[Liblas-commits] hg: reorganize liblas::Dimension into its on
source and header f...
liblas-commits at liblas.org
Thu Oct 7 13:26:11 EDT 2010
changeset 81c45bb49008 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=81c45bb49008
summary: reorganize liblas::Dimension into its on source and header files
diffstat:
include/liblas/lasdimension.hpp | 170 ++++++++++++++++++++++++++++++++++++++++
include/liblas/lasschema.hpp | 166 ++++----------------------------------
src/CMakeLists.txt | 2 +
src/lasdimension.cpp | 141 +++++++++++++++++++++++++++++++++
4 files changed, 334 insertions(+), 145 deletions(-)
diffs (truncated from 540 to 300 lines):
diff -r dbbfd9a96a6c -r 81c45bb49008 include/liblas/lasdimension.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/liblas/lasdimension.hpp Thu Oct 07 12:26:03 2010 -0500
@@ -0,0 +1,170 @@
+ * $Id$
+ * Project: libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose: LAS Dimension implementation for C++ libLAS
+ * Author: Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2010, Howard Butler
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ * * Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * * Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided
+ * with the distribution.
+ * * Neither the name of the Martin Isenburg or Iowa Department
+ * of Natural Resources nor the names of its contributors may be
+ * used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifndef LIBLAS_DIMENSION_HPP_INCLUDED
+#define LIBLAS_DIMENSION_HPP_INCLUDED
+#include <liblas/lasversion.hpp>
+#include <liblas/external/property_tree/ptree.hpp>
+#include <liblas/lasvariablerecord.hpp>
+// boost
+#include <boost/cstdint.hpp>
+#include <boost/any.hpp>
+#include <boost/shared_ptr.hpp>
+#include <boost/foreach.hpp>
+#include <boost/array.hpp>
+#include <boost/multi_index_container.hpp>
+#include <boost/multi_index/member.hpp>
+#include <boost/multi_index/ordered_index.hpp>
+#include <boost/multi_index/hashed_index.hpp>
+#include <boost/multi_index/sequenced_index.hpp>
+// std
+#include <iosfwd>
+#include <limits>
+#include <string>
+#include <vector>
+#include <algorithm>
+#include <boost/unordered_map.hpp>
+namespace liblas {
+/// Dimension definition
+class Dimension
+public:
+ Dimension(std::string const& name, boost::uint32_t size_in_bits);
+ Dimension& operator=(Dimension const& rhs);
+ Dimension(Dimension const& other);
+ virtual ~Dimension() {};
+ std::string const& GetName() { return m_name; }
+ /// bits, logical size of point record
+ std::size_t GetBitSize() const
+ return m_bit_size;
+ /// bytes, physical/serialisation size of record
+ std::size_t GetByteSize() const;
+ /// Is this dimension required by PointFormatName
+ bool IsRequired() const { return m_required; }
+ void IsRequired(bool v) { m_required = v; }
+ /// Is this dimension being used. A dimension with
+ /// IsActive false may exist as a placeholder in PointFormatName-specified
+ /// dimensions, but have their IsActive flag set to false. In this
+ /// case, those values may be disregarded.
+ bool IsActive() const { return m_active; }
+ void IsActive(bool v) { m_active = v; }
+ std::string GetDescription() const { return m_description; }
+ void SetDescription(std::string const& v) { m_description = v; }
+ /// Is this dimension a numeric dimension. Dimensions with IsNumeric == false
+ /// are considered generic bit/byte fields/
+ bool IsNumeric() const { return m_numeric ; }
+ void IsNumeric(bool v) { m_numeric = v; }
+ /// Does this dimension have a sign? Only applicable to dimensions with
+ /// IsNumeric == true.
+ bool IsSigned() const { return m_signed; }
+ void IsSigned(bool v) { m_signed = v; }
+ /// Does this dimension interpret to an integer? Only applicable to dimensions
+ /// with IsNumeric == true.
+ bool IsInteger() const { return m_integer; }
+ void IsInteger(bool v) { m_integer = v; }
+ /// The minimum value of this dimension as a double
+ double GetMinimum() { return m_min; }
+ void SetMinimum(double min) { m_min = min; }
+ /// The maximum value of this dimension as a double
+ double GetMaximum() { return m_max; }
+ void SetMaximum(double max) { m_max = max; }
+ boost::uint32_t GetPosition() const { return m_position; }
+ void SetPosition(boost::uint32_t v) { m_position = v; }
+ double GetScale() const { return m_scale; }
+ void SetScale(double v) { m_scale = v; }
+ double GetOffset() const { return m_offset; }
+ void SetOffset(double v) { m_offset = v; }
+ bool IsFinitePrecision() const { return m_precise; }
+ void IsFinitePrecision(bool v) { m_precise = v; }
+ bool operator < (Dimension const& dim) const
+ return m_position < dim.m_position;
+private:
+ std::string m_name;
+ boost::uint32_t m_bit_size;
+ bool m_required;
+ bool m_active;
+ std::string m_description;
+ double m_min;
+ double m_max;
+ bool m_numeric;
+ bool m_signed;
+ bool m_integer;
+ boost::uint32_t m_position;
+ double m_scale;
+ bool m_precise;
+ double m_offset;
+} // namespace liblas
+#endif // LIBLAS_DIMENSION_HPP_INCLUDED
diff -r dbbfd9a96a6c -r 81c45bb49008 include/liblas/lasschema.hpp
--- a/include/liblas/lasschema.hpp Thu Oct 07 10:55:19 2010 -0500
+++ b/include/liblas/lasschema.hpp Thu Oct 07 12:26:03 2010 -0500
@@ -46,12 +46,22 @@
+#include <liblas/lasdimension.hpp>
// boost
// std
#include <iosfwd>
#include <limits>
@@ -62,14 +72,23 @@
namespace liblas {
-class Dimension;
typedef boost::shared_ptr<Dimension> DimensionPtr;
typedef boost::unordered_map<std::string, DimensionPtr> DimensionMap;
typedef std::vector<DimensionPtr> DimensionArray;
typedef boost::array<std::size_t, 4> SizesArray;
typedef boost::unordered_map<std::string, SizesArray> SizesMap;
+// using namespace boost::multi_index;
+// typedef multi_index_container<
+// DimensionPtr,
+// indexed_by<
+// hashed_unique<tag<key>, BOOST_MULTI_INDEX_MEMBER(Data_t,int,key_)>,
+// sequenced<tag<key_seq> >
+// > Map;
/// Schema definition
class Schema
@@ -134,149 +153,6 @@
-/// Dimension definition
-class Dimension
-public:
- Dimension(std::string const& name, boost::uint32_t size_in_bits) :
- m_name(name),
- m_bitsize(size_in_bits),
- m_required(false),
- m_active(false),
- m_description(std::string("")),
- m_min(0),
- m_max(0),
- m_numeric(false),
- m_signed(false),
- m_integer(false),
- m_position(0)
- if (size_in_bits == 0) {
- std::ostringstream oss;
- oss << "The bit size of the dimension is 0, the dimension is invalid.";
- throw std::runtime_error(oss.str());
- virtual ~Dimension() {};
- std::string const& GetName() { return m_name; }
- /// bits, logical size of point record
- std::size_t GetBitSize() const
- return m_bitsize;
- /// bytes, physical/serialisation size of record
- std::size_t GetByteSize() const
- std::size_t bit_position = m_bitsize % 8;
- if (bit_position > 0) {
- // For dimensions that are not byte aligned,
- // we need to determine how many bytes they
- // will take. We have to read at least one byte if the
- // size in bits is less than 8. If it is more than 8,
- // we need to read the number of bytes it takes + 1 extra.
- if (m_bitsize > 8) {
- return m_bitsize/8 + 1;
- } else {
- return 1;
- return m_bitsize / 8;
- // /// This stuff needs to be put in dim-GetBytesize
- // if (m_bitsize > 8) {
- // return = m_bitsize / 8 + 1;
- // } else {
- // byte_size = 1;
- // // if (m_bitsize % 8 != 0) {
- // // std::ostringstream oss;
- // // oss << m_name << "'s bit size, " << m_bitsize
- // // << ", is not a multiple of 8 and "
- // // << "cannot be expressed as a single byte value";
- // // throw std::range_error(oss.str());
- // // return m_bitsize / 8;
More information about the Liblas-commits
