[Liblas-commits] hg: VLR key info
liblas-commits at liblas.org
Fri May 21 14:21:54 EDT 2010
changeset 249a0797bf7d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=249a0797bf7d
summary: VLR key info
diffstat:
doc/development/specifications.txt | 7 +++++++
1 files changed, 7 insertions(+), 0 deletions(-)
diffs (17 lines):
diff -r 57cff46f6fc2 -r 249a0797bf7d doc/development/specifications.txt
--- a/doc/development/specifications.txt Fri May 21 12:44:54 2010 -0500
+++ b/doc/development/specifications.txt Fri May 21 13:21:48 2010 -0500
@@ -14,6 +14,13 @@
* `ASPRS LAS 1.1`_
* `ASPRS LAS 1.0`_
+VLR Key
+libLAS' VLR key is ``1209`` with keyname ``liblas``
+http://www.asprs.org/society/committees/lidar/lidar_format_keylist.html
.. _`ASPRS LAS 1.3`: http://liblas.org/_static/specifications/asprs_las_format_v13.pdf
.. _`ASPRS LAS 1.2`: http://liblas.org/_static/specifications/asprs_las_format_v12.pdf
.. _`ASPRS LAS 1.1`: http://liblas.org/_static/specifications/asprs_las_format_v11.pdf
More information about the Liblas-commits
