[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Thu Nov 4 10:22:20 EDT 2010
changeset a2a2c9deed0c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a2a2c9deed0c
summary: more verbose output
changeset 7584c0069580 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=7584c0069580
summary: use the writer's header for ReprojectionTransform
diffstat:
apps/las2las-old.c | 4 ++--
src/laswriter.cpp | 2 +-
2 files changed, 3 insertions(+), 3 deletions(-)
diffs (33 lines):
diff -r 6f96b326bc0e -r 7584c0069580 apps/las2las-old.c
--- a/apps/las2las-old.c Wed Nov 03 14:49:52 2010 -0500
+++ b/apps/las2las-old.c Thu Nov 04 09:22:07 2010 -0500
@@ -880,7 +880,7 @@
} else {
if (verbose) {
fprintf(stderr,
- "Setting xyz offset to commandline-assigned values...\n");
+ "Setting xyz offset to %.8f %.8f %.8f...\n", xyz_offset[0], xyz_offset[1], xyz_offset[2]);
LASHeader_SetOffset(surviving_header,
xyz_offset[0],
@@ -892,7 +892,7 @@
if (do_set_scale) {
if (verbose) {
fprintf(stderr,
- "Setting xyz scale...\n");
+ "Setting xyz scale to %.8f %.8f %.8f...\n", xyz_scale[0], xyz_scale[1], xyz_scale[2]);
LASHeader_SetScale( surviving_header,
xyz_scale[0],
diff -r 6f96b326bc0e -r 7584c0069580 src/laswriter.cpp
--- a/src/laswriter.cpp Wed Nov 03 14:49:52 2010 -0500
+++ b/src/laswriter.cpp Thu Nov 04 09:22:07 2010 -0500
@@ -187,7 +187,7 @@
// overwrite our reprojection transform
- m_reprojection_transform = TransformPtr(new ReprojectionTransform(m_in_srs, m_out_srs));
+ m_reprojection_transform = TransformPtr(new ReprojectionTransform(m_in_srs, m_out_srs, m_header));
if (m_transforms != 0) {
if (m_transforms->size() > 0) {
More information about the Liblas-commits
