[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org
Thu May 20 08:44:56 EDT 2010
changeset 02b0cb83e697 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=02b0cb83e697
summary: typo
changeset 0469b8533fd2 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0469b8533fd2
summary: add TransformI prototype
changeset 422eaffeb92c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=422eaffeb92c
summary: more doc work
diffstat:
doc/_templates/indexsidebar.html | 2 +-
doc/base/index.txt | 21 --
doc/compilation.txt | 268 ++++++++++++++++--------------------
doc/conf.py | 3 +-
doc/development/buildbot.txt | 147 ++++++++++++++++++++
doc/docs.txt | 15 +-
doc/download.txt | 6 +-
doc/images/ccmake-osx-start.png | 0
doc/images/cmake-gui-osx-start.png | 0
doc/index.txt | 3 -
doc/python.txt | 155 +++++++++++++++++++++
doc/python/classes.txt | 155 ---------------------
doc/python/index.txt | 16 --
include/liblas/liblas.hpp | 8 +
src/lasfilter.cpp | 2 +-
15 files changed, 445 insertions(+), 356 deletions(-)
diffs (truncated from 955 to 300 lines):
diff -r 5586d2510818 -r 422eaffeb92c doc/_templates/indexsidebar.html
--- a/doc/_templates/indexsidebar.html Tue May 18 14:22:39 2010 -0500
+++ b/doc/_templates/indexsidebar.html Thu May 20 07:44:44 2010 -0500
@@ -14,6 +14,6 @@
</p>
<p>
- <script type="text/javascript" src="http://www.ohloh.net/p/10742/widgets/project_partner_badge.js"></script>
+<script type="text/javascript" src="http://www.ohloh.net/p/10742/widgets/project_thin_badge.js"></script>
</p>
diff -r 5586d2510818 -r 422eaffeb92c doc/base/index.txt
--- a/doc/base/index.txt Tue May 18 14:22:39 2010 -0500
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,21 +0,0 @@
-.. raw:: pdf
- PageBreak
-.. _cppapi:
- C++ Library Reference
-some text
-.. doxygenindex::
- :project: liblas
- :path: /Users/hobu/hg/liblas-cmake/doc/api/xml/index.xml
-.. doxygenclass:: liblas::Color
- :project: liblas
-some more text
\ No newline at end of file
diff -r 5586d2510818 -r 422eaffeb92c doc/compilation.txt
--- a/doc/compilation.txt Tue May 18 14:22:39 2010 -0500
+++ b/doc/compilation.txt Thu May 20 07:44:44 2010 -0500
@@ -8,38 +8,136 @@
:depth: 3
:backlinks: top
-CMake
:Author: Mateusz Loskot
:Contact: mateusz at loskot dot net
+:Author: Howard Butler
+:Contact: hobu.inc at gmail dot com
-This article describes how to use `CMake`_ tool to build and install libLAS as
-well as run unit tests.
+As of libLAS 1.6, `CMake`_ 2.8.1+ is the prescribed tool for building
+libLAS from source as well as running unit tests. `CMake`_ is a cross-platform
+build system that provides a number of benefits, and its usage ensures a
+single, up-to-date build system for all libLAS-supported operating systems
+and compiler platforms.
-The CMake build configuration is available from the libLAS repository, in
-branch `main`.
+Like a combination of autoconf/autotools, except that it actually works on
+Windows (and works without eye-stabbing pain in general), `CMake`_ is somewhat
+of a meta-building tool. It can be used to generate MSVC project files, GNU
+Makefiles, NMake files for MSVC, XCode projects on Mac OS X, and Eclipse
+projects (as well as many others). This functionality allows the libLAS project
+to avoid maintaining these build options by hand and target a single configuration
+and build platform.
-Building libLAS using CMake on Unix
+This tutorial will describe how to build libLAS using CMake on both a
+Unix platform and a Windows platform.
+* Get the source code. See :ref:`source` for how to obtain the latest
+ development version or visit :ref:`download` to get the latest released
+ version.
+* Prepare a build directory. CMake allows you to generate different builders
+ for a project, and in this example, we are going to generate both "Unix Makefiles"
+ and "Xcode" builders for libLAS on Mac OS X.
+ $ cd liblas
+ $ mkdir makefiles
+CMake with "Unix Makefiles"
-* Check out source code
+* Configure the basic core library for the "Unix Makefiles" target:
- $ hg clone http://hg.liblas.org/main/
+ $ cmake -G "Unix Makefiles" ../
+ -- The C compiler identification is GNU
+ -- The CXX compiler identification is GNU
+ -- Checking whether C compiler has -isysroot
+ -- Checking whether C compiler has -isysroot - yes
+ -- Check for working C compiler: /usr/bin/gcc
+ -- Check for working C compiler: /usr/bin/gcc -- works
+ -- Detecting C compiler ABI info
+ -- Detecting C compiler ABI info - done
+ -- Checking whether CXX compiler has -isysroot
+ -- Checking whether CXX compiler has -isysroot - yes
+ -- Check for working CXX compiler: /usr/bin/c++
+ -- Check for working CXX compiler: /usr/bin/c++ -- works
+ -- Detecting CXX compiler ABI info
+ -- Detecting CXX compiler ABI info - done
+ -- Enable libLAS utilities to build - done
+ -- Configuring done
+ -- Generating done
+ -- Build files have been written to: /Users/hobu/hg/liblas-cmake/makefiles
-* Prepare build directory, possibly out of source tree
+* Run `make`
- $ mkdir build
- $ cd build
+ $ make
+ Scanning dependencies of target las
+ [ 3%] Building CXX object src/CMakeFiles/las.dir/lasclassification.cpp.o
+ [ 60%] Building CXX object src/CMakeFiles/las.dir/detail/writer/writer.cpp.o
+ Linking CXX static library ../bin/Debug/liblas.a
+ [ 60%] Built target las
+ Scanning dependencies of target las_c
+ [ 63%] Building CXX object src/CMakeFiles/las_c.dir/las_c_api.cpp.o
+ Linking CXX shared library ../bin/Debug/liblas_c.dylib
+ [ 63%] Built target las_c
+ Scanning dependencies of target las2las
+ [100%] Built target txt2las
-* Configure basic core library only
+* Run 'ccmake ../' for the `Curses`_ interface or 'cmake-gui ../' for a
+ GUI version.
+.. figure:: ./images/ccmake-osx-start.png
+ :alt: Running CCMake in OS X
+.. figure:: ./images/cmake-gui-osx-start.png
+ :alt: Running cmake-gui in OS X
+CMake using XCode
+ $ cd liblas
+ $ mkdir xcode
+ $ cd xcode/
+ $ cmake -G "Xcode" ..
+ -- Check for working CXX compiler: /usr/bin/g++
+ -- Check for working CXX compiler: /usr/bin/g++ -- works
+ -- Build files have been written to: /Users/hobu/hg/liblas-cmake/xcode
@@ -89,143 +187,7 @@
$ make
-Building libLAS and running unit tests using CMake on Unix
-Users are encourage to run libLAS unit tests and submit test results to
-dedicated `CDash`_ - utility dashboard hosted by the http://cdash.org website:
-* `libLAS CDash`_
-The CDash is another tool liblAS uses to perform `continuous integration`_
-during development process.
-.. note::
- In order to enable `CTest`_ support it is required to use `CMake 2.8.0+`_
- version (it is Beta currently).
-* Configure libLAS core library with unit tests and CTest enabled
- $ cmake ../main -DWITH_TESTS=ON -DENABLE_CTEST=ON
- -- The C compiler identification is GNU
- -- The CXX compiler identification is GNU
- -- Check for working C compiler: /usr/bin/gcc
- -- Check for working C compiler: /usr/bin/gcc -- works
- -- Detecting C compiler ABI info
- -- Detecting C compiler ABI info - done
- -- Check for working CXX compiler: /usr/bin/c++
- -- Check for working CXX compiler: /usr/bin/c++ -- works
- -- Detecting CXX compiler ABI info
- -- Detecting CXX compiler ABI info - done
- -- Enable libLAS utilities to build - done
- -- Enable libLAS unit tests to build - done
- -- Enable CTest to support submissions of results to CDash at http://cdash.org
- -- Enable CTest to support submissions of results to CDash at http://cdash.org - done
- -- Configuring done
- -- Generating done
- -- Build files have been written to: /home/mloskot/dev/liblas/_hg/build
-* Inspect available targets
- $ make help
- The following are some of the valid targets for this Makefile:
- ... all (the default if no target is provided)
- ... clean
- ... depend
- ... Continuous
- ... ContinuousBuild
- ... ContinuousConfigure
- ... ContinuousCoverage
- ... ContinuousMemCheck
- ... ContinuousStart
- ... ContinuousSubmit
- ... ContinuousTest
- ... ContinuousUpdate
- ... Experimental
- ... ExperimentalBuild
- ... ExperimentalConfigure
- ... ExperimentalCoverage
- ... ExperimentalMemCheck
- ... ExperimentalStart
- ... ExperimentalSubmit
- ... ExperimentalTest
- ... ExperimentalUpdate
- ... Nightly
- ... NightlyBuild
- ... NightlyConfigure
- ... NightlyCoverage
- ... NightlyMemCheck
- ... NightlyMemoryCheck
- ... NightlyStart
- ... NightlySubmit
- ... NightlyTest
- ... NightlyUpdate
- ... edit_cache
- ... install
- ... install/local
- ... install/strip
- ... list_install_components
- ... rebuild_cache
- ... test
- ... las
- ... las_c
- ... las2las
- ... las2txt
- ... lasinfo
- ... lasmerge
- ... txt2las
- ... liblas_test
-* Run `Continuous` target
- mloskot at dog:~/dev/liblas/_hg/build$ make Continuous
- Site: dog
- Build name: Linux-c++
- Create new tag: 20091025-0003 - Continuous
- Updating the repository
More information about the Liblas-commits
