[Liblas-commits] hg: more doc work
liblas-commits at liblas.org liblas-commits at liblas.org
Thu May 20 23:16:16 EDT 2010
changeset b2a08acdc059 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=b2a08acdc059
summary: more doc work
diffstat:
 doc/compilation.txt |  59 ++++++++++++++++++++++++++++++++++------------------
 1 files changed, 38 insertions(+), 21 deletions(-)
diffs (81 lines):
diff -r 2832af382b4c -r b2a08acdc059 doc/compilation.txt
--- a/doc/compilation.txt	Thu May 20 15:57:34 2010 -0500
+++ b/doc/compilation.txt	Thu May 20 22:16:10 2010 -0500
@@ -6,6 +6,7 @@
 .. contents::
     :depth: 3
+    :backlinks: none
 :Author: Mateusz Loskot
@@ -287,32 +288,48 @@
     "","ORACLE_OCI_LIBRARY","/home/oracle/libclntsh.so"
-.. note::
-    While `CMake`_ can be run from the command-line, and this is the preferred
-    way for many individuals, it can be much easier to run CMake from a GUI.
-    Now that we have a basic library building, we will use CMake's GUIs to
-    help us configure the rest of the optional components of the library. Run
-    ``ccmake ../`` for the `Curses`_ interface or ``cmake-gui ../`` for a GUI
-    version.
+CCMake and cmake-gui
+While `CMake`_ can be run from the command-line, and this is the preferred
+way for many individuals, it can be much easier to run CMake from a GUI.
+Now that we have a basic library building, we will use CMake's GUIs to
+help us configure the rest of the optional components of the library. Run
+``ccmake ../`` for the `Curses`_ interface or ``cmake-gui ../`` for a GUI
+version.
-    .. figure:: ./images/ccmake-osx-start.png
-        :alt: Running CCMake in OS X
+.. figure:: ./images/ccmake-osx-start.png
+    :alt: Running CCMake in OS X
+    Running the `Curses`_ `CMake`_ interface.  This interface is available to
+    all unix-like operating systems.
-        Running the `Curses`_ `CMake`_ interface.  This interface is available to
-        all unix-like operating systems.
-        .. note::
-            If your arrow keys are not working with in CCMake, use CTRL-N and
-            CTRL-P to move back and forth between the options.
+.. note::
+    If your arrow keys are not working with in CCMake, use CTRL-N and
+    CTRL-P to move back and forth between the options.
-    .. figure:: ./images/cmake-gui-osx-start.png
-        :alt: Running cmake-gui in OS X
-        Running the cmake-gui `CMake`_ interface.  This interface is available
-        on Linux, Windows, and Mac OS X.
+.. figure:: ./images/cmake-gui-osx-start.png
+    :alt: Running cmake-gui in OS X
+    Running the cmake-gui `CMake`_ interface.  This interface is available
+    on Linux, Windows, and Mac OS X.
+Build and install
+Once you have configured your additional libraries, you can install the
+software.  The main pieces that will be installed are:
+* libLAS headers (typically in a location ./include/liblas/...)
+* libLAS C++ (liblas.a or liblas.so) library
+* libLAS C (liblas_c.a or liblas_c.so) library
+* :ref:`Utility <utilities>` programs
+    make install
 CMake using XCode
More information about the Liblas-commits mailing list
