[Liblas-commits] hg: fix OpenInput and remove liblas_kernel as an installable ent...
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Nov 22 13:16:33 EST 2010
changeset 5ac9800e2d83 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=5ac9800e2d83
summary: fix OpenInput and remove liblas_kernel as an installable entity.  This wasn't working
diffstat:
 apps/CMakeLists.txt              |  21 +++++------------
 apps/laskernel.hpp               |   2 +-
 apps/oci_util.cpp                |  48 ++++++++++++++++++++-------------------
 apps/oci_util.hpp                |   2 +-
 cmake/modules/BuildOSGeo4W.cmake |   1 -
 5 files changed, 33 insertions(+), 41 deletions(-)
diffs (141 lines):
diff -r 82e6ece4d9fe -r 5ac9800e2d83 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt	Sat Nov 20 15:08:17 2010 -0600
+++ b/apps/CMakeLists.txt	Mon Nov 22 12:16:15 2010 -0600
@@ -82,15 +82,6 @@
 link_directories(${Boost_LIBRARY_DIRS})
-set (LASKERNEL_SOURCES laskernel.cpp)
-add_library(${LASKERNEL_LIB_NAME} SHARED ${LASKERNEL_SOURCES})
-target_link_libraries(${LASKERNEL_LIB_NAME}
-                      ${LIBLAS_LIB_NAME})
-install(TARGETS ${LASKERNEL_LIB_NAME}
-  RUNTIME DESTINATION ${LIBLAS_BIN_DIR}
-  LIBRARY DESTINATION ${LIBLAS_LIB_DIR}
-  ARCHIVE DESTINATION ${LIBLAS_LIB_DIR})
 # Build lasinfo
 if(LASINFO_OLD)
@@ -107,13 +98,13 @@
 endif()
 if(LAS2LAS)
-    add_executable(${LAS2LAS} las2las.cpp )
-    target_link_libraries(${LAS2LAS} ${APPS_CPP_DEPENDENCIES} ${LASKERNEL_LIB_NAME})
+    add_executable(${LAS2LAS} las2las.cpp laskernel.cpp)
+    target_link_libraries(${LAS2LAS} ${APPS_CPP_DEPENDENCIES} )
 endif()
 if(LASINFO)
-    add_executable(${LASINFO} lasinfo.cpp )
-    target_link_libraries(${LASINFO} ${APPS_CPP_DEPENDENCIES} ${LASKERNEL_LIB_NAME} )
+    add_executable(${LASINFO} lasinfo.cpp laskernel.cpp )
+    target_link_libraries(${LASINFO} ${APPS_CPP_DEPENDENCIES}  )
 endif()
 # Build las2txt
@@ -157,8 +148,8 @@
 # Build las2oci
 if(LAS2OCI)
-    add_executable(${LAS2OCI} las2oci.cpp oci_wrapper.cpp kdx_util.cpp oci_util.cpp )
-    target_link_libraries(${LAS2OCI} ${APPS_CPP_DEPENDENCIES} ${ORACLE_LIBRARY} ${LASKERNEL_LIB_NAME})
+    add_executable(${LAS2OCI} las2oci.cpp oci_wrapper.cpp kdx_util.cpp oci_util.cpp laskernel.cpp )
+    target_link_libraries(${LAS2OCI} ${APPS_CPP_DEPENDENCIES} ${ORACLE_LIBRARY} )
 endif()
 if(BIGFILE_TEST)
diff -r 82e6ece4d9fe -r 5ac9800e2d83 apps/laskernel.hpp
--- a/apps/laskernel.hpp	Sat Nov 20 15:08:17 2010 -0600
+++ b/apps/laskernel.hpp	Mon Nov 22 12:16:15 2010 -0600
@@ -93,7 +93,7 @@
 #define compare_no_case(a,b,n)  strncasecmp( (a), (b), (n) )
 #endif
-// std::istream* OpenInput(std::string const& filename, bool bEnd);
+std::istream* OpenInput(std::string const& filename, bool bEnd);
 LAS_DLL std::string TryReadFileData(std::string const& filename);
 LAS_DLL std::vector<char> TryReadRawFileData(std::string const& filename);
 LAS_DLL bool term_progress(std::ostream& os, double complete);
diff -r 82e6ece4d9fe -r 5ac9800e2d83 apps/oci_util.cpp
--- a/apps/oci_util.cpp	Sat Nov 20 15:08:17 2010 -0600
+++ b/apps/oci_util.cpp	Mon Nov 22 12:16:15 2010 -0600
@@ -1,29 +1,31 @@
 #include "oci_util.hpp"
-std::istream* OpenInput(std::string const& filename, bool bEnd)
-    std::ios::openmode mode = std::ios::in | std::ios::binary;
-    if (bEnd == true) {
-        mode = mode | std::ios::ate;
-    std::istream* istrm;
-    if (compare_no_case(filename.c_str(),"STDIN",5) == 0)
-        istrm = &std::cin;
-    else
-        istrm = new std::ifstream(filename.c_str(), mode);
-    if (!istrm->good())
-        delete istrm;
-        throw std::runtime_error("Reading stream was not able to be created");
-    return istrm;
+// std::istream* OpenInput(std::string const& filename, bool bEnd)
+//     std::ios::openmode mode = std::ios::in | std::ios::binary;
+//     if (bEnd == true) {
+//         mode = mode | std::ios::ate;
+//     std::istream* istrm;
+//     if (compare_no_case(filename.c_str(),"STDIN",5) == 0)
+//         istrm = &std::cin;
+//     else
+//         istrm = new std::ifstream(filename.c_str(), mode);
+//     if (!istrm->good())
+//         delete istrm;
+//         throw std::runtime_error("Reading stream was not able to be created");
+//     return istrm;
+LAS_DLL std::istream* OpenInput(std::string const& filename, bool bEnd) ;
 std::string ReadSQLData(std::string filename)
diff -r 82e6ece4d9fe -r 5ac9800e2d83 apps/oci_util.hpp
--- a/apps/oci_util.hpp	Sat Nov 20 15:08:17 2010 -0600
+++ b/apps/oci_util.hpp	Mon Nov 22 12:16:15 2010 -0600
@@ -33,7 +33,7 @@
                     std::string cloudColumnName);
 LAS_DLL std::string to_upper(const std::string&);
 LAS_DLL std::string ReadSQLData(std::string filename);
-LAS_DLL std::istream* OpenInput(std::string const& filename, bool bEnd) ;
+// LAS_DLL std::istream* OpenInput(std::string const& filename, bool bEnd) ;
 #ifdef _WIN32
 #define compare_no_case(a,b,n)  _strnicmp( (a), (b), (n) )
diff -r 82e6ece4d9fe -r 5ac9800e2d83 cmake/modules/BuildOSGeo4W.cmake
--- a/cmake/modules/BuildOSGeo4W.cmake	Sat Nov 20 15:08:17 2010 -0600
+++ b/cmake/modules/BuildOSGeo4W.cmake	Mon Nov 22 12:16:15 2010 -0600
@@ -129,7 +129,6 @@
 copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/liblas_c.dll ${OSGEO4W_BIN_DIR}/  )
 copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/liblas.dll ${OSGEO4W_BIN_DIR}/  )
-copy_files(${LIBLAS_BUILD_OUTPUT_DIRECTORY}/liblas_kernel.dll ${OSGEO4W_BIN_DIR}/  )
 copy_files(${libLAS_SOURCE_DIR}/liblas-osgeo4w-start.bat.tmpl ${OSGEO4W_BIN_DIR}/liblas.bat.tmpl )
 copy_files(${libLAS_SOURCE_DIR}/liblas-osgeo4w-init.bat ${OSGEO4W_ETC_INI_DIR}/liblas.bat )
More information about the Liblas-commits mailing list
