[Liblas-commits] hg: more xcode documentation
liblas-commits at liblas.org liblas-commits at liblas.org
Fri May 21 15:20:57 EDT 2010
changeset 52814339c0a1 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=52814339c0a1
summary: more xcode documentation
diffstat:
 doc/compilation.txt |  31 ++++++++++++++++++++++++++++---
 1 files changed, 28 insertions(+), 3 deletions(-)
diffs (62 lines):
diff -r 249a0797bf7d -r 52814339c0a1 doc/compilation.txt
--- a/doc/compilation.txt	Fri May 21 13:21:48 2010 -0500
+++ b/doc/compilation.txt	Fri May 21 14:20:39 2010 -0500
@@ -66,7 +66,7 @@
 Oracle tables.
 Building these libraries is beyond the scope of this document, but all except
-'OCI`_ can be built from source and installed at your leisure.
+`OCI`_ can be built from source and installed at your leisure.
 `GDAL`_
@@ -92,6 +92,31 @@
     those using that platform to link and build libLAS themselves, do
     not need to worry about this issue.
+`libspatialindex`_
+Obtain `libspatialindex`_ and install using a typical ``./configure; make; make install``
+installation procedure.  It does not have any dependent libraries.  It is also
+available via `DebianGIS`_ and `OSGeo4W`_ as a binary.
+`OCI`_
+Obtain the `Oracle Instant Client`_ and install in a location on your system.
+Be sure to install both the "Basic" and the "SDK" modules. Set your
+``ORACLE_HOME`` environment variable system- or user-wide to point to this
+location so the CMake configuration can find your install.
+.. warning::
+    `OCI`_'s libraries are inconsistently named.  You may need to create
+    symbolic links for some library names in order for the `CMake`_ to find
+    them::
+        cd $ORACLE_HOME
+        ln -s libocci.so.10.1 libocci.so
+        ln -s libclntsh.so.10.1 libclntsh.so
+        ln -s libociei.so.10.1 libociei.so
 .. _`libgeotiff`: http://www.remotesensing.org/geotiff/geotiff.html
 .. _`7/28/2008`: http://lists.maptools.org/pipermail/geotiff/2008-July/000501.html
 .. _`proj.4`: http://proj.maptools.org/
@@ -110,7 +135,7 @@
-Using "Unix Makefiles"
+Using "Unix Makefiles" on Linux
 Get the source code
@@ -336,7 +361,7 @@
     make install
-CMake using XCode
+Using "XCode" on OS X
More information about the Liblas-commits mailing list
