[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Wed Oct 6 10:12:56 EDT 2010
changeset 05de1037ed9c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=05de1037ed9c
summary: fix underlying bug that causes #188 -- fix up VLR writing and WriteLAS10PadSignature to do more reasonable error checking
changeset 2e087c088430 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2e087c088430
summary: merge
diffstat:
apps/las2oci.cpp | 12 +-
apps/ts2las.hpp | 2 +-
include/liblas/detail/private_utility.hpp | 495 ++++++++++++++++++++++++++++++
include/liblas/detail/utility.hpp | 495 ------------------------------
include/liblas/detail/writer/base.hpp | 2 +-
include/liblas/detail/writer/header.hpp | 6 +-
include/liblas/detail/writer/point.hpp | 2 +-
include/liblas/guid.hpp | 2 +-
include/liblas/lasbounds.hpp | 2 +-
include/liblas/laspoint.hpp | 2 +-
include/liblas/lasschema.hpp | 23 +-
include/liblas/lasspatialreference.hpp | 2 +-
include/liblas/lasvariablerecord.hpp | 2 +-
include/liblas/liblas.hpp | 2 +-
src/CMakeLists.txt | 2 +-
src/detail/reader/cachedreader.cpp | 6 +-
src/detail/reader/header.cpp | 4 +-
src/detail/reader/point.cpp | 4 +-
src/detail/reader/reader.cpp | 4 +-
src/detail/utility.cpp | 2 +-
src/detail/writer/header.cpp | 128 +++----
src/detail/writer/point.cpp | 6 +-
src/detail/writer/writer.cpp | 9 +-
src/lasclassification.cpp | 2 +-
src/lasheader.cpp | 4 +-
src/laspoint.cpp | 56 +--
src/lasschema.cpp | 65 +--
src/lasspatialreference.cpp | 2 +-
test/unit/lasreader_iterator_test.cpp | 2 +-
29 files changed, 645 insertions(+), 700 deletions(-)
diffs (truncated from 2057 to 300 lines):
diff -r 6fcfd7074841 -r 2e087c088430 apps/las2oci.cpp
--- a/apps/las2oci.cpp Tue Oct 05 15:48:37 2010 -0500
+++ b/apps/las2oci.cpp Wed Oct 06 09:12:45 2010 -0500
@@ -1,13 +1,8 @@
#include "las2oci.hpp"
-#include <liblas/detail/utility.hpp>
+#include <liblas/detail/private_utility.hpp>
#include "laskernel.hpp"
typedef boost::tokenizer<boost::char_separator<char> > tokenizer;
namespace po = boost::program_options;
@@ -15,11 +10,6 @@
using namespace liblas;
using namespace std;
void OCIGDALDebugErrorHandler(CPLErr eErrClass, int err_no, const char *msg)
ostringstream oss;
diff -r 6fcfd7074841 -r 2e087c088430 apps/ts2las.hpp
--- a/apps/ts2las.hpp Tue Oct 05 15:48:37 2010 -0500
+++ b/apps/ts2las.hpp Wed Oct 06 09:12:45 2010 -0500
@@ -1,6 +1,6 @@
#ifndef TS2LAS_HPP_INCLUDED
#include <liblas/laswriter.hpp>
#include <liblas/laspoint.hpp>
diff -r 6fcfd7074841 -r 2e087c088430 include/liblas/detail/private_utility.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/liblas/detail/private_utility.hpp Wed Oct 06 09:12:45 2010 -0500
@@ -0,0 +1,495 @@
+ * $Id$
+ * Project: libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose: A grab bucket 'o fun for C++ libLAS
+ * Author: Mateusz Loskot, mateusz at loskot.net
+ * Copyright (c) 2008, Mateusz Loskot
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ * * Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * * Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided
+ * with the distribution.
+ * * Neither the name of the Martin Isenburg or Iowa Department
+ * of Natural Resources nor the names of its contributors may be
+ * used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifndef LIBLAS_DETAIL_UTILITY_HPP_INCLUDED
+#define LIBLAS_DETAIL_UTILITY_HPP_INCLUDED
+#include <liblas/detail/pointrecord.hpp>
+#include <liblas/detail/endian.hpp>
+// boost
+#include <boost/concept_check.hpp>
+#include <boost/cstdint.hpp>
+// std
+#include <cassert>
+#include <cstddef>
+#include <cstring>
+#include <algorithm>
+#include <iosfwd>
+#include <limits>
+#include <sstream>
+#include <stdexcept>
+#include <cmath>
+#include <vector>
+/// Defines utilities for internal use in libLAS.
+/// The liblas::detail elements do not belong to the public
+/// interface of libLAS.
+namespace liblas { namespace detail {
+// From http://stackoverflow.com/questions/485525/round-for-float-in-c
+inline double sround(double r) {
+ return (r > 0.0) ? floor(r + 0.5) : ceil(r - 0.5);
+/// Compile-time calculation size of array defined statically.
+template <typename T, std::size_t N>
+inline std::size_t static_array_size(T (&t)[N])
+ boost::ignore_unused_variable_warning(t);
+ return (sizeof(t) / sizeof(t[0]));
+/// Simple RAII wrapper.
+/// It's dedicated to use with types associated with custom deleter,
+/// opaque pointers and C API objects.
+template <typename T>
+class raii_wrapper
+ typedef void(*deleter_type)(T* p);
+public:
+ raii_wrapper(T* p, deleter_type d)
+ : p_(p), del_(d)
+ assert(0 != p_);
+ assert(0 != del_);
+ raii_wrapper& operator=(raii_wrapper const& rhs)
+ if (&rhs != this)
+ p_ = rhs.p_;
+ del_ = rhs.del_;
+ return *this;
+ ~raii_wrapper()
+ do_delete(p_);
+ void reset(T* p)
+ do_delete(p_);
+ p_= p;
+ T* get() const
+ return p_;
+ void swap(raii_wrapper& other)
+ std::swap(p_, other.p_);
+private:
+ raii_wrapper(raii_wrapper const& other);
+ // raii_wrapper& operator=(raii_wrapper const& rhs);
+ void do_delete(T* p)
+ assert(del_);
+ if (0 != p)
+ del_(p);
+ T* p_;
+ deleter_type del_;
+/// Definition of variable-length record header.
+struct VLRHeader
+ boost::uint16_t reserved;
+ char userId[16]; // TODO: replace wtih boost::array --mloskot
+ boost::uint16_t recordId;
+ boost::uint16_t recordLengthAfterHeader;
+ char description[32]; // TODO: replace wtih boost::array --mloskot
+bool compare_distance(const T& actual, const T& expected);
+struct Point
+ Point()
+ : x(T()), y(T()), z(T())
+ Point(T const& x, T const& y, T const& z)
+ : x(x), y(y), z(z)
+ bool equal(Point<T> const& other) const
+ return (compare_distance(x, other.x)
+ && compare_distance(y, other.y)
+ && compare_distance(z, other.z));
+ T x;
+ T y;
+ T z;
+bool operator==(Point<T> const& lhs, Point<T> const& rhs)
+ return lhs.equal(rhs);
+bool operator!=(Point<T> const& lhs, Point<T> const& rhs)
+ return (!lhs.equal(rhs));
+// template <typename T>
+// struct Extents
+// Extents() {}
+// Extents(detail::Point<T> const& min, detail::Point<T> const& max)
+// : min(min), max(max)
+// bool equal(Extents<T> const& other) const
+// return (min == other.min && max == other.max);
+// typename detail::Point<T> min;
+// typename detail::Point<T> max;
+// bool operator==(Extents<T> const& lhs, Extents<T> const& rhs)
+// return lhs.equal(rhs);
+// bool operator!=(Extents<T> const& lhs, Extents<T> const& rhs)
+// return (!lhs.equal(rhs));
+inline T generate_random_byte()
+ // Requires pseudo-random numbers generator to be initialized
+ // in create_random_based() function - a poor man solution.
+ T const rmin = (std::numeric_limits<T>::min)();
+ T const rmax = (std::numeric_limits<T>::max)();
+ unsigned int const rnd = std::rand() % rmax + rmin;
+ assert(rnd <= 255);
+ return static_cast<T>(rnd);
+ const T epsilon = std::numeric_limits<T>::epsilon();
+ const T diff = actual - expected;
+ if ( !((diff <= epsilon) && (diff >= -epsilon )) )
+ return false;
+ return true;
+template<typename T>
+inline char* as_buffer(T& data)
+ return static_cast<char*>(static_cast<void*>(&data));
More information about the Liblas-commits
