[Liblas-commits] hg: more compilation doc work
liblas-commits at liblas.org liblas-commits at liblas.org
Thu May 20 16:57:41 EDT 2010
changeset 2832af382b4c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2832af382b4c
summary: more compilation doc work
diffstat:
 doc/compilation.txt |  249 +++++++++++++++++++++++++++++++++++++++++++++++----
 doc/download.txt    |    5 +-
 doc/index.txt       |    4 +-
 3 files changed, 234 insertions(+), 24 deletions(-)
diffs (truncated from 345 to 300 lines):
diff -r 5dfcb15cc06d -r 2832af382b4c doc/compilation.txt
--- a/doc/compilation.txt	Thu May 20 13:24:43 2010 -0500
+++ b/doc/compilation.txt	Thu May 20 15:57:34 2010 -0500
@@ -6,8 +6,6 @@
 .. contents::
     :depth: 3
-    :backlinks: top
 :Author: Mateusz Loskot
@@ -32,25 +30,108 @@
 This tutorial will describe how to build libLAS using CMake on both a
 Unix platform and a Windows platform.
+.. note::
+    The only supported build environment libLAS moving forward from the 1.6
+    release is `CMake`_. `Autoconf`_ configuration will be phased out and will
+    no longer be updated after the 1.6 release.
+Prerequisites
-* Get the source code.  See :ref:`source` for how to obtain the latest
-  development version or visit :ref:`download` to get the latest released
-  version.
+In addition to `CMake`_ 2.8.1+, you also need a C/C++ compiler.  The
+following compilers are known to work:
-* Prepare a build directory.  CMake allows you to generate different builders
-  for a project, and in this example, we are going to generate both "Unix Makefiles"
-  and "Xcode" builders for libLAS on Mac OS X.
+* MSVC 2003 (VC 7.1) (not all optional libraries work with 2003)
+* MSVC 2005 (VC 8.0)
+* MSVC 2008 (VC 9.0)
+* MSVC 2010
+* GCC 4.0
+* GCC 4.2
+* LLVM 4.2
+Optional libraries
+The base libLAS library can work without optional libraries to read and
+write LAS files, but linking in libraries like `GDAL`_, `libgeotiff`_, and
+`libspatialindex`_ will provide a boost in functionality to libLAS.
+libLAS linkage of GDAL and libgeotiff enhances spatial coordinate system
+description and provides data reprojection support.  libLAS linkage of
+libspatialindex allows libLAS to use an `R-tree`_ for bounds queries and
+filtering operations.  By linking `OCI`_ with the `Oracle Instant Client`_,
+libLAS can be used to load LAS data into `Oracle Point Cloud`_ -enabled
+Oracle tables.
+Building these libraries is beyond the scope of this document, but all except
+'OCI`_ can be built from source and installed at your leisure.
+`GDAL`_
+Obtain `GDAL`_ via whatever method is convenient.  Linux platforms such as
+`Debian`_ have `DebianGIS`_, Mac OS X has the `KyngChaos`_ software frameworks,
+and Windows has the `OSGeo4W`_ platform.
+`libgeotiff`_
+Obtain `libgeotiff`_ from the same place you got `GDAL`_.
+.. note::
+    `GDAL` surreptitiously embeds a copy of `libgeotiff`_ in its library build
+    but there is no way for you to know this.  In addition to embedding
+    libgeotiff, it also strips away the library symbols that libLAS needs,
+    meaning that libLAS can't simply link against `GDAL`_.  If you are
+    building both of these libraries yourself, make sure you build GDAL
+    using the "External libgeotiff" option, which will prevent the
+    insanity that can ensue on some platforms.  `OSGeo4W`_ users, including
+    those using that platform to link and build libLAS themselves, do
+    not need to worry about this issue.
+.. _`libgeotiff`: http://www.remotesensing.org/geotiff/geotiff.html
+.. _`7/28/2008`: http://lists.maptools.org/pipermail/geotiff/2008-July/000501.html
+.. _`proj.4`: http://proj.maptools.org/
+.. _`GDAL`: http://www.gdal.org
+.. _`libspatialindex`: http://trac.gispython.org/spatialindex/wiki
+.. _`Oracle Instant Client`: http://www.oracle.com/technology/tech/oci/instantclient/index.html
+.. _`OCI`: http://www.oracle.com/technology/tech/oci/index.html
+.. _`R-tree`: http://en.wikipedia.org/wiki/R-tree
+.. _`Oracle Point Cloud`: http://download.oracle.com/docs/cd/B28359_01/appdev.111/b28400/sdo_pc_pkg_ref.htm
+.. _`DebianGIS`: http://wiki.debian.org/DebianGis
+.. _`Debian`: http://www.debian.org
+.. _`KyngChaos`: http://www.kyngchaos.com/software/unixport
+.. _`OSGeo4W`: http://trac.osgeo.org/osgeo4w/
+Using "Unix Makefiles"
+Get the source code
+See :ref:`source` for how to obtain the latest development version or visit
+:ref:`download` to get the latest released version.
+Prepare a build directory
+CMake allows you to generate different builders for a project, and in this
+example, we are going to generate both "Unix Makefiles" and "Xcode" builders
+for libLAS on Mac OS X.
     $ cd liblas
     $ mkdir makefiles
-CMake with "Unix Makefiles"
+Configure base library
-* Configure the basic core library for the "Unix Makefiles" target:
+Configure the basic core library for the "Unix Makefiles" target:
@@ -74,7 +155,11 @@
     -- Generating done
     -- Build files have been written to: /Users/hobu/hg/liblas-cmake/makefiles
-* Run `make`
+Issue the `make` command
+This will build a base build of the library, with no extra libraries being
+configured.
@@ -97,20 +182,143 @@
     [100%] Built target txt2las
-* Run 'ccmake ../' for the `Curses`_ interface or 'cmake-gui ../' for a
-  GUI version.
+Run ``make install`` and test your installation with a :ref:`lasinfo` command
+``make install`` will install the :ref:`utilities <utilities>` in the location
+that was specified for 'CMAKE_INSTALL_PREFIX'.  Once installed, ensure that
+you can run lasinfo.
+    $ lasinfo -c ../test/data/TO_core_last_zoom.las
+      Header Summary
+      File Name: ../test/data/TO_core_last_zoom.las
+      Version:                    1.0
+      Source ID:                  0
+      Reserved:                   0
+      Project ID/GUID:           '00000000-0000-0000-0000-000000000000'
+      System Identifier:         ''
+      Generating Software:       'TerraScan'
+      File Creation Day/Year:    0/0
+      Header Size                227
+      Offset to Point Data       229
+      Number Var. Length Records 0
+      Point Data Format          1
+      Point Data Record Length   28
+      Number of Point Records    213093
+      Number of Points by Return 128621 84472 0 0 0
+      Scale Factor X Y Z         0.01 0.01 0.01
+      Offset X Y Z               -0.000000 -0.000000 -0.000000
+      Min X Y Z                  630250.000000 4834500.000000 46.830000
+      Max X Y Z                  630500.000000 4834750.000000 170.650000
+     Spatial Reference
+    Geotiff_Information:
+       Version: 1
+       Key_Revision: 1.0
+       Tagged_Information:
+          End_Of_Tags.
+       Keyed_Information:
+          End_Of_Keys.
+       End_Of_Geotiff.
+      Point Inspection Summary
+      Header Point Count: 213093
+      Actual Point Count: 213093
+      Minimum and Maximum Attributes (min,max)
+      Min X,Y,Z:        630250.000000,4834500.000000,46.830000
+      Max X,Y,Z:        630500.000000,4834750.000000,170.650000
+      Bounding Box:     630250.00,4834500.00,630500.00,4834750.00
+      Time:         413162.560400,414095.322000
+      Return Number:    1,2
+      Return Count:     1,2
+      Flightline Edge:  0,0
+      Intensity:        10,50200
+      Scan Direction Flag:  0,0
+      Scan Angle Rank:  0,0
+      Classification:   1,1
+      Point Source Id:  0,0
+      Minimum Color:     0 0 0
+      Maximum Color:     0 0 0
+        (0) 128621  (1) 84472   (2) 0   (3) 0   (4) 0
+     Total Points: 213093
+      Number of Returns by Pulse
+        (1) 128621  (2) 84472   (3) 0   (4) 0   (5) 0   (6) 0   (7) 0
+     Total Pulses: 213093
+      Point Classifications
+          213093 Unclassified (1)
+Configure your `Optional Libraries`_.
+By checking the "on" button for each, CMake may find your installations of
+these libraries, but in case it does not, set the following variables,
+substituting accordingly, to values that match your system layout.
+.. csv-table::
+    "`GDAL`_","GDAL_CONFIG", "/usr/local/bin/gdal-config"
+    "","GDAL_INCLUDE_DIR", "/usr/local/include"
+    "","GDAL_LIBRARY", "/usr/local/lib/libgdal.so"
+    "`libgeotiff`_","GEOTIFF_INCLUDE_DIR","/usr/local/include"
+    "","GEOTIFF_LIBRARY","/usr/local/lib/libgeotiff.so"
+    "`libspatialindex`_","SPATIALINDEX_INCLUDE_DIR","/usr/local/include"
+    "","SPATIALINDEX_LIBRARY","/usr/local/lib/libspatialindex_c.so"
+    "`OCI`_","ORACLE_INCLUDE_DIR","/home/oracle/sdk/include"
+    "","ORACLE_NNZ_LIBRARY","/home/oracle/libnnz10.so"
+    "","ORACLE_OCCI_LIBRARY","/home/oracle/libocci.so"
+    "","ORACLE_OCIEI_LIBRARY","/home/oracle/libociei.so"
+    "","ORACLE_OCI_LIBRARY","/home/oracle/libclntsh.so"
+.. note::
+    While `CMake`_ can be run from the command-line, and this is the preferred
+    way for many individuals, it can be much easier to run CMake from a GUI.
+    Now that we have a basic library building, we will use CMake's GUIs to
+    help us configure the rest of the optional components of the library. Run
+    ``ccmake ../`` for the `Curses`_ interface or ``cmake-gui ../`` for a GUI
+    version.
-.. figure:: ./images/ccmake-osx-start.png
-    :alt: Running CCMake in OS X
+    .. figure:: ./images/ccmake-osx-start.png
+        :alt: Running CCMake in OS X
+        Running the `Curses`_ `CMake`_ interface.  This interface is available to
+        all unix-like operating systems.
+        .. note::
+            If your arrow keys are not working with in CCMake, use CTRL-N and
+            CTRL-P to move back and forth between the options.
-.. figure:: ./images/cmake-gui-osx-start.png
-    :alt: Running cmake-gui in OS X
+    .. figure:: ./images/cmake-gui-osx-start.png
+        :alt: Running cmake-gui in OS X
+        Running the cmake-gui `CMake`_ interface.  This interface is available
+        on Linux, Windows, and Mac OS X.
 CMake using XCode
     $ cd liblas
     $ mkdir xcode
     $ cd xcode/
@@ -196,4 +404,5 @@
 .. _`CDash`: http://www.cdash.org/
 .. _`continuous integration`: http://en.wikipedia.org/wiki/Continuous_integration
 .. _`libLAS CDash`: http://my.cdash.org/index.php?project=libLAS
-.. _`Curses`: http://en.wikipedia.org/wiki/Curses_%28programming_library%29
\ No newline at end of file
More information about the Liblas-commits mailing list
