[Liblas-commits] hg: 5 new changesets
liblas-commits at liblas.org
Sat Oct 9 19:17:54 EDT 2010
changeset 555da2e430b5 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=555da2e430b5
summary: rename EmptyHeader to DefaultHeader to more accurately reflect what it is
changeset 7b0859cc333c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=7b0859cc333c
summary: use a random_access view on the multi_index for fetching byte offset sizes of fixed-position dimensions. Move sizes stuff onto the dimension
changeset 38ebc1c8e1da in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=38ebc1c8e1da
summary: move byte offset sizes here for now
changeset 2930d5919a46 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2930d5919a46
summary: remove GetDimensionPosition(name)
changeset 2fe4df7bda66 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2fe4df7bda66
summary: use fixed (numerical) dimension positions to denote the index position of the PointFormatName-fixed dimensions. Requires random_access view on the Schema's multi_index to work. And fast too -- down to ~3 sec on a debug build from the previous ~ 15 sec
diffstat:
include/liblas/lasdimension.hpp | 10 +
include/liblas/lasheader.hpp | 10 +-
include/liblas/laspoint.hpp | 3 +-
include/liblas/lasschema.hpp | 9 +-
src/lasdimension.cpp | 3 +
src/laspoint.cpp | 406 ++++++++++++++++++++++++++-------------
src/lasschema.cpp | 55 +----
src/utility.cpp | 8 +
8 files changed, 313 insertions(+), 191 deletions(-)
diffs (truncated from 870 to 300 lines):
diff -r 35180fc82d8b -r 2fe4df7bda66 include/liblas/lasdimension.hpp
--- a/include/liblas/lasdimension.hpp Fri Oct 08 12:36:47 2010 -0500
+++ b/include/liblas/lasdimension.hpp Sat Oct 09 18:17:39 2010 -0500
@@ -70,6 +70,7 @@
namespace liblas {
+typedef boost::array<std::size_t, 4> SizesArray;
/// Dimension definition
class Dimension
@@ -145,6 +146,13 @@
return m_position < dim.m_position;
+ bool operator > (Dimension const& dim) const
+ return m_position > dim.m_position;
+ SizesArray const& GetSizes() const { return m_sizes; }
+ void SetSizes(SizesArray const& a) { m_sizes = a; }
private:
std::string m_name;
@@ -161,6 +169,8 @@
double m_scale;
bool m_precise;
double m_offset;
+ SizesArray m_sizes;
diff -r 35180fc82d8b -r 2fe4df7bda66 include/liblas/lasheader.hpp
--- a/include/liblas/lasheader.hpp Fri Oct 08 12:36:47 2010 -0500
+++ b/include/liblas/lasheader.hpp Sat Oct 09 18:17:39 2010 -0500
@@ -408,10 +408,10 @@
/// a reader creates the point, the HeaderPtr from the file that was
/// read will be used, but all stand-alone points will have EmptyHeader
/// as their base.
-class EmptyHeader
+class DefaultHeader
public:
- virtual ~EmptyHeader() {};
+ virtual ~DefaultHeader() {};
static Header const& get()
@@ -419,9 +419,9 @@
return object;
protected:
- EmptyHeader();
- EmptyHeader( EmptyHeader const&);
- EmptyHeader& operator=( EmptyHeader const&);
+ DefaultHeader();
+ DefaultHeader( DefaultHeader const&);
+ DefaultHeader& operator=( DefaultHeader const&);
diff -r 35180fc82d8b -r 2fe4df7bda66 include/liblas/laspoint.hpp
--- a/include/liblas/laspoint.hpp Fri Oct 08 12:36:47 2010 -0500
+++ b/include/liblas/laspoint.hpp Sat Oct 09 18:17:39 2010 -0500
@@ -211,8 +211,7 @@
detail::PointRecord m_record;
std::vector<boost::uint8_t> m_format_data;
- std::vector<boost::uint8_t>::size_type GetDimensionPosition(std::string const& name) const;
+ std::vector<boost::uint8_t>::size_type GetDimensionBytePosition(std::size_t dim_pos) const;
HeaderPtr m_header;
Header const& m_default_header;
diff -r 35180fc82d8b -r 2fe4df7bda66 include/liblas/lasschema.hpp
--- a/include/liblas/lasschema.hpp Fri Oct 08 12:36:47 2010 -0500
+++ b/include/liblas/lasschema.hpp Sat Oct 09 18:17:39 2010 -0500
@@ -61,6 +61,7 @@
#include <boost/multi_index/hashed_index.hpp>
#include <boost/multi_index/sequenced_index.hpp>
#include <boost/multi_index/mem_fun.hpp>
+#include <boost/multi_index/random_access_index.hpp>
// std
@@ -81,7 +82,7 @@
struct name{};
struct position{};
+struct index{};
typedef multi_index_container<
@@ -90,6 +91,8 @@
// sort by Dimension::operator<
ordered_unique<tag<position>, identity<Dimension> >,
+ // Random access
+ random_access<tag<index> >,
// sort by less<string> on GetName
hashed_unique<tag<name>, const_mem_fun<Dimension,std::string const&,&Dimension::GetName> >
@@ -99,6 +102,8 @@
typedef IndexMap::index<name>::type index_by_name;
typedef IndexMap::index<position>::type index_by_position;
+typedef IndexMap::index<index>::type index_by_index;
/// Schema definition
class Schema
@@ -138,6 +143,7 @@
IndexMap const& GetDimensions() const { return m_index; }
liblas::property_tree::ptree GetPTree() const;
SizesArray const& GetSizes(std::string const& n) const;
+ SizesArray const& GetSizes(std::size_t pos) const;
boost::uint16_t GetSchemaVersion() const { return m_schemaversion; }
void SetSchemaVersion(boost::uint16_t v) { m_schemaversion = v; }
@@ -152,7 +158,6 @@
std::size_t m_bit_size;
std::size_t m_base_bit_size;
boost::uint16_t m_schemaversion;
- SizesMap m_sizes;
private:
diff -r 35180fc82d8b -r 2fe4df7bda66 src/lasdimension.cpp
--- a/src/lasdimension.cpp Fri Oct 08 12:36:47 2010 -0500
+++ b/src/lasdimension.cpp Sat Oct 09 18:17:39 2010 -0500
@@ -80,6 +80,7 @@
oss << "The bit size of the dimension is 0, the dimension is invalid.";
throw std::runtime_error(oss.str());
+ m_sizes.assign(0);
/// copy constructor
@@ -95,6 +96,7 @@
, m_signed(other.m_signed)
, m_integer(other.m_integer)
, m_position(other.m_position)
+ , m_sizes(other.m_sizes)
@@ -114,6 +116,7 @@
m_signed = rhs.m_signed;
m_integer = rhs.m_integer;
m_position = rhs.m_position;
+ m_sizes = rhs.m_sizes;
return *this;
diff -r 35180fc82d8b -r 2fe4df7bda66 src/laspoint.cpp
--- a/src/laspoint.cpp Fri Oct 08 12:36:47 2010 -0500
+++ b/src/laspoint.cpp Sat Oct 09 18:17:39 2010 -0500
@@ -63,7 +63,7 @@
Point::Point()
: m_header(HeaderPtr())
- , m_default_header(EmptyHeader::get())
+ , m_default_header(DefaultHeader::get())
m_format_data.resize(ePointSize3);
m_format_data.assign(ePointSize3, 0);
@@ -71,7 +71,7 @@
Point::Point(HeaderPtr hdr)
: m_header(hdr)
@@ -80,7 +80,7 @@
Point::Point(Point const& other)
: m_format_data(other.m_format_data)
, m_header(other.m_header)
@@ -388,7 +388,8 @@
boost::int32_t Point::GetRawX() const
- std::vector<boost::uint8_t>::size_type pos = GetDimensionPosition("X");
+ // std::vector<boost::uint8_t>::size_type pos = GetDimensionPosition("X");
+ std::vector<boost::uint8_t>::size_type pos = GetDimensionBytePosition(0);
boost::int32_t output = liblas::detail::bitsToInt<boost::int32_t>(output, m_format_data, pos);
return output;
@@ -396,7 +397,8 @@
boost::int32_t Point::GetRawY() const
- std::vector<boost::uint8_t>::size_type pos = GetDimensionPosition("Y");
+ // std::vector<boost::uint8_t>::size_type pos = GetDimensionPosition("Y");
+ std::vector<boost::uint8_t>::size_type pos = GetDimensionBytePosition(1);
return output;
@@ -405,7 +407,8 @@
boost::int32_t Point::GetRawZ() const
boost::int32_t output;
- std::vector<boost::uint8_t>::size_type pos = GetDimensionPosition("Z");
+ // std::vector<boost::uint8_t>::size_type pos = GetDimensionPosition("Z");
+ std::vector<boost::uint8_t>::size_type pos = GetDimensionBytePosition(2);
return output;
@@ -413,27 +416,32 @@
void Point::SetRawX( boost::int32_t const& value)
liblas::detail::intToBits<boost::int32_t>(value, m_format_data, pos);
void Point::SetRawY( boost::int32_t const& value)
void Point::SetRawZ( boost::int32_t const& value)
boost::uint16_t Point::GetIntensity() const
+ // Intensity's position is always the 4th dimension
+ std::vector<boost::uint8_t>::size_type pos = GetDimensionBytePosition(3);
boost::uint16_t output =
liblas::detail::bitsToInt<boost::uint16_t>(
- output, m_format_data, GetDimensionPosition("Intensity"));
+ output, m_format_data, pos);
return output;
@@ -441,24 +449,35 @@
void Point::SetIntensity(boost::uint16_t const& intensity)
liblas::detail::intToBits<boost::uint16_t>(intensity,
m_format_data,
- GetDimensionPosition("Intensity"));
+ pos);
boost::uint8_t Point::GetScanFlags() const
- return m_format_data[GetDimensionPosition("Return Number")];
+ // Scan Flag's position is always the 5th dimension
+ // (the entire byte composed of "Return Number", "Number of Returns",
+ // "Scan Direction", and "Flightline Edge")
+ std::vector<boost::uint8_t>::size_type pos = GetDimensionBytePosition(4);
+ return m_format_data[pos];
void Point::SetScanFlags(boost::uint8_t const& flags)
- m_format_data[GetDimensionPosition("Return Number")] = flags;
+ m_format_data[pos] = flags;
boost::uint16_t Point::GetReturnNumber() const
- std::vector<boost::uint8_t>::size_type pos = GetDimensionPosition("Return Number");
+ // "Return Number" is always the 5th dimension
boost::uint8_t flags = m_format_data[pos];
// Read bits 1,2,3 (first 3 bits)
@@ -467,8 +486,9 @@
void Point::SetReturnNumber(uint16_t const& num)
More information about the Liblas-commits
