[Liblas-commits] hg: osx cmake example
liblas-commits at liblas.org liblas-commits at liblas.org
Fri May 21 13:45:13 EDT 2010
changeset 57cff46f6fc2 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=57cff46f6fc2
summary: osx cmake example
diffstat:
 doc/compilation.txt                         |   92 ++++++++++++++++++++++++++-
 doc/images/cmake-gui-osx-configured.png     |    0
 doc/images/xcode-lasinfo-arguments.png      |    0
 doc/images/xcode-lasinfo-output.png         |    0
 doc/images/xcode-set-default-executable.png |    0
 doc/images/xcode-start.png                  |    0
 6 files changed, 86 insertions(+), 6 deletions(-)
diffs (170 lines):
diff -r d9215b9a9929 -r 57cff46f6fc2 doc/compilation.txt
--- a/doc/compilation.txt	Fri May 21 10:03:12 2010 -0500
+++ b/doc/compilation.txt	Fri May 21 12:44:54 2010 -0500
@@ -50,6 +50,8 @@
 * GCC 4.2
 * LLVM 4.2
+.. _optional_libraries:
 Optional libraries
@@ -121,7 +123,7 @@
 CMake allows you to generate different builders for a project, and in this
-example, we are going to generate both "Unix Makefiles" and "Xcode" builders
+example, we are going to generate a "Unix Makefiles" builder
 for libLAS on Mac OS X.
@@ -183,6 +185,8 @@
     [100%] Built target txt2las
+.. _make_install:
 Run ``make install`` and test your installation with a :ref:`lasinfo` command
@@ -264,6 +268,7 @@
           213093 Unclassified (1)
+.. _configure_optional_libraries:
 Configure your `Optional Libraries`_.
@@ -334,12 +339,34 @@
 CMake using XCode
+Get the source code
+See :ref:`source` for how to obtain the latest development version or visit
+:ref:`download` to get the latest released version.
+Prepare a build directory
+CMake allows you to generate different builders for a project, and in this
+example, we are going to generate an "Xcode" builder for libLAS on Mac OS X.
+Additionally, we're going to use an alternative compiler -- `LLVM`_ -- which
+under certain situations can produce much faster code on Mac OS X.
+    $ export CC=/usr/bin/llvm-gcc
+    $ export CXX=/usr/bin/llvm-g++
     $ cd liblas
     $ mkdir xcode
     $ cd xcode/
+Configure base library
+Configure the basic core library for the Xcode build:
     $ cmake -G "Xcode" ..
@@ -347,21 +374,73 @@
     -- The CXX compiler identification is GNU
     -- Checking whether C compiler has -isysroot
     -- Checking whether C compiler has -isysroot - yes
-    -- Check for working C compiler: /usr/bin/gcc
-    -- Check for working C compiler: /usr/bin/gcc -- works
+    -- Check for working C compiler: /usr/bin/llvm-gcc
+    -- Check for working C compiler: /usr/bin/llvm-gcc -- works
     -- Detecting C compiler ABI info
     -- Detecting C compiler ABI info - done
     -- Checking whether CXX compiler has -isysroot
     -- Checking whether CXX compiler has -isysroot - yes
-    -- Check for working CXX compiler: /usr/bin/g++
-    -- Check for working CXX compiler: /usr/bin/g++ -- works
+    -- Check for working CXX compiler: /usr/bin/llvm-g++
+    -- Check for working CXX compiler: /usr/bin/llvm-g++ -- works
     -- Detecting CXX compiler ABI info
     -- Detecting CXX compiler ABI info - done
     -- Enable libLAS utilities to build - done
+    -- Enable libLAS unit tests to build - done
     -- Configuring done
     -- Generating done
     -- Build files have been written to: /Users/hobu/hg/liblas-cmake/xcode
+    $ open libLAS.xcodeproj/
+.. figure:: ./images/xcode-start.png
+    :alt: Building libLAS using the XCode project
+Set default command for XCode
+Set the default executable for the project to be ``lasinfo`` by opening the
+"Executables" tree, choosing "lasinfo," and clicking the bubble next to
+the "Executable name" in the right-hand panel.
+.. figure:: ./images/xcode-set-default-executable.png
+    :alt: Setting the default executable
+Set arguments for :ref:`lasinfo`
+Set the arguments for :ref:`lasinfo` so it can be run from within XCode. We
+use the ${PROJECT_DIR} environment variable to be able to tell lasinfo the
+location of our test file. This is similar to the :ref:`same command
+<make_install>` above in the "Unix Makefiles" section.
+.. figure:: ./images/xcode-lasinfo-arguments.png
+    :alt: Setting the arguments for lasinfo
+Build and run the :ref:`lasinfo` command
+Open the console by pressing CMD-SHIFT-R or by navigating to the Run-Console
+menu and press the `Build and Run` button.
+.. figure:: ./images/xcode-lasinfo-output.png
+    :alt: lasinfo output in XCode
+Configure `Optional Libraries`_
+As :ref:`before <configure_optional_libraries>`, use ``ccmake ../`` or ``cmake-gui ../`` to
+configure your :ref:`optional_libraries`.
+.. figure:: ./images/cmake-gui-osx-configured.png
+    :alt: Configuring optional libraries with CMake GUI
+    Configuring `Optional Libraries`_ with CMake GUI
@@ -422,4 +501,5 @@
 .. _`continuous integration`: http://en.wikipedia.org/wiki/Continuous_integration
 .. _`libLAS CDash`: http://my.cdash.org/index.php?project=libLAS
 .. _`Curses`: http://en.wikipedia.org/wiki/Curses_%28programming_library%29
-.. _`Autoconf`: http://www.gnu.org/software/autoconf/
\ No newline at end of file
+.. _`Autoconf`: http://www.gnu.org/software/autoconf/
+.. _`LLVM`: http://llvm.org/
diff -r d9215b9a9929 -r 57cff46f6fc2 doc/images/cmake-gui-osx-configured.png
Binary file doc/images/cmake-gui-osx-configured.png has changed
diff -r d9215b9a9929 -r 57cff46f6fc2 doc/images/xcode-lasinfo-arguments.png
Binary file doc/images/xcode-lasinfo-arguments.png has changed
diff -r d9215b9a9929 -r 57cff46f6fc2 doc/images/xcode-lasinfo-output.png
Binary file doc/images/xcode-lasinfo-output.png has changed
diff -r d9215b9a9929 -r 57cff46f6fc2 doc/images/xcode-set-default-executable.png
Binary file doc/images/xcode-set-default-executable.png has changed
diff -r d9215b9a9929 -r 57cff46f6fc2 doc/images/xcode-start.png
Binary file doc/images/xcode-start.png has changed
More information about the Liblas-commits mailing list
