[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org
Thu Oct 7 11:55:30 EDT 2010
changeset 47129cabb288 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=47129cabb288
summary: we can't write the pad bytes if we have less than 2 bytes between the end of the VLR block and the end of the header -- not *only* 2 bytes
changeset dbbfd9a96a6c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=dbbfd9a96a6c
summary: remove extraneous throw_out_of_range, we weren't using it
diffstat:
include/liblas/laspoint.hpp | 3 +--
src/detail/writer/header.cpp | 2 +-
src/laspoint.cpp | 6 ------
3 files changed, 2 insertions(+), 9 deletions(-)
diffs (48 lines):
diff -r cf94fbdf37e6 -r dbbfd9a96a6c include/liblas/laspoint.hpp
--- a/include/liblas/laspoint.hpp Wed Oct 06 13:47:11 2010 -0500
+++ b/include/liblas/laspoint.hpp Thu Oct 07 10:55:19 2010 -0500
@@ -216,7 +216,6 @@
HeaderPtr m_header;
Header const& m_default_header;
- void throw_out_of_range() const;
/// Equal-to operator implemented in terms of Point::equal method.
@@ -241,7 +240,7 @@
if (index == 2)
return GetZ();
- throw_out_of_range();
+ throw std::out_of_range("coordinate subscript out of range");
diff -r cf94fbdf37e6 -r dbbfd9a96a6c src/detail/writer/header.cpp
--- a/src/detail/writer/header.cpp Wed Oct 06 13:47:11 2010 -0500
+++ b/src/detail/writer/header.cpp Thu Oct 07 10:55:19 2010 -0500
@@ -358,7 +358,7 @@
int32_t diff = m_header.GetDataOffset() - GetRequiredHeaderSize();
- if (diff != 2) {
+ if (diff < 2) {
std::ostringstream oss;
oss << "Header is not large enough to write extra 1.0 pad bytes. Data offset is ";
oss << m_header.GetDataOffset() << " while the required total size ";
diff -r cf94fbdf37e6 -r dbbfd9a96a6c src/laspoint.cpp
--- a/src/laspoint.cpp Wed Oct 06 13:47:11 2010 -0500
+++ b/src/laspoint.cpp Thu Oct 07 10:55:19 2010 -0500
@@ -276,12 +276,6 @@
return os;
-void Point::throw_out_of_range() const
- throw std::out_of_range("coordinate subscript out of range");
double Point::GetX() const
More information about the Liblas-commits
