[Liblas-commits] hg: more doc work
liblas-commits at liblas.org
Mon May 24 17:33:37 EDT 2010
changeset 6c1bc65e8004 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=6c1bc65e8004
summary: more doc work
diffstat:
apps/las2las2.cpp | 1 +
doc/_static/ASPRS-Workshop-NOAA-Demo.pdf | 0
doc/_static/LAS-1.0-1.3-feature-matrix.pdf | 0
doc/_static/files/ASPRS-Workshop-NOAA-Demo.pdf | 0
doc/_static/files/LAS-1.0-1.3-feature-matrix.pdf | 0
doc/_static/files/liblas_foss4g_2008.pdf | 0
doc/_static/files/specifications/asprs_las_format_v10.pdf | 0
doc/_static/files/specifications/asprs_las_format_v11.pdf | 0
doc/_static/files/specifications/asprs_las_format_v12.pdf | 0
doc/_static/files/specifications/asprs_las_format_v13.pdf | 0
doc/_static/liblas_foss4g_2008.pdf | 0
doc/_static/specifications/asprs_las_format_v10.pdf | 0
doc/_static/specifications/asprs_las_format_v11.pdf | 0
doc/_static/specifications/asprs_las_format_v12.pdf | 0
doc/_static/specifications/asprs_las_format_v13.pdf | 0
doc/development/format_elements.txt | 6 +-
doc/download.txt | 4 +-
doc/images/windows-cmake-generator-makefiles.png | 0
doc/images/windows-cmake-generator-visual-studio-9.png | 0
doc/images/windows-cmake-start.png | 0
doc/images/windows-msvc-build.png | 0
doc/index.txt | 1 -
doc/tutorial/python.txt | 5 -
doc/tutorial/qhull.txt | 48 +++++++-------
24 files changed, 31 insertions(+), 34 deletions(-)
diffs (190 lines):
diff -r 75db102ef798 -r 6c1bc65e8004 apps/las2las2.cpp
--- a/apps/las2las2.cpp Mon May 24 14:18:42 2010 -0500
+++ b/apps/las2las2.cpp Mon May 24 16:32:11 2010 -0500
@@ -247,3 +247,4 @@
return rc;
+//las2las2 -i lt_srs_rt.las -o foo.las -c 1,2 -b 2483590,366208,2484000,366612
diff -r 75db102ef798 -r 6c1bc65e8004 doc/_static/ASPRS-Workshop-NOAA-Demo.pdf
Binary file doc/_static/ASPRS-Workshop-NOAA-Demo.pdf has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/_static/LAS-1.0-1.3-feature-matrix.pdf
Binary file doc/_static/LAS-1.0-1.3-feature-matrix.pdf has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/_static/files/ASPRS-Workshop-NOAA-Demo.pdf
Binary file doc/_static/files/ASPRS-Workshop-NOAA-Demo.pdf has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/_static/files/LAS-1.0-1.3-feature-matrix.pdf
Binary file doc/_static/files/LAS-1.0-1.3-feature-matrix.pdf has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/_static/files/liblas_foss4g_2008.pdf
Binary file doc/_static/files/liblas_foss4g_2008.pdf has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/_static/files/specifications/asprs_las_format_v10.pdf
Binary file doc/_static/files/specifications/asprs_las_format_v10.pdf has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/_static/files/specifications/asprs_las_format_v11.pdf
Binary file doc/_static/files/specifications/asprs_las_format_v11.pdf has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/_static/files/specifications/asprs_las_format_v12.pdf
Binary file doc/_static/files/specifications/asprs_las_format_v12.pdf has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/_static/files/specifications/asprs_las_format_v13.pdf
Binary file doc/_static/files/specifications/asprs_las_format_v13.pdf has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/_static/liblas_foss4g_2008.pdf
Binary file doc/_static/liblas_foss4g_2008.pdf has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/_static/specifications/asprs_las_format_v10.pdf
Binary file doc/_static/specifications/asprs_las_format_v10.pdf has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/_static/specifications/asprs_las_format_v11.pdf
Binary file doc/_static/specifications/asprs_las_format_v11.pdf has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/_static/specifications/asprs_las_format_v12.pdf
Binary file doc/_static/specifications/asprs_las_format_v12.pdf has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/_static/specifications/asprs_las_format_v13.pdf
Binary file doc/_static/specifications/asprs_las_format_v13.pdf has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/development/format_elements.txt
--- a/doc/development/format_elements.txt Mon May 24 14:18:42 2010 -0500
+++ b/doc/development/format_elements.txt Mon May 24 16:32:11 2010 -0500
@@ -10,7 +10,7 @@
On this page, elements and attributes of LAS Format 1.0 and 1.1 are compared.
.. seealso::
- The `LAS 1.0-1.3 Permuation matrix <http://liblas.org/_static/LAS-1.0-1.3-feature-matrix.pdf>`__
+ The `LAS 1.0-1.3 Permuation matrix`_
contains a detailed description of LAS header and point discrepancies
between versions in addition to this (older) document.
@@ -158,4 +158,6 @@
(1) FileMarker from 1.0 has been renamed to User Data in 1.1 and is available for any use.
-(2) User Bit Field from 1.0 has been renamed to Point Source ID in 1.1 and marked as required.
\ No newline at end of file
+(2) User Bit Field from 1.0 has been renamed to Point Source ID in 1.1 and marked as required.
+.. _`LAS 1.0-1.3 Permuation matrix`: ../_static/LAS-1.0-1.3-feature-matrix.pdf
diff -r 75db102ef798 -r 6c1bc65e8004 doc/download.txt
--- a/doc/download.txt Mon May 24 14:18:42 2010 -0500
+++ b/doc/download.txt Mon May 24 16:32:11 2010 -0500
@@ -20,7 +20,7 @@
- `liblas-1.2.1-win32 <http://trac.liblas.org/raw-attachment/wiki/1.2.1/liblas-1.2.1-win32.zip>`_
`(md5) <http://trac.liblas.org/raw-attachment/wiki/1.2.1/liblas-1.2.1-win32.zip.md5>`__
- - `Release Notes <http://trac.liblas.org/wiki/1.2.1>`_
+ - `Release Notes <http://trac.liblas.org/wiki/1.2.1>`__
.. _`liblas-src-1.2.1.tar.gz`: http://trac.liblas.org/raw-attachment/wiki/1.2.1/liblas-src-1.2.1.tar.gz
@@ -43,7 +43,7 @@
- `liblas-1.2.0-win32 <http://trac.liblas.org/raw-attachment/wiki/1.2.0/liblas-1.2.0-win32.zip>`_
`(md5) <http://trac.liblas.org/raw-attachment/wiki/1.2.0/liblas-1.2.0-win32.zip.md5>`__
- - `Release Notes <http://trac.liblas.org/wiki/1.2.0>`_
+ - `Release Notes <http://trac.liblas.org/wiki/1.2.0>`__
.. _`liblas-src-1.2.0.tar.gz`: http://trac.liblas.org/raw-attachment/wiki/1.2.0/liblas-src-1.2.0.tar.gz
diff -r 75db102ef798 -r 6c1bc65e8004 doc/images/windows-cmake-generator-makefiles.png
Binary file doc/images/windows-cmake-generator-makefiles.png has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/images/windows-cmake-generator-visual-studio-9.png
Binary file doc/images/windows-cmake-generator-visual-studio-9.png has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/images/windows-cmake-start.png
Binary file doc/images/windows-cmake-start.png has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/images/windows-msvc-build.png
Binary file doc/images/windows-msvc-build.png has changed
diff -r 75db102ef798 -r 6c1bc65e8004 doc/index.txt
--- a/doc/index.txt Mon May 24 14:18:42 2010 -0500
+++ b/doc/index.txt Mon May 24 16:32:11 2010 -0500
@@ -66,7 +66,6 @@
.. _`LAStools`: http://www.cs.unc.edu/~isenburg/lastools/
.. _`Martin Isenburg and Jonathan Shewchuk`: http://www.cs.unc.edu/~isenburg/lastools/
.. _`LAS Format`: http://www.lasformat.org/
-.. _`LAS permutation matrix`: http://liblas.org/raw-attachment/wiki/WikiStart/LAS-1.0-1.3-feature-matrix.pdf
.. _`ASPRS Standards Committee`: http://www.asprs.org/society/committees/standards/lidar_exchange_format.html
.. _`ASPRS LAS format`: http://www.asprs.org/society/committees/standards/lidar_exchange_format.html
diff -r 75db102ef798 -r 6c1bc65e8004 doc/tutorial/python.txt
--- a/doc/tutorial/python.txt Mon May 24 14:18:42 2010 -0500
+++ b/doc/tutorial/python.txt Mon May 24 16:32:11 2010 -0500
@@ -215,8 +215,3 @@
>>> f.write(pt)
>>> f.close()
-Examples
-* Extracting specific classes from a file `PyExtractClass`:trac:
diff -r 75db102ef798 -r 6c1bc65e8004 doc/tutorial/qhull.txt
--- a/doc/tutorial/qhull.txt Mon May 24 14:18:42 2010 -0500
+++ b/doc/tutorial/qhull.txt Mon May 24 16:32:11 2010 -0500
@@ -37,51 +37,51 @@
-$ las2txt --stdout --parse xyz cloud.las > points.txt
-$ cat points.txt | wc -l > count.txt
-$ echo "3" > dimension.txt
-$ cat dimension.txt count.txt points.txt > qhull_input.txt
-$ head -n4 qhull_input.txt
-3
-213093
-630499.95 4834749.17 62.15
-630499.83 4834748.88 62.68
+ $ las2txt --stdout --parse xyz cloud.las > points.txt
+ $ cat points.txt | wc -l > count.txt
+ $ echo "3" > dimension.txt
+ $ cat dimension.txt count.txt points.txt > qhull_input.txt
+ $ head -n4 qhull_input.txt
+ 3
+ 213093
+ 630499.95 4834749.17 62.15
+ 630499.83 4834748.88 62.68
Now, file 'qhull_input.txt' is ready to use with 'qhull' program:
-$ qhull s < qhull_input.txt
+ $ qhull s < qhull_input.txt
-Convex hull of 213093 points in 3-d:
+ Convex hull of 213093 points in 3-d:
- Number of vertices: 149
- Number of facets: 282
- Number of non-simplicial facets: 4
+ Number of vertices: 149
+ Number of facets: 282
+ Number of non-simplicial facets: 4
-Statistics for: | qhull s
+ Statistics for: | qhull s
- Number of points processed: 172
- Number of hyperplanes created: 795
- Number of distance tests for qhull: 2430368
- Number of distance tests for merging: 3484
- Number of distance tests for checking: 3890
- Number of merged facets: 12
- CPU seconds to compute hull (after input): 0.07
+ Number of points processed: 172
+ Number of hyperplanes created: 795
+ Number of distance tests for qhull: 2430368
+ Number of distance tests for merging: 3484
+ Number of distance tests for checking: 3890
+ Number of merged facets: 12
+ CPU seconds to compute hull (after input): 0.07
and output calculated actual convex hull geometry:
-$ qhull s n TO qhull.txt < qhull_input.txt
+ $ qhull s n TO qhull.txt < qhull_input.txt
Outputting data for qhull programs with C++
Alternatively, one may need to output LAS file to qhull input format using
Python script or C++ program. Here is example of how to do program it in C++
-using libLAS :ref:`reader and iterator <cpp_tutorial>:
+using libLAS :ref:`reader and iterator <cpptutorial>`:
.. code-block:: cpp
More information about the Liblas-commits
