[Liblas-commits] hg: add back the libxml2 searching. Have Boost
static/multithre...
liblas-commits at liblas.org
Mon Nov 22 17:11:32 EST 2010
changeset f42350719b60 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=f42350719b60
summary: add back the libxml2 searching. Have Boost static/multithreaded lib stuff only be set for WIN32/MSVC case, which is how we prescribe building on that environment with the boostpro.com installer
diffstat:
CMakeLists.txt | 30 ++++++++++++++++++++++++++++--
1 files changed, 28 insertions(+), 2 deletions(-)
diffs (47 lines):
diff -r 5ac9800e2d83 -r f42350719b60 CMakeLists.txt
--- a/CMakeLists.txt Mon Nov 22 12:16:15 2010 -0600
+++ b/CMakeLists.txt Mon Nov 22 16:11:21 2010 -0600
@@ -150,8 +150,17 @@
# Boost C++ Libraries support - required
message(STATUS "Searching for Boost 1.38+ - done")
-set(Boost_USE_STATIC_LIBS ON)
-set(Boost_USE_MULTITHREADED ON)
+# Default to using static, multithreaded libraries for
+# linking under MSVC. This is because we show users how to
+# use boostpro.com installer and install those options when linking
+# on windows in the compilation documentation.
+if(WIN32)
+ if (MSVC)
+ set(Boost_USE_STATIC_LIBS ON)
+ set(Boost_USE_MULTITHREADED ON)
+ endif(MSVC)
+endif(WIN32)
# NOTE: Add iostreams to COMPONENTS list to enable bigfile_boost_iostreams_test
find_package(Boost 1.38 COMPONENTS program_options REQUIRED)
@@ -164,6 +173,23 @@
mark_as_advanced(CLEAR Boost_LIBRARY_DIRS)
link_directories(${Boost_LIBRARY_DIRS})
+# libxml2 support - optional, default=ON
+set(WITH_LIBXML2 FALSE CACHE BOOL "Choose if libxml2 support should be built ")
+if(WITH_LIBXML2)
+ find_package(LibXml2)
+ mark_as_advanced(CLEAR LIBXML2_INCLUDE_DIR)
+ mark_as_advanced(CLEAR LIBXML2_LIBRARIES)
+ if(LIBXML2_FOUND)
+ include_directories(${LIBXML2_INCLUDE_DIR})
+ add_definitions(-DHAVE_LIBXML2=1)
+ endif()
+endif()
# GeoTIFF support - optional, default=OFF
set(WITH_GEOTIFF FALSE CACHE BOOL "Choose if GeoTIFF support should be built")
More information about the Liblas-commits
