_file.empty() || out_file.empty())
+ throw std::runtime_error("missing input paremeters");
+ // Source
+ std::cout << "Source:" << "\n - dataset: " << in_file << std::endl;
+ // Make the filter
+ liblas::ClassificationFilter* class_filter = new ClassificationFilter(classes);
+ class_filter->SetKeep(true);
+ filters.push_back(class_filter);
+ liblas::BoundsFilter* bounds_filter = 0;
+ if (bounds.size() > 0) {
+ if (bounds.size() == 4) {
+ bounds_filter = new BoundsFilter(bounds[0], bounds[1], bounds[2], bounds[3]);
+ } else if (bounds.size() == 6) {
+ bounds_filter = new BoundsFilter(bounds[0], bounds[1], bounds[2], bounds[3], bounds[4], bounds[5]);
+ } else {
+ throw std::runtime_error("bounds must be a 4-tuple or 6-tuple in the form of minx, miny, maxx, maxy, [minx, maxz]");
+ filters.push_back(bounds_filter);
+ std::ifstream ifs;
+ if (!liblas::Open(ifs, in_file.c_str()))
+ throw std::runtime_error(std::string("Can not open \'") + in_file + "\'");
+ liblas::Reader reader(ifs);
+ reader.SetFilters(filters);
+ std::ofstream ofs;
+ if (!liblas::Create(ofs, out_file.c_str()))
+ throw std::runtime_error(std::string("Can not create \'") + in_file + "\'");
+ liblas::Writer writer(ofs, reader.GetHeader());
+ std::cout << "Target:"
+ << "\n - : " << out_file
+ << std::endl;
+ // Translation of points cloud to features set
+ liblas::uint32_t i = 0;
+ liblas::uint32_t const size = reader.GetHeader().GetPointRecordsCount();
+ while (reader.ReadNextPoint())
+ liblas::Point const& p = reader.GetPoint();
+ writer.WritePoint(p);
+ term_progress(std::cout, (i + 1) / static_cast<double>(size));
+ i++;
+ catch (std::exception const& e)
+ std::cerr << "Error: " << e.what() << std::endl;
+ rc = -1;
+ catch (...)
+ std::cerr << "Unknown error\n";
+ rc = -1;
+ return rc;
diff -r 5c3cb0178182 -r 5586d2510818 apps/las2ogr.cpp
--- a/apps/las2ogr.cpp Mon May 17 14:53:25 2010 -0500
+++ b/apps/las2ogr.cpp Tue May 18 14:22:39 2010 -0500
@@ -151,7 +151,7 @@
err = OGR_L_CreateField(lyr, fld, 0);
if (OGRERR_NONE != err)
- throw std::runtime_error("angle field cration failed");
+ throw std::runtime_error("angle field creation failed");
OGR_Fld_Destroy(fld);
@@ -160,7 +160,7 @@
More information about the Liblas-commits
