[Liblas-commits] hg: push Gary's latest
liblas-commits at liblas.org
Wed Oct 6 14:47:18 EDT 2010
changeset cf94fbdf37e6 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=cf94fbdf37e6
summary: push Gary's latest
diffstat:
apps/lasindex_test.cpp | 29 +++++++++++++++++++++++------
include/liblas/lasindex.hpp | 6 ++++--
src/lasindex.cpp | 38 +++++++++++++++++++++++---------------
3 files changed, 50 insertions(+), 23 deletions(-)
diffs (253 lines):
diff -r 2e087c088430 -r cf94fbdf37e6 apps/lasindex_test.cpp
--- a/apps/lasindex_test.cpp Wed Oct 06 09:12:45 2010 -0500
+++ b/apps/lasindex_test.cpp Wed Oct 06 13:47:11 2010 -0500
@@ -185,12 +185,12 @@
// temporary until argv[] starts to work
// uncomment only one of these blocks
/*------------------------------N1440375----------------------------------*/
- ///*------------------------build embedded index------------------------------
+ /*------------------------build embedded index------------------------------
const char* arggv[] = {"foo", "-t", "C:\\LibLAS\\Samples\\N1440375.tmp",
"-i", "C:\\LibLAS\\Samples\\N1440375.las", "-a", SAMPLE_AUTHOR, "-c", SAMPLE_COMMENT, "-d", SAMPLE_DATE,
"-o", "C:\\LibLAS\\Samples\\N1440375_idx.las"};
argc = 13;
/*-----------------build index in standalone file---------------------------
@@ -207,8 +207,8 @@
"-n", "C:\\LibLAS\\Samples\\N1440375_idx.ldx", "-r"};
argc = 6;
- /*const char* arggv[] = {"foo", "-t", "C:\\LibLAS\\Samples\\N1440375.tmp",
+ /*-----------------build embedded index, filter with user bounds------------
+ const char* arggv[] = {"foo", "-t", "C:\\LibLAS\\Samples\\N1440375.tmp",
"-o", "C:\\LibLAS\\Samples\\N1440375_idx.las",
"-x", "1443000.00", "1444000.00", "-y", "376000.02", "379000.00", "-z", "850.00", "950.00"};
@@ -250,6 +250,18 @@
"-i", "C:\\LibLAS\\Samples\\Lincoln_idx.las", "-r"};
argc = 4;
+ /*------------------------------flatDataset-------------------------------*/
+ ///*------------------------------build index---------------------------------
+ const char* arggv[] = {"foo", "-t", "C:\\LibLAS\\flatDataset.tmp",
+ "-i", "C:\\LibLAS\\Samples\\flatDataset.las", "-a", SAMPLE_AUTHOR, "-c", SAMPLE_COMMENT, "-d", SAMPLE_DATE,
+ "-o", "C:\\LibLAS\\Samples\\flatDataset_idx.las"};
+ argc = 13;
+ /*------------------filter with embedded index------------------------------
+ "-i", "C:\\LibLAS\\Samples\\flatDataset_idx.las", "-r"};
+ argc = 4;
for (int i = 1; i < argc; i++)
@@ -411,7 +423,7 @@
Bounds<double> filterBounds(oLowFilterX, oLowFilterY, oLowFilterZ,
oHighFilterX, oHighFilterY, oHighFilterZ);
- if (ParamSrc.SetFilterValues(filterBounds))
+ if (ParamSrc.SetFilterValues(filterBounds, index))
const std::vector<uint32_t>& FilterResult = index.Filter(ParamSrc);
if (FilterResult.size())
@@ -507,14 +519,19 @@
break;
} // 5
} // switch
// do something with the list of points
+ #ifdef VISUAL_8
+ fprintf(debugger, "Points within filter area %d of %d, %s\n", FilterResult.size(),
+ index.GetPointRecordsCount(), CovgStr);
+ #else // VISUAL_8
fprintf(debugger, "Points within filter area %zu of %d, %s\n", FilterResult.size(),
+ #endif // VISUAL_8
else
IndexFilterNoPoints(debugger);
diff -r 2e087c088430 -r cf94fbdf37e6 include/liblas/lasindex.hpp
--- a/include/liblas/lasindex.hpp Wed Oct 06 09:12:45 2010 -0500
+++ b/include/liblas/lasindex.hpp Wed Oct 06 13:47:11 2010 -0500
@@ -379,8 +379,9 @@
boost::uint32_t maxmem = LIBLAS_INDEX_MAXMEMDEFAULT, int debugoutputlevel = 0, FILE *debugger = 0);
// set the bounds for use in filtering
- bool SetFilterValues(double LowFilterX, double HighFilterX, double LowFilterY, double HighFilterY, double LowFilterZ, double HighFilterZ);
- bool SetFilterValues(Bounds<double> const& src);
+ bool SetFilterValues(double LowFilterX, double HighFilterX, double LowFilterY, double HighFilterY, double LowFilterZ, double HighFilterZ,
+ Index const& index);
+ bool SetFilterValues(Bounds<double> const& src, Index const& index);
// Blocked copying operations, declared but not defined.
/// Copy constructor.
@@ -427,6 +428,7 @@
double GetMaxFilterY(void) const {return m_filter.max(1);};
double GetMinFilterZ(void) const {return m_filter.min(2);};
double GetMaxFilterZ(void) const {return m_filter.max(2);};
+ void ClampFilterBounds(Bounds<double> const& m_bounds);
void SetReader(Reader *reader) {m_reader = reader;};
void SetIStream(std::istream *ifs) {m_ifs = ifs;};
void SetOStream(std::ostream *ofs) {m_ofs = ofs;};
diff -r 2e087c088430 -r cf94fbdf37e6 src/lasindex.cpp
--- a/src/lasindex.cpp Wed Oct 06 09:12:45 2010 -0500
+++ b/src/lasindex.cpp Wed Oct 06 13:47:11 2010 -0500
@@ -43,6 +43,7 @@
#include <liblas/laswriter.hpp>
#include <liblas/detail/index/indexoutput.hpp>
#include <liblas/detail/index/indexcell.hpp>
+#include <liblas/detail/writer/writer.hpp>
namespace liblas
@@ -303,7 +304,7 @@
m_filterMinYCell = m_cellsY * (ParamSrc.GetMinFilterY() - GetMinY()) / GetRangeY();
m_filterMaxYCell = m_cellsY * (ParamSrc.GetMaxFilterY() - GetMinY()) / GetRangeY();
// Z range however can be 0
- if (GetRangeZ() > 0.0)
+ if (GetRangeZ() > 0.0 && ! detail::compare_distance(GetRangeZ(), 0.0))
m_filterMinZCell = m_cellsZ * (ParamSrc.GetMinFilterZ() - GetMinZ()) / GetRangeZ();
m_filterMaxZCell = m_cellsZ * (ParamSrc.GetMaxFilterZ() - GetMinZ()) / GetRangeZ();
@@ -731,7 +732,7 @@
// seek and read
assert(static_cast<boost::uint32_t>(PointID) < m_pointRecordsCount);
- PtRead = (m_reader->seek(PointID) && m_reader->ReadNextPoint());
+ PtRead = (m_reader->seek(PointID) && m_reader->ReadNextPoint());
} // if
if (PtRead)
@@ -774,7 +775,7 @@
// seek and read
} // if
if (PtRead)
@@ -818,7 +819,7 @@
// seek and read
} // if
if (PtRead)
@@ -857,7 +858,7 @@
CalcRangeY();
CalcRangeZ();
- if (m_cellSizeZ > 0.0)
+ if (m_cellSizeZ > 0.0 && ! detail::compare_distance(m_cellSizeZ, 0.0))
m_cellsZ = static_cast<boost::uint32_t>(ceil(m_rangeZ / m_cellSizeZ));
else
m_cellsZ = 1;
@@ -1008,7 +1009,7 @@
// get the actual point from the las file
assert(MapIt->first < m_pointRecordsCount);
- if (m_reader->seek(MapIt->first) && m_reader->ReadNextPoint())
+ if (m_reader->seek(MapIt->first) && m_reader->ReadNextPoint())
boost::uint32_t FirstPt = 0, LastCellZ = static_cast<boost::uint32_t>(~0);
boost::uint32_t LastSubCell = static_cast<boost::uint32_t>(~0);
@@ -1125,7 +1126,7 @@
OffsetX = (CurPt.GetX() - m_bounds.min(0)) / m_rangeX;
if (OffsetX >= 0 && OffsetX < 1.0)
CurCellX = static_cast<boost::uint32_t>(OffsetX * m_cellsX);
- else if (OffsetX == 1.0)
+ else if (detail::compare_distance(OffsetX, 1.0))
CurCellX = m_cellsX - 1;
else
@@ -1135,7 +1136,7 @@
OffsetY = (CurPt.GetY() - m_bounds.min(1)) / m_rangeY;
if (OffsetY >= 0 && OffsetY < 1.0)
CurCellY = static_cast<boost::uint32_t>(OffsetY * m_cellsY);
- else if (OffsetY == 1.0)
+ else if (detail::compare_distance(OffsetY, 1.0))
CurCellY = m_cellsY - 1;
else
@@ -1153,7 +1154,7 @@
OffsetZ = (CurPt.GetZ() - m_bounds.min(2)) / m_rangeZ;
if (OffsetZ >= 0 && OffsetZ < 1.0)
CurCellZ = static_cast<boost::uint32_t>(OffsetZ * m_cellsZ);
- else if (OffsetZ == 1.0)
+ else if (detail::compare_distance(OffsetZ, 1.0))
CurCellZ = m_cellsZ - 1;
else
@@ -1194,7 +1195,7 @@
return true;
-} // Index::IdentifyCellZ
+} // Index::IdentifySubCell
bool Index::PurgePointsToTempFile(IndexCellDataBlock& CellBlock)
@@ -1731,11 +1732,12 @@
} // IndexData::SetBuildAloneValues
bool IndexData::SetFilterValues(double LowFilterX, double HighFilterX, double LowFilterY, double HighFilterY,
- double LowFilterZ, double HighFilterZ)
+ double LowFilterZ, double HighFilterZ, Index const& index)
try {
m_filter = Bounds<double>(LowFilterX, LowFilterY, LowFilterZ, HighFilterX, HighFilterY, HighFilterZ);
m_filter.verify();
+ m_filter.clip(index.GetBounds());
} // try
catch (std::runtime_error) {
return (false);
@@ -1744,11 +1746,12 @@
} // IndexData::SetFilterValues
-bool IndexData::SetFilterValues(Bounds<double> const& src)
+bool IndexData::SetFilterValues(Bounds<double> const& src, Index const& index)
try {
m_filter = src;
m_filter.verify();
} // try
return (false);
@@ -1759,14 +1762,19 @@
bool IndexData::CalcFilterEnablers(void)
- if (m_filter.min(0) == m_filter.max(0))
+ if (detail::compare_distance(m_filter.min(0), m_filter.max(0)))
m_noFilterX = true;
- if (m_filter.min(1) == m_filter.max(1))
+ if (detail::compare_distance(m_filter.min(1), m_filter.max(1)))
m_noFilterY = true;
- if (m_filter.min(2) == m_filter.max(2))
+ if (detail::compare_distance(m_filter.min(2), m_filter.max(2)))
m_noFilterZ = true;
return (! (m_noFilterX && m_noFilterY && m_noFilterZ));
} // IndexData::CalcFilterEnablers
+void IndexData::ClampFilterBounds(Bounds<double> const& m_bounds)
+ m_filter.clip(m_bounds);
+} // IndexData::ClampFilterBounds
} // namespace liblas
More information about the Liblas-commits
