[Liblas-commits] hg: complete a working but ugly implementation of --point-translate
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Nov 3 15:50:01 EDT 2010
changeset 6f96b326bc0e in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=6f96b326bc0e
summary: complete a working but ugly implementation of --point-translate
diffstat:
 include/liblas/lastransform.hpp |   16 +++-
 src/lastransform.cpp            |  112 ++++++++++++++++++++++++++++++++-------
 2 files changed, 102 insertions(+), 26 deletions(-)
diffs (189 lines):
diff -r b75eee10bb92 -r 6f96b326bc0e include/liblas/lastransform.hpp
--- a/include/liblas/lastransform.hpp	Wed Nov 03 11:33:45 2010 -0500
+++ b/include/liblas/lastransform.hpp	Wed Nov 03 14:49:52 2010 -0500
@@ -125,18 +125,24 @@
     ~TranslationTransform();
     bool transform(Point& point);
+    enum OPER_TYPE
+        eOPER_MULTIPLY = 0,
+        eOPER_DIVIDE = 1,
+        eOPER_SUBTRACT = 2,
+        eOPER_ADD = 3,
+        eOPER_NONE = -99
     // Yes, Mateusz, I'm embarassed by this :)
     struct operation{
-        bool multiply;
-        bool divide;
-        bool subtract;
-        bool add;
+        OPER_TYPE oper;
         std::string dimension;
         double value;
         std::string expression;
-        operation(std::string name) : multiply(false), divide(false), subtract(false), add(false), dimension(name), value(0.0)
+        operation(std::string name) : oper(eOPER_NONE), dimension(name), value(0.0)
diff -r b75eee10bb92 -r 6f96b326bc0e src/lastransform.cpp
--- a/src/lastransform.cpp	Wed Nov 03 11:33:45 2010 -0500
+++ b/src/lastransform.cpp	Wed Nov 03 14:49:52 2010 -0500
@@ -170,29 +170,12 @@
     boost::char_separator<char> sep_space(" ");
     tokenizer dimensions(expression, sep_space);
-    boost::char_separator<char> sep_star("*");
-    boost::char_separator<char> sep_dash("-");
-    boost::char_separator<char> sep_plus("+");
-    boost::char_separator<char> sep_div("/");
-    boost::uint32_t dimension_size = 0;
     for (tokenizer::iterator t = dimensions.begin(); t != dimensions.end(); ++t) {
-        std::cout << "token: " << *t;
         std::string const& s = *t;
         operation op = GetOperation(s);
         operations.push_back(op);
-        dimension_size++;
-    std::cout << std::endl;
-    std::cout << dimension_size << std::endl;
@@ -262,24 +245,24 @@
     std::string::size_type data_pos = std::string::npos;
     if (found_star != std::string::npos)
-        output.multiply = true;
+        output.oper = eOPER_MULTIPLY;
         data_pos = expression.find_last_of(star) + 1;
     if (found_divide != std::string::npos)
-        output.divide = true;
+        output.oper = eOPER_DIVIDE;
         data_pos = expression.find_last_of(divide) + 1;
     if (found_plus != std::string::npos)
-        output.add = true;
+        output.oper = eOPER_ADD;
         data_pos = expression.find_last_of(plus) + 1;
     if (found_minus != std::string::npos)
-        output.subtract = true;
+        output.oper = eOPER_SUBTRACT;
         data_pos = expression.find_last_of(minus) + 1;
@@ -302,6 +285,93 @@
 bool TranslationTransform::transform(Point& point)
+    for(std::vector<TranslationTransform::operation>::const_iterator op = operations.begin();
+        op != operations.end();
+        op++)
+        switch (op->oper)
+                case eOPER_MULTIPLY:
+                    if (!op->dimension.compare("X"))
+                        point.SetX(point.GetX() * op->value);
+                    if (!op->dimension.compare("Y"))
+                        point.SetY(point.GetY() * op->value);
+                    if (!op->dimension.compare("Z"))
+                        point.SetZ(point.GetZ() * op->value);
+                    break;
+                case eOPER_DIVIDE:
+                        point.SetX(point.GetX() / op->value);
+                        point.SetY(point.GetY() / op->value);
+                        point.SetZ(point.GetZ() / op->value);
+                    break;
+                case eOPER_ADD:
+                        point.SetX(point.GetX() + op->value);
+                        point.SetY(point.GetY() + op->value);
+                        point.SetZ(point.GetZ() + op->value);
+                    break;
+                case eOPER_SUBTRACT:
+                        point.SetX(point.GetX() - op->value);
+                        point.SetY(point.GetY() - op->value);
+                        point.SetZ(point.GetZ() - op->value);
+                    break;
+                default:
+                    std::ostringstream oss;
+                    oss << "Unhandled expression operation id " << static_cast<boost::int32_t>(op->oper);
+                    throw std::runtime_error(oss.str());
+    if (detail::compare_distance(point.GetRawX(), std::numeric_limits<boost::int32_t>::max()) ||
+        detail::compare_distance(point.GetRawX(), std::numeric_limits<boost::int32_t>::min())) {
+        throw std::domain_error("X scale and offset combination of this file is insufficient to represent the data given the expression ");
+    if (detail::compare_distance(point.GetRawY(), std::numeric_limits<boost::int32_t>::max()) ||
+        detail::compare_distance(point.GetRawY(), std::numeric_limits<boost::int32_t>::min())) {
+        throw std::domain_error("Y scale and offset combination of this file is insufficient to represent the data given the expression");
+    if (detail::compare_distance(point.GetRawZ(), std::numeric_limits<boost::int32_t>::max()) ||
+        detail::compare_distance(point.GetRawZ(), std::numeric_limits<boost::int32_t>::min())) {
+        throw std::domain_error("Z scale and offset combination of this file is insufficient to represent the data given the expression");
     return true;
More information about the Liblas-commits mailing list
