[Liblas-commits] hg: more windows compilation doc work
liblas-commits at liblas.org
Mon May 24 15:18:49 EDT 2010
changeset 75db102ef798 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=75db102ef798
summary: more windows compilation doc work
diffstat:
doc/compilation.txt | 74 +++++++++++++++++++++++++++++++++++++++++++++-------
1 files changed, 64 insertions(+), 10 deletions(-)
diffs (99 lines):
diff -r ef1cb9adc93c -r 75db102ef798 doc/compilation.txt
--- a/doc/compilation.txt Mon May 24 13:16:45 2010 -0600
+++ b/doc/compilation.txt Mon May 24 14:18:42 2010 -0500
@@ -471,25 +471,78 @@
Using "Visual Studio 9 2008" on Windows
+.. _msvc_prerequisites:
Prerequisites
* Ensure that you have `CMake 2.8.0+`_ installed on your system.
-* Make sure you run `CMake`_ from a "Visual Studio 2008 Command Prompt"
+* Install `OSGeo4W`_ on your system to get `Optional Libraries`_ in
+ pre-compiled form. You can build these from source yourself, but it is
+ much more convenient to get them from OSGeo4W.
- .. note::
- This can be found by navigating through the start bar to
- "Start" -- "Microsoft Visual Studio 2008" -- "Visual Studio Tools " --
- "Visual Studio 2008 Command Prompt". This command prompt sets
- a number of environment variables necessary for Visual Studio to
- run, and `CMake`_ must have these variables set in order for it to
+ * gdal-dev
+ * libspatialindex
+ * libspatialindex-devel
+ * libtiff
+ * libgeotiff
+ .. figure:: ./images/windows-osgeo4w-advanced-install.png
+ :alt: OSGeo4W installation
+ Choose the "Advanced install" to be able to pick the libraries
+ and their headers that you need.
+ .. figure:: ./images/windows-osgeo4w-choosing-packages.png
+ :alt: Choosing libraries
+ Open up the "Libs" tree and choose the libraries you need
+Run ``cmake-gui.exe``
+* Run ``cmake-gui.exe`` from a "Visual Studio 2008 Command Prompt"
+ cd d:\liblas
+ cmake-gui .
+.. figure:: ./images/windows-cmake-start.png
+ :alt: Starting CMake
+ Upon opening cmake-gui, nothing will be configured.
+ .. note::
+ The Visual Studio Prompt can be found by navigating through the start
+ bar to "Start" -- "Microsoft Visual Studio 2008" -- "Visual Studio
+ Tools " -- "Visual Studio 2008 Command Prompt". This command prompt
+ sets a number of environment variables necessary for Visual Studio to
+ run, and `CMake`_ must have these variables set in order for it to
work properly.
+ .. figure:: ./images/windows-command-prompt.png
+ :alt: Visual Studio Command prompt
- .. figure:: ./images/windows-command-prompt.png
- :alt: Visual Studio Command prompt
+.. figure:: ./images/windows-cmake-generator-visual-studio-9.png
+ :alt: Generating a project
+* Click "Configure" and a window will pop up asking what type of build to
+ generate. Choose "Visual Studio 9 2008."
+* Click "Generate" and a "libLAS.sln" file will be in ``d:\liblas``
+* Open and build the project
+.. image:: ./images/windows-msvc-build.png
.. _`CMake`: http://www.cmake.org/
.. _`CTest`: http://cmake.org/cmake/help/ctest-2-8-docs.html
@@ -499,4 +552,5 @@
.. _`libLAS CDash`: http://my.cdash.org/index.php?project=libLAS
.. _`Curses`: http://en.wikipedia.org/wiki/Curses_%28programming_library%29
.. _`Autoconf`: http://www.gnu.org/software/autoconf/
-.. _`LLVM`: http://llvm.org/
\ No newline at end of file
+.. _`LLVM`: http://llvm.org/
+.. _`OSGeo4W`: http://trac.osgeo.org/osgeo4w/
More information about the Liblas-commits
